Old 11-26-2012, 08:43 PM   #49411
flatfender
flatfender's Avatar
Oddometer: 769
Originally Posted by beechum1 View Post
Rear hub you can make a sleeve OD 20mm and ID 17. With interference fit.
Is that all that's needed? Do the rotors have the same bolt pattern? I found a page once that had all XR250-400-600-650 wheel interchangeablity. Wish I would have saved that.
1998 XR650L Dualsport
flatfender is offline   Reply With Quote
Old 11-26-2012, 08:50 PM   #49412
flatfender
flatfender's Avatar
Oddometer: 769
Originally Posted by Drunk_Uncle View Post
Sweet that page is now in my favorites to try myself.
Those lights are 500 lumens each and only use 4 watts, and dirt cheap. Deal
Old 11-26-2012, 09:09 PM   #49413
super samurai
super samurai's Avatar
Oddometer: 303
able to tell me more about your muffler, i see it has a turn downed tip.
is the end still in it?
i know my clear tank is ugly!
super samurai is online now   Reply With Quote
Old 11-26-2012, 09:18 PM   #49414
flatfender
flatfender's Avatar
Oddometer: 769
Originally Posted by super samurai View Post
flatfender, tell me more about your muffler? i see a down turned tail pipe, what is its size and did you remove the baffle from the end?
i picked up a second exhast to cut open and modify as the cycle wizard did/ wont reveal any more of these tricks, which i can understand but still gonna try it.
is it change the tone or quiet it at all? thanks
I bought a stock XR600R muffler after my Cobra exhaust broke in half. Then I found a Thumper Racing XR650L Baffle at a bike shop but I didn't have my bike with me, when I got home I found out they're not the same baffle....oops. Here's the TR and stock 600R baffle
Rather than buying an XR-L muffler I bored out the stock 600R baffle with directions from Kubiak
That sounded pretty good but then found a brand new XR-L muffler on ebay so I could use my TR baffle.
Then I picked up a used WB E-series muffler
I really can't tell the performance difference between the stock muffler with TR baffle, the 600R muffler with a bored out baffle and the WB E-series muffler, and the tone and loudness are about the same too. All are much better than a stoock XR-L/XR600 muffler/baffle for sure. HTH
Old 11-26-2012, 09:40 PM   #49415
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 1,606
Originally Posted by award900 View Post
Scored a pair of Excels on Craigs for 150! Nope, didnt even try to talk him down. They are off of a 650r. Sorry I know this has been covered before but, what do I need to do to mount these things?
Sent from my LG-P999 using Tapatalk 2
The easiest way to mount them is to get an XR650R. They will bolt up directly.
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is online now   Reply With Quote
Old 11-26-2012, 09:40 PM   #49416
Brown Falcon
Mossy-Back
Brown Falcon's Avatar
Oddometer: 745
I like my 600R muffler with the bored out insert. Sounds better than stock but still quiet. I really like the bark of it with the silencer removed, but it's too loud for longer rides. I want to make a turn-down for it to see if it would deflect the sound enough for my taste though.
I looked for one of those Thumper Racing inserts for the 600R muffler, but no luck...
Just curious, what's the inner diameter on that Thumper Racing insert?
Evan
Ooh-Rah! Once a Marine, always a Marine!
'93 XR650L (Xena)
Brown Falcon is offline   Reply With Quote
Old 11-26-2012, 11:58 PM   #49417
GlockPointer
NachosRiflesAlchohol
GlockPointer's Avatar
Oddometer: 323
Originally Posted by 3girlsdad View Post
i think glockpointer is talking about these... you can find them by searching "xr650l handguards" this one in particular is item # 380494508684.
Yup,they's the ones. Does what it says.
'03 SuperHawk 996, SP Engineering exhaust, Zero Gravity, Helibars, Eastern Beaver, Continental
09 XRL, Clarke 4.7, K&N, Dynojet, Yoshi RS2, Manrack, D2Moto pegs, Frazes Mod
'82 NightHawk 450, '71 CB350, '74 CL200, '82 CT110, '75 XL175
GlockPointer is offline   Reply With Quote
Old 11-27-2012, 12:48 AM   #49418
Motor2of7
Oddometer: 67
Originally Posted by flyingwombat View Post
Pretty sweet. Does it add much inertia to the steering?
Just got home from the ride. 586 riders, saw 1 guy got air lifted out and came across another with a possible concussion. The terrain this year seemed to have more sandy sections than last year. I suck at riding in the sand and as others have pointed out the XRL can be a hand full when the front end has a mind of its own. Airing down the front isnt really an option on this ride because one minute you're in foot deep sand and the next minute you're doing 30 over a boulder strewn road with washouts. Overall it's always a good ride and getting to spend some time in Vegas is a great way to recover.
