12-28-2012, 02:10 PM
#50686 | |
Oddometer: 3,436
2009 XR650L Steve |
12-28-2012, 02:50 PM
#50687 | ||
Pig Wrangler
Oddometer: 1,569
![]() The relay is bolted to the number plate mounting hole on the front of my top USD triple. ![]() The flasher is ziptied into the rats nest of wires behind the headlight. I plan to rethink the dash this winter. I want to incorporate a cigarette lighter power outlet and get my indicator lights back in play.
12-28-2012, 02:54 PM
#50688 | ||
Pig Wrangler
Oddometer: 1,569
![]() http://blazer-international.com/Prod...hires/FL33.jpg I connected a hot wire directly to the hot side of the battery to a 20 amp inline fuse. http://www.autozone.com/autozone/acc...ier=32415_0_0_ I have my battery under my seat. The fuse block is ziptied to the frame rail... easy access by pulling off the number plate. The hot wire from the fuse runs to the 30 terminal on the relay. The 85 terminal goes to the green wire that fed the dash light. The 86 terminal goes to the black dash light wire. the 87 terminal wire goes to the heater. The other heater wire goes to a ground.
ThumpnRed screwed with this post 12-28-2012 at 03:00 PM |
12-28-2012, 02:58 PM
#50689 |
Mossy-Back
Oddometer: 709
Got my bike partially torn down and oil drained today.
First thing tomorrow morning my buddy is bringing his XRL over to my place (on a trailer) and we're going to adjust valves on both bikes, and then put in my new clutch, put on my fork skins, and tweak my suspension a bit. Any advice for removing the right side engine cover? Does the brake lever need to come off?
Evan Ooh-Rah! Once a Marine, always a Marine! '93 XR650L (Xena) |
12-28-2012, 03:01 PM
#50690 | ||
Pig Wrangler
Oddometer: 1,569
12-28-2012, 03:07 PM
#50691 | ||
Pig Wrangler
Oddometer: 1,569
http://www.dremel.com/en-us/Attachme...spx?pid=225-01
12-28-2012, 04:09 PM
#50692 | |
Oddometer: 2,951
![]() P.S. Have fun with the cotter pins. ![]() Spud
2005 XR650L: Shorai Battery Relocation, Spud Oil Cooler, XR650R C/S Sprocket, Reinforced Subframe, Chain Slipper Roller, Performance Design Lowering Link, Baja Designs Headlight, FMF Hi-Flo Header, ManRacks SD Rack, CST Surge I Front Tire, D952 Rear Tire, Tusk D-Flex Handguards, Uni Air Filter, No-Toil Evolution air filter oil |
12-28-2012, 04:20 PM
#50693 | |
Oddometer: 7,989
When having to remove the clutch cover I leave the pedal in place but I remove both the brake pedal and brake light switch springs along with the master cylinder bolts. This way you can depress the pedal to get the clearance you need to remove the clutch cover. Am I going to tell all of you guys ALL of my secrets ???
Steve in SF BMW's 58 R26 79 R100s 91 R100gs 87 Harley FXRS-SP ~ 06 KTM 625 SMC ~ 72 Honda CB750/915cc ~ 92 XR600/654cc ~ 95 XR650l/675cc ~ 03 CRF450r ~ 05 CRF450x ~ 02 XR650l/675cc ~ 86 YZ490 ~ 93 YZ80 ~ 93 XR650l Project |
12-28-2012, 04:24 PM
#50694 | |
Oddometer: 2,951
Do you remember approximately how much it cost?Spud
12-28-2012, 04:43 PM
#50695 | |
Pig Wrangler
Oddometer: 1,569
I dont... I bought it several years ago when I was fighting with my blinkers. I ended up with several different flashers. I think any turn signal flasher would work.
12-28-2012, 04:52 PM
#50696 | |
Mossy-Back
Oddometer: 709
12-28-2012, 04:58 PM
#50697 | |
Fly high, go far.
Clint >>> 2007 XR650L <<< ---------------------------------- Good government is no substitute for self-government. Mahatma Gandhi That government is best which governs least, because its people discipline themselves. - Thomas Jefferson |
12-28-2012, 05:43 PM
#50698 | |
Oddometer: 2,951
http://www.napaonline.com/Catalog/Ca...D12_0335211065 ![]() ![]() I analyzed the DPCO switch cirucuit, with the help of an electrical engineer. The Tusk Heated Grip Kit consumes about 9.0 watts per grip on low setting, with the resistor consuming about 7.2 watts. The high setting consumes about 17.8 watts per grip. Therefore, the low setting generates about 1/2 the heat of the high setting, and wastes 7.2 watts from the resistor. The DPCO switch circuit consumes about 4.42 watts per grip on the low setting, which is about 1/2 the heat generated by the Tusk setup on low heat, and 1/4 the heat generated by the high setting. Therefore, I won't be using the DPCO switch. I think I am going to follow your example, and install an electronic relay. The LED dimmer is very nice, and inexpensive; however, it's just too large for me. ![]() Spud
2005 XR650L: Shorai Battery Relocation, Spud Oil Cooler, XR650R C/S Sprocket, Reinforced Subframe, Chain Slipper Roller, Performance Design Lowering Link, Baja Designs Headlight, FMF Hi-Flo Header, ManRacks SD Rack, CST Surge I Front Tire, D952 Rear Tire, Tusk D-Flex Handguards, Uni Air Filter, No-Toil Evolution air filter oil Spud Rider screwed with this post 12-28-2012 at 08:43 PM |
12-28-2012, 06:19 PM
#50699 | |
Pig Wrangler
Oddometer: 1,569
I'm not sure I understand your question. I'll do my best to answer what I think you are asking. If I am way off... let me know. The power to the heater runs through the relay. The relay is also wired to the dash light wire which is only hot when the key is on. If the key is not on, there is no juice flowing to the grip heaters.
12-28-2012, 07:02 PM
#50700 | |
Oddometer: 7,989
You may have to remove the mid pipe bolt to have enough movement for the clutch cover to come off. Remove the top banjo bolt and the pipe will be plenty loose. Be sure to keep track of the copper crush washers and which banjo bolt goes where. IIRC the black banjo bolt is on the bottom. It has a larger hole/passageway.
