Old 11-03-2012, 06:21 PM   #48481
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,328
Originally Posted by beechum1 View Post
Theener
B
techforlife is offline   Reply With Quote
Old 11-03-2012, 06:25 PM   #48482
mcma111
mcma111's Avatar
Oddometer: 12,289
Air Filter Cleaning
Yes gasoline will work but you then need to wash the filter to get rid of the residue before you oil it up.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-03-2012, 06:54 PM   #48483
absoluteclint
absoluteclint's Avatar
Oddometer: 206
Originally Posted by techforlife View Post
Problem with carb cleaner is some types eat plastic badly,,some don`t..i`d use straight gas in a pinch and wash out with soap after..
B
+1... gas followed by mild soap (blue Dawn), air dry, apply oil, insert, ride on! I'm new to owning an XRL but unless it's airfilter differs from a traditional foam filter that's common on atvs, lawnmowers, etc. I'd stick to this method... Has always worked for me on foam filters.
Huh... Speaking of air filters maybe I'll check/clean mine tomorrow... Just acquired this bike a week ago... So far I've only de-stickered it from the previous owner, changed the oil, and got a tag! Went for my first real ride today... really liking the XRL!
Can't speak in favor or against the carb cleaner... never used it.
absoluteclint is offline   Reply With Quote
Old 11-03-2012, 06:59 PM   #48484
Spud Rider
Spud Rider's Avatar
Oddometer: 3,777
Originally Posted by Ulyses View Post
Okay, so Mexican Home Depot it is! Or even Mexican Walmart.
Will straight gas work? That would save me the hassle of riding all over a strange city with over a 1,000,000 inhabitants.
Clean the air filter with gasoline. After all the dirt and filter oil are removed, wash the filter thoroughly in soapy water. Then rinse all the soap out of the filter, and let the filter dry. After the filter is completely dry, apply your No-Toil filter oil. Let the carrier evaporate completely until the filter oil becomes tacky. Once the oil is tacky, you can install the air filter in your XR650L.
Did you bring along the original, red, No-Toil filter oil, or the new, Evolution filter oil?
Spud
Old 11-03-2012, 08:32 PM   #48485
ReferJohn
3RD Generation Rider
ReferJohn's Avatar
Oddometer: 447
temperature sensor
Does any one make a Temperature sensor for the head where the upper banjo bolt mounts instream with the oil?
where can i get one.
Thanks in advance
John
CMA FAST LANE
01' XR650L - 06' NPS50 - 07' KLX 110 - 12' FLTRU - 12' RMZ 250
ReferJohn is offline   Reply With Quote
Old 11-03-2012, 08:59 PM   #48486
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,555
Thanks in advance
John
That is where the TrailTech sensor connects.
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Old 11-03-2012, 09:06 PM   #48487
Mossy-Back
Wet-Sider
Mossy-Back's Avatar
Oddometer: 1,649
Originally Posted by Brown Falcon View Post
So... trying to prepare for trail riding over the next few months and wanting to figure out what parts and accessories I should be getting.
I already have bark busters, XRR sprocket, Dave's mods and 55/158 jetting, K&N air filter (not thrilled with this), smog removed, snorkel removed, and Hoglegs from Manracks.
So far this is my list:
- tires (somthing better than the Avon's I have now)
- fork boots
- skid plate
- fork brace
- case guard (on shifter side)
Also, need to get me some of those combination tire-iron/axle nut wrench tools, and a couple extra tubes.
Evan
2013 Husqvarna Strada
'93 XR650L (Gone, but missed)
Ooh-Rah! Once a Marine, always a Marine!
Originally Posted by kenny61 View Post
figures...my stud was rusty I played with my nuts a little and it cranked right over
Mossy-Back is offline   Reply With Quote
Old 11-03-2012, 09:10 PM   #48488
Mossy-Back
Wet-Sider
Mossy-Back's Avatar
Oddometer: 1,649
Can't remember if I posted this before...
Here's my bike as it is now with the MSR handguards and my B&W Outdoor Case on the back. So far the case is working great! I don't even notice it when riding, fits a helmet with room to spare, and totally waterproof. Great for my commute to school 5 days a week in this rainy Oregon weather.