The new instruments worked great. The Voyager GPS was a life saver on many occasions. We finished day 1 in the dark and the trail markers were hard to see. The GPS provided reassurance that we were on the right track. The ride organizers emphasize that a GPS can't replace a roll chart because the roll chart has other important information. I agree, and we primarily followed the roll chart and used the GPS as reassurance.
I rode out to Palmdale from the South Bay (south of Los Angeles) at 4:00 AM and the extra wind screen I fabricated offered great protection and then stowed behind the fairing for the ride.
The roll chart holder was a big improvement over the plastic one I had last year.
The fairing and instruments didn't affect handling at all, even at freeway speeds, and the extra height of the fairing didn't obstruct my view if the trail.
Overall it was a great addition to the bike. I will add a separate (and bigger) odometer. I found that I really needed to see the map and odometer at the same time. When the Voyager is on the map screen you can't see the odometer, which means I had to use the odometer on the stock speedo, which worked fine but the stock odometer is down low and the whole reason I did this mod was to bring the critical info up higher in the line of sight. I'll probably add an IMO odo soon.
Here's a pic showing the fairing on the bike. As soon as I get my bike back from my buddy who trailered it home I'll take a few more pics if anyone is interested.
If the people lead the leaders will follow.
Once the pin is pulled, Mr. Handgrenade is not our friend.
Motor2of7 is offline   Reply With Quote
Old 11-27-2012, 05:42 AM   #49419
XR650L
XR650L's Avatar
Oddometer: 208
Country Side
Just a picture of the road leading down to Algeria in the Cedar Mountains
https://picasaweb.google.com/lh/phot...eat=directlink
Rum is the bad boy of booze. The pirates of the Caribbean weren't drinking vodka. The British navy wasn't run on "amaretto, sodomy and the lash." The smugglers who risked death to bring in illegal alcohol to the thirsty citizens of the U.S. during Prohibition weren't called "spritzer runners."
XR650L screwed with this post 11-27-2012 at 05:49 AM
XR650L is offline   Reply With Quote
Old 11-27-2012, 05:43 AM   #49420
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 726
Cool2
As of right now the $30.00 sale on the 1 3/8"Easton EXP handlebar kit with adapters/risers is still going on.
Get them while you can. Bar selection is getting limited...
http://www.motosport.com/dirtbike/ea...s-and-controls
A big thanks goes to "3girlsdad" for the tip.
Praise the Lord!!! I have seen the light!!! He has shown me the promised land!!! TT for now...
MentalGuru is offline   Reply With Quote
Old 11-27-2012, 06:16 AM   #49421
beechum1
beechum1's Avatar
Oddometer: 4,933
Send a message via AIM to beechum1 Send a message via MSN to beechum1 Send a message via Yahoo to beechum1
Hmmm probably not. I bet theres something different enough to piss you off.
www.bajastarz.com \\\ 94 XR650L, 85 GL1200A
Rally Moto Kit /// Vendor Thread
Old 11-27-2012, 09:05 AM   #49422
purpledrake
No Pretensions
Oddometer: 293
Jaco, you are in Algeria now?? Wow, what an epic ride from S.A. How did you get there? Did you publish a ride report?
The Good Lord gave most of us 10 digits; mine are all thumbs.
purpledrake is offline   Reply With Quote
Old 11-27-2012, 09:43 AM   #49423
xr400r
xr400r's Avatar
Oddometer: 2,435
That is exactly the fairing I want! Where do I get one, who makes it?
xr400r is offline   Reply With Quote
Old 11-27-2012, 09:54 AM   #49424
Ben99r1
Ben99r1's Avatar
Oddometer: 2,804
I would like to see more pics of your bike and the LAB2V ride. I did that ride 3 years ago on my L. That year it was a lot of sand also. My bike handle it pretty good. But I have my bike set up a little different that yours. I have a fork brace, springs to my weight and a scott's damper. I set it up just for the sand, stiff in the front and loose in the rear. I know its not going to handle the sand as good as mx bike. But it could do it without beating you up to bad.
Ben99r1 is offline   Reply With Quote
Old 11-27-2012, 09:55 AM   #49425
purpledrake
No Pretensions
Oddometer: 293
Originally Posted by Walterxr650l View Post
What size fuse are you using? A 5A should be enough, but I wouldn't be afraid to run between a 7 and 10A. Otherwise you have an intermittent short. Are you sure you have the harness hooked to the battery correctly. The center connection in the plug should be the positive connection. If the outer connection is positive anytime the plug bumps the frame you will blow a fuse, Or you have a bit of bare wire someplace that is shorting to ground when the harness gets twisted just right.
Walter
Thanks, Walter,
I will wait for the temperature to rise above freezing, and go check! (Why do I always do this in the winter...) It sounds to me like a short somewhere. Great advice.
PD
Times are GMT -7.   It's 06:54 AM.
