01-19-2013, 07:38 PM
#51961 |
Oddometer: 1,039
"How much a dunce That has been set to roam Excels a dunce That has stayed at home." |
01-19-2013, 09:00 PM
#51962 | |
Oddometer: 7,801
I posted the answer after the first time you asked. Here it is again.
Front Royal Va. Quote:
2004 XR650L 1992 Specialized Stump Jumper FS NWVA TAG NWVA TAG MAP RTE THREAD & IN LIST bwalsh screwed with this post 01-19-2013 at 09:10 PM |
01-19-2013, 09:06 PM
#51963 | |
Oddometer: 7,801
![]() From here... http://www.4strokes.com/tech/honda/xr650lcarbmods/ The reason I said to check is some folks buy the Dyna jet kit and just replace jets, sometimes the wrong size jets, and don't do anything else. You know the old saying, "if you want something done right, you have to do it yourself". It applies here too.
2004 XR650L 1992 Specialized Stump Jumper FS NWVA TAG NWVA TAG MAP RTE THREAD & IN LIST |
01-19-2013, 09:14 PM
#51964 | |
Oddometer: 641
Plus the pigtails can also run other accessories....like a tiny 12 volt tire pump like the one that came in my slime kit I have tenders and pigtails on all my bikes, and carry the slime kit in my backpack with tire plugs and slime for both tube and tubeless tire repairs ![]() You can also plug cigarette style outlets into them for charging/running devices like gps, phones etc. The Schumacher style tenders come with a nice thick gauge wire too
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack |
#51965 |
Oddometer: 441
Igor: Dr. Frankenstein...
Dr. Frederick Frankenstein: "Fronkensteen." Igor: You're putting me on. Dr. Frederick Frankenstein: No, it's pronounced "Fronkensteen." Igor: Do you also say "Froaderick"? Dr. Frederick Frankenstein: No... "Frederick." Igor: Well, why isn't it "Froaderick Fronkensteen"? Dr. Frederick Frankenstein: It isn't; it's "Frederick Fronkensteen." Igor: I see. Dr. Frederick Frankenstein: You must be Igor. [He pronounces it ee-gor] Igor: No, it's pronounced "eye-gor." Dr. Frederick Frankenstein: But they told me it was "ee-gor." Igor: Well, they were wrong then, weren't they? on a different note, I put on my Stealth fuel mixture screw on my FCR today...a word of advice don't think your going to save any time by trying to put it on without pulling the seat,side covers,tank,carb...DAMHIK
2007 XR650L, Looking to acquire a stock XRL choke plunger. |
01-19-2013, 09:33 PM
#51966 | |
Mossy-Back
Oddometer: 746
Evan Ooh-Rah! Once a Marine, always a Marine! '93 XR650L (Xena) |
01-19-2013, 09:43 PM
#51967 | ||
Oddometer: 3,000
![]() After removing the stock chain slipper, I found it easiest to remove the left foot peg before I drilled the mounting hole to enlarge it to 5/16-inch. I also discovered I had much more room to install the front chain roller after I removed both the sprocket cover, and the shift lever. I placed a ¼-inch washer on the supplied bolt, and shoved the bolt through the chain roller from the engine side of the frame. I then added 4, ¼-inch washers to space the roller evenly under the chain. Adding another ¼-inch washer on the outside of the frame, I attached the supplied, nyloc nut. ![]() ![]() ![]() After I switched to the wider, XR650R C/S sprocket, I removed one of the washers between the frame tab and the chain roller; I now have 3 washers in that position. ![]() Spud
2005 XR650L: Shorai Battery Relocation, Spud Oil Cooler, XR650R C/S Sprocket, Reinforced Subframe, Chain Slipper Roller, Performance Design Lowering Link, Baja Designs Headlight, FMF Hi-Flo Header, ManRacks SD Rack, CST Surge I Front Tire, D952 Rear Tire, Tusk D-Flex Handguards, Uni Air Filter, No-Toil Evolution air filter oil |
01-20-2013, 01:47 AM
#51968 | |
Oddometer: 51
01-20-2013, 02:03 AM
#51969 | |
M0DAH0LIC
Oddometer: 1,953
-Barron
1996 XR650L with a couple mods If everyone brewed beer there would be no war. ![]()
01-20-2013, 02:26 AM
#51970 |
Oddometer: 51
Still isn't mine but here are pics from his ad.
![]() ![]() ![]() ![]() ![]() ![]() The only thing cosmetic I don't care for is the tail light, I plan to swap it for an LED light strip under the fender lip. Otherwise from the pics it looks great, love the MX rear fender. I plan to go look at it in person this tuesday and may well be bringing it home. |
01-20-2013, 02:42 AM
#51971 | |
M0DAH0LIC
Oddometer: 1,953
I'd ask him about maintenance(mainly how often he changes the oil and ask him to show you the bolts to drain it, if he doesn't know that is a bad sign) and any internal engine mods. If you hear the words "hot cam" proceed with caution! If you plan on putting turn signals and a tail light on there you might want to look at what he did with the wiring... -Barron
01-20-2013, 06:20 AM
#51972 |
Oddometer: 45
cush drive
Hey everyone so Im trying to get a cush drive for my xr and was wondering if anyone has done this? does anyone know if a dr60 wheel will match up or would it be to wide?
09 XR650L |
01-20-2013, 06:34 AM
#51973 | |
Oddometer: 247
Check your Six 94 XR650L "Hellbitch" |
01-20-2013, 07:40 AM
#51974 | |
Oddometer: 7,801
Oh, I was assuming it was the stock carb. Don't know nothin bout no pumper carbs.
01-20-2013, 07:52 AM
#51975 | |
Feral Chia tamer
Oddometer: 2,607
![]() If you look closely there is a lic. plate hanger on the tail edge of the fender. WMD doesn't know it yet, but we'll be trading bikes when we hit the trail. ![]()
Mutt'n the custard. On the outside with my back turned. |
