01-16-2013, 01:46 PM
#51736 | |
Oddometer: 641
......although I have to admit, you're right on both counts I still hope there's another advantage or 2 tho
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack |
01-16-2013, 01:53 PM
#51737 |
CDI REPAIR
Oddometer: 3,312
01 XR650L,102mm JE 11.25:1 ..NX650 second gear,FMX650 fifth gear,ported CW head,KW valve train,MegaCycle 173X25.Cycra probend CRM,Scott`s sharkfin,Xr`s Only casesaver.FMF "Q2",Sutton Oil Cooler,Clarke 4.0,Red XR`s Only skidplate,Doubletake mirrors,Manracks Rotopax rack..one Minature Schnauzer
01-16-2013, 01:54 PM
#51738 | |
Oddometer: 641
What else you wanna talk about....women? Politics? The world economy? I actually like our little escape here.......and I even like talking about tires, gas tanks, oil, bike mods, and especially the ride pics Helps tide me over through are typically brutally unridable winters
01-16-2013, 02:11 PM
#51739 | |
Oddometer: 641
![]() Marko's pics were also from an 08......hmmm I figured the headers would be robot welded to save time, but they must be hand welded to be so inconsistent
01-16-2013, 02:38 PM
#51740 |
Oddometer: 2,800
[QUOTE=bwalsh;20498195]I'll keep the switch on the lowest setting during the winter when not in use and still have the relay so it wont draw current when the key is off. Come late spring I'll turn it off. Two cycles a year should make it last awhile...I hope!
I am electrically challenged myself and I got it done thanks to ThumpnRed! ![]() I still ran the wire(with fuse) from the battery to the relay. The relay has four pins, 1: hot from the battery 2: hot from a wire that is electrified (I ran this wire form the Speedo light wire) 3: a ground( I ran this from the biggest green wire in the dash. I can't remember what it went to. Just check it with a test light to make sure you have the right polarity.) 4: hot out to the grips The package the relay came in had a diagram showing which pin was what. You can still use a relay and keep the resistor. The tusk kit come with part a relay or resistor? What other part do I need get to wire it just like you did? I already have a inline fuse that I can use. |
01-16-2013, 02:49 PM
#51741 | |
Enjoying my last V8
Oddometer: 5,301
Regards Fritzcoinc 96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT, 86 Husky 400 XCE, 03 Harley Road King Police, 00 Husky Te 610 e, 1999 Husky TC610 SM, |
01-16-2013, 02:51 PM
#51742 | |
Mossy-Back
Oddometer: 706
[QUOTE=Ben99r1;20502191]
Evan Ooh-Rah! Once a Marine, always a Marine! '93 XR650L (Xena) |
01-16-2013, 03:09 PM
#51743 | |
Oddometer: 641
Originally Posted by Sierra Thumper
I noticed that the way the airbox is designed, the top right side slopes down some to allow air in under the seat, I believe thats the main source of air for the airbox. Quote:
Thats why even Dave noticed an improvement with just drilling some holes.....every litttle bit helps with the xrl's set-up If you look close with the side covers off and the seat on the bike, you can see that that rib is actually part of the airbox noise reduction/sealing system. It seals the front of the airbox top off....I'm guessing to keep noise down and water out. The seats a tough sob, I highly doubt that little fin has anything to do with holding the seat together, it has tons of support all over. Too many guys have completely removed it without issues for it to be anything structurally important to the seat.....I think its more important to meeting sound regs.....and maybe some water protection ![]() I left it alone because I wanted a bigger airflow increase than removing it was going to give me Unfortunately the front top of the airbox is filled with the wiring loom, so removing that rib would still have a limited effect on more air flow. Honda really capped the airbox off well Thank you EPA ![]() You know the U.S. ZX-10 is down by about 22hp strictly because of the EPA (easily corrected with an ecu reflash and some other basic derestricting tricks tho)....the cbr1000 is down well over 10....R1 about the same, and it just goes on. And look at how nuetered the xr650r was stock....it gained 10-12hp with some simple derestricting/opening up the airbox....thats HUGE on a single that was only rated at 45hp at the crank stock ![]() I'm SO glad I never leave anything stock
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack Sierra Thumper screwed with this post 01-16-2013 at 03:14 PM |
01-16-2013, 04:30 PM
#51744 |
Oddometer: 240
Fritz....You sir, have good taste.
Check your Six 94 XR650L "Hellbitch" |
01-16-2013, 05:26 PM
#51745 |
Must / takeit / easy
Location: Harrisonboiig; Shenandoah Valley riding wonderland
Oddometer: 4,390
Sure, you can use the Dremel. You should take your time with the Dremel though - don't work it too hard or you'll get it too hot inside and burn it up. It's strong enough if you take your time. The air drill will be faster and able to take a larger wheel wiht which it is easier to get a smooth job.
Let's ride!!! ![]() - No offense, but there've been a lot of people over time who were just as sure, but got it wrong. - Una necedad, aunque la repitan millones de bocas, no deja de ser una necedad. |
01-16-2013, 05:29 PM
#51746 |
Oddometer: 4,390
01-16-2013, 05:55 PM
#51747 | |
Oddometer: 4,390
Steve? Have you investigated this in detail? Your determination?
01-16-2013, 05:57 PM
#51748 | |
Oddometer: 7,714
![]() I'll take door(pic) number one please!
2004 XR650L 1992 Specialized Stump Jumper FS NWVA TAG NWVA TAG MAP RTE THREAD & IN LIST |
01-16-2013, 06:04 PM
#51749 | ||
Pig Wrangler
Oddometer: 1,566
I HATE cold weather... Good gawd... no politics! If someone starts up about gun control or health care reform The mangina gets sore when I cant ride... Too cold in the garage to even work on the bike
01-16-2013, 06:08 PM
#51750 | ||
Oddometer: 7,714
[QUOTE=Brown Falcon;20502293]
What about this... ![]() ![]() 2013 Honda CRF450 Rally Quote:
http://motorcycles.about.com/b/2012/...rally-bike.htm http://www.motorcyclistonline.com/fi..._crf450_rally/ I wonder if you could slap a dual sport kit on that puppy from the dealer and ? One of those and a Giant loop bag and you'd be good to go...anywhere! Did I miss the discussion about this or are all you FF's slacking? I'd damn near give my right arm and left testicle for that bike!
