11-05-2012, 05:02 PM
#48586 | |
Oddometer: 240
Check your Six 94 XR650L "Hellbitch" |
11-05-2012, 05:13 PM
#48587 |
Wiring diagram is PD. if it hasn't been linked by the time I get to the hotel ill set it up.
11-05-2012, 05:14 PM
#48588 | |
Oddometer: 143
Barron... I'm sending you my email address... PM sent... Thanks |
11-05-2012, 05:15 PM
#48589 |
Oddometer: 240
Ok, Test=switched the wires and both filaments will light separately. The lights solid black wire should go to the bikes green which is ground. The lights Red should go to bikes brown and the lights black/white should go to bikes green/yellow..right?
11-05-2012, 05:19 PM
#48590 |
Oddometer: 143
Awesome! Thanks my6! I'm sure that information will save me a good chunk of time in a few days!
11-05-2012, 07:57 PM
#48591 |
Oddometer: 38
nooB
Hello XR room! First I would like to say, WOW, this forum/thread is amazing. I have literally been reading for about 12 days , unable to put this information stream down, in a futile attempt to get caught up with this saturation of wisdom. The amount of information here and practical experience is, well, as they say in an ad, PRICELESS! Anywho... I am a long time rider, mx back in the day and mostly street for the last years, and am now in the possession an 07 XR650L bone stock with 385 miles. Be gentle, my first dual sport.
, (Smilies, how fun) I have assimilated, ingested, osmoticly ( it could be a word) as much information as my inferior human pyramidal cells can electrically handle, and I am still nowhere near the omnipotent individuals who post /hand down their pearls of wisdom from the mountain. So I humbly put forth my first, of many ignorant, and surely previously answered (somewhere in the depths of the thread) questions into the cistern of collective knowledge. Whew..if I remove the smog equipment only,with XR'S only smog eradication device, will I need to re-jet my new pig, who has yet to be named? She and I are currently residing at base camp 1 roughly 500 feet above sea level in the Southern California portion of the world. Thanks again for ability to reach out to the sea of knowledge that resides here and post such trivial and humble question for the collective to deem as it sees fit. Hope to get a chance in this timeline to meet some of you on the planet for a beverage and some ADV time
11-05-2012, 08:13 PM
#48592 |
Oddometer: 7,989
Badger
Do the de-smog but leave the oil separator. Buy a 55 pilot and a 158 main. Here ya go: http://www.4strokes.com/tech/honda/xrlsmog/ http://www.4strokes.com/tech/honda/xr650lcarbmods/
Steve in SF BMW's 58 R26 79 R100s 91 R100gs 87 Harley FXRS-SP ~ 06 KTM 625 SMC ~ 72 Honda CB750/915cc ~ 92 XR600/654cc ~ 95 XR650l/675cc ~ 03 CRF450r ~ 05 CRF450x ~ 02 XR650l/675cc ~ 86 YZ490 ~ 93 YZ80 ~ 93 XR650l Project |
11-05-2012, 08:22 PM
#48593 |
Behind Bars 4 Life
Oddometer: 198
Steve, what if my used "L" did not have the oil seperator...
![]() what could happen, and what should i look out for. Thanks John BTW Welcome to the asylum BADGER
'01 XR650L '06 NPS50 '12 FLTRU |
11-05-2012, 08:30 PM
#48594 | |
Oddometer: 1,083
11-05-2012, 08:33 PM
#48595 | |
Oddometer: 2,951
![]() Spud
2005 XR650L: Shorai Battery Relocation, Spud Oil Cooler, XR650R C/S Sprocket, Reinforced Subframe, Chain Slipper Roller, Performance Design Lowering Link, Baja Designs Headlight, FMF Hi-Flo Header, ManRacks SD Rack, CST Surge I Front Tire, D952 Rear Tire, Tusk D-Flex Handguards, Uni Air Filter, No-Toil Evolution air filter oil |
11-05-2012, 08:38 PM
#48596 | ||
Pig Wrangler
Oddometer: 1,569
The PO got rid of the separator as part of the smog gear. Same douchebag that welded the countersprocket on the shaft
11-05-2012, 08:40 PM
#48597 | |
Oddometer: 1,083
11-05-2012, 08:44 PM
#48598 | |
Oddometer: 2,951
![]() ![]() Don't use just any snake oil! Use Eastern Timber Rattlesnake Oil! ![]() Unfortunately, the cost of collecting, handling, and harvesting these serpents has became prohibitive, so I switched to 15W/40 motor oil. The commercial, diesel motor oil is doing an excellent job for me, so I intend to keep using it. ![]() Spud
11-05-2012, 09:04 PM
#48599 |
Oddometer: 7,989
Without the separator the oil mist from the engine case will accumulate in the air box and eventually make a mess and drain out onto the floor/ground. I leave mine on because Mr HONDA designed it that way.
So some smuck comes along and calls it a charcoal canister (previous de-smog threads) and everyone thinks the bike will run better without it. Go figure. It's just doing it's job.
11-05-2012, 09:16 PM
#48600 | ||
Oddometer: 2,951
I prefer No-Toil Evolution Filter Oil over petroleum based filter oils for the following reasons. 1) Cleaning the No-Toil filter oil is very quick and easy. Make a solution consisting of 2 ounces of No-Toil Cleaner/Oxi-Clean in a gallon of warm water, and agitate the air filter in the solution. In two minutes the air filter is completely clean, and so are you hands. If you wish, you can clean your air filters in the kitchen sink. 2) Cleaning the No-Toil filter oil is also non-toxic. You don't need to use any harsh solvents, and you can pour the dirty water down the sink, commode, bathtub, or pour it out on the ground. 3) Cleaning the No-Toil filter oil is also inexpensive. If you use Oxi-Clean/sodium percarbonate, you can clean your air filter for 16 cents, or less. 4) Oiling an air filter with No-Toil Evolution is much easier than oiling an air filter with a petroleum filter oil. The water based, Evolution filter oil quickly distributes into the foam, and the excess oil is easily squeezed out of the filter, with very little waste. You can oil your air filter in your motel room, and you can easily clean your hands using the technique I stated above, without any need for smelly, harsh, inflammable solvents. 5) The No-Toil filter oil is very tacky, and stops all the dirt. However, No-Toil is less "goopy" than petroleum filter oils. Therefore, I get better air flow through my Uni air filters since I switched to No-Toil Evolution Filter Oil. 6) Since oiling the air filters, cleaning your hands, and cleaning the air filters is so easy, convenient, and inexpensive, I no longer dread the job. Therefore, I clean my air filters more frequently, and my engine performs better because of it. ![]() However, be forewarned, the water based, Evolution filter oil takes longer to dry than the red, No-Toil filter oil. Alcohol evaporates much faster than water, so you need to wait longer for the Evolution filter oil to become tacky. ![]() Spud
2005 XR650L: Shorai Battery Relocation, Spud Oil Cooler, XR650R C/S Sprocket, Reinforced Subframe, Chain Slipper Roller, Performance Design Lowering Link, Baja Designs Headlight, FMF Hi-Flo Header, ManRacks SD Rack, CST Surge I Front Tire, D952 Rear Tire, Tusk D-Flex Handguards, Uni Air Filter, No-Toil Evolution air filter oil Spud Rider screwed with this post 11-05-2012 at 09:23 PM |