Evan
Old 11-03-2012, 09:12 PM   #48489
ReferJohn
ReferJohn's Avatar
Oddometer: 447
I don't have a Vapor,, nor do i plan to get a Vapor.
does the TrailTech you mentioned have it's own display reading
or is there another company that makes a temperature sensor
I already have a XR's only dipstick
CMA FAST LANE
Old 11-03-2012, 09:15 PM   #48490
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,555
Check out their website if you want to know more about their stuff. Their sensor connects to the banjo.
Old 11-03-2012, 10:35 PM   #48491
Spud Rider
Spud Rider's Avatar
Oddometer: 3,777
You can buy a Trail Tech, TTO Temperature Gauge.
http://trailtech.net/tto_temperature.html
I installed a TTO Temperature Gauge with the BSPP 1/8-28 temperature probe when I installed my oil cooler.
http://www.advrider.com/forums/showthread.php?t=781962
I believe you want the 10mm cylinder head temperature sensor if you wish to mount the sensor on the banjo bolt for the external oil line to the cylinder head.
http://www.trailtech.net/7500-3010.html
I see Trail Tech is also offering an M12 bolt which will probably fit the oil drain plug on the crankcase.
http://www.trailtech.net/VA-12150.html
However, you would need to run a long wire from a BSPP 1/8-28 temperature probe to use this 12mm bolt.
Spud
Old 11-04-2012, 06:53 AM   #48492
selkirkswamper
hellbilly
selkirkswamper's Avatar
Oddometer: 142
winter mods, commuter set up.......
While I don't post much I'm lurking here daily, I posted a few questions earlier this spring after I picked up my 2012 XR650L. I still really like the cycle (I currently only have the one cycle). I haven't delved in to many mods, having been laid off for a couple months cahs was tight, back to work now and I'm making my list:
what I've done so far;
4 gallon clarke tank
crf front fender
skid plate
rear rack (hopefully will be replaced with a manracks one)
so with the limited riding season coming up here in upstate NY here's my list:
XRR moose/PBI front sprocket
smog removal/block off
rejet- I know everyone say do Dave's Mod, I'm thinking of just a couple of jets and go....use stock air filter, maybe the factory pro jet kit
replace the handlebars (bent couple drops on the trials) with protaper ATV hi bars
I've already done a few oil/filter changes been using the spec'd Honda 10w-30 oil, I've been getting it online for about the price of Rotella at Walmart (from Ron Ayers)
one question I have is the Rotella synthetic?
Another new job has a commute of about 40 miles each way mostly slab at 65mph+
is anyone riding the 650l daily under these conditions?
I'm looking for ideas for tires (I still want some dirt light off road capability), wind screen,
eventually an oil cooler either one from Sutton Cycle works or the Van Pelt one if it is still being made.
Anyway I'm just looking for ideas, my other option is to look for a more street oriented ride like an old Suzuki bandit, Kawi Concours, etc, pm me if you like
thanks all.......
selkirkswamper is offline   Reply With Quote
Old 11-04-2012, 08:35 AM   #48493
ReferJohn
ReferJohn's Avatar
Oddometer: 447
Spud
SPUD YOU ROCK, thats what i am trying to do...less the oil cooler
thanks again
SPUD JESUS LOVES YOU AND SO DO THE INMATES.
John
CMA FAST LANE
Old 11-04-2012, 09:03 AM   #48494
wbedient
MoTard
wbedient's Avatar
Oddometer: 1,292
The oil temp guage... is it needed, or is it more of a curiosity thing?
I mean, if oil temperature was something we had to worry about wouldn't honda have put on one there?
Not trying to start trouble, just an honest question.
2008 KTM 690 Enduro
My Videos: http://www.youtube.com/user/wbedient#g/u
wbedient is offline   Reply With Quote
Old 11-04-2012, 09:27 AM   #48495
ReferJohn
ReferJohn's Avatar
Oddometer: 447
After a 180 mile dual sport ride yesterday, doing 70-75 mph on highway, + 1st and 2nd gear black diamond single track, then a spirted backroads canyon carving run home. leads me to think. # 1 i could have slowed down, took a break and had a beer. # 2 i most likely heated up my oil.
I did buy a 22oz beer,strap it to my manracks rubicon, and enjoy the beer before i dropped into the trail system at cow mtn...
CMA FAST LANE
Times are GMT -7.   It's 09:12 AM.
