Old 01-21-2013, 09:43 PM   #52096
Mossy-Back
Wet-Sider
Mossy-Back's Avatar
Oddometer: 1,646
Originally Posted by beechum1 View Post
think cutoff blues trow C shirt and shirt stays and an ass that won't quit.
HAHAHA! If I had an extra set of blues trousers I could make that happen! Still have all my uniforms, and even some shirt stays! Don't temp me. You'd all go blind, or wish you were blind!
'05 CRF450X
Once a Marine, always a Marine!
Mossy-Back is offline   Reply With Quote
Old 01-21-2013, 09:52 PM   #52097
RZRob
RZRob's Avatar
Oddometer: 1,667
Originally Posted by Brown Falcon View Post
Do they come with leads that I'd be able to leave hooked up to the bike all the time?
Yes sir. They're the leader in bike chargers.
RZ Rob
RZRob is offline   Reply With Quote
Old 01-21-2013, 10:19 PM   #52098
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,434
I've got my pic around here somewhere. NSFW.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 01-21-2013, 10:34 PM   #52099
Haywood
Haywood's Avatar
Oddometer: 401
Originally Posted by elsalvadorklr View Post
have you been running rich for a long time? carbon buildup?
It's possible. The last time I experienced this I did bump up the main a size or two. If it's running rich wouldn't there be some black soot buildup at the exhaust tip? There isn't. It's as clean as could be. I haven't checked the plug for a while. With the Acerbis 5.8 and the Sutton oil cooler lines, it makes the plug a lot harder to get to.
Originally Posted by mcma111 View Post
Haywood,
Pull the carb intake boot and check for cracks.
Will do. It will give me a chance to check the jet sizes. I need to start writing these things down.
Haywood is offline   Reply With Quote
Old 01-22-2013, 12:23 AM   #52100
Birdmove
Birdmove's Avatar
Oddometer: 1,768
Geez, I'da thunk guys mean enough to ride an XR650L would shoot a real rifle, like my Uberti Remington Rolling Block in 45-70. How about a 500 grain bullet??
Jon in Keaau, Hi. USA
2008 SYM HD200 (wife's ride)
2009 Kymco People 150 and coming soon, another dual sport mc
Birdmove is offline   Reply With Quote
Old 01-22-2013, 01:12 AM   #52101
pngaudioguy
Just...one...more...
pngaudioguy's Avatar
Oddometer: 510
Muffler
Thanks for all the advice that seems to all point in only one direction as to what I should do with the old Supertrapp. Since I've got it sitting here anyway, I may attack it a little longer before throwing in the towel, and just keep my eyes open for something else.
pngaudioguy is online now   Reply With Quote
Old 01-22-2013, 02:49 AM   #52102
Lost on Row 1
Lost on Row 1's Avatar
Oddometer: 246
One other thing I've been meaning to ask. With stock suspension, what are good settings to run on the forks (bottom of tube) and the adjustables on the rear shock? I'm 145 pounds, so probably 160 or so with gear on.
Right now the front is 2 clicks counter-clockwise from stop, the adjuster under the left side cover is 8 clicks counter-clockwise from stop, and I haven't messed with the adjuster on the bottom of the shock.
Just looking for good settings to start from. Commuting and moderate trail riding, but more concerned about suspension good for the trails.
Have you had your shock serviced? It needs to be done every so often. Nitrogen leaks out slowly over time and the factory suspension fluid needed changing 1 year after the bike was sold new. That will be the best suspension improvement you can make with stock components. Then your adjustments will really make more of a difference in the way the bike handles, especially off-road.
1993 XR650L; 14T CS, Dave's carb mod, Modified stk muffler, Airbox Mod, Battery relocation, Bar risers, Uni filter, No passenger pegs(to make it super lite), Blue powerband.
Lost on Row 1 is offline   Reply With Quote
Old 01-22-2013, 04:30 AM   #52103
mcma111
mcma111's Avatar
Oddometer: 12,434
While you have the carb off get a Sharpie and write the jet sizes on the side of the bowl.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-22-2013, 05:04 AM   #52104
taco250
wannabe adventurer
taco250's Avatar
Oddometer: 1,329
My $.02: try clamping the in a vise (or bracing it somehow w/o denting and heat the end that goes into the muffler with a propane torch as hot as you can get it, then start working the muffler back and forth (if it will move). If it does move, then keep working while it's hot until it comes off. The heat will bust loose the rust and burn off carbon build up. Beware, doing this will make tons of nasty smoke so work in a ventilated area.
Prov 3:5 & 6
www.benddualsport.com
300+ mile Paisley OR day ride
taco250 is offline   Reply With Quote
Old 01-22-2013, 05:34 AM   #52105
pngaudioguy
Oddometer: 510
Unfortunately, I have no bench vise or propane torch here. I do have a reasonable 230V heat gun that goes up to 600C! I'll give that a try and hope for the best. I didn't spend much on this can, and have never had it on the bike, so no huge loss if it doesn't work out. Looking at the condition, I just figured it more than likely needed a repack (which I also didn't bother to buy just in case I can't open it.)
Old 01-22-2013, 05:56 AM   #52106
XR650L_Dave
Oddometer: 3,755
Originally Posted by RZRob View Post
Hey guys,
You know those times when an extra inch would come in handy? Or when you're having difficulty finding the hole and before you know it you've made a mess out of everything?
OK, well maybe not, but I was at Harbor Freight today and stumbled upon these little goodies. A pair runs a measly $1.49 and fits your traditional oil bottle neck or the larger size like comes with Mobil 1 for instance. These are small and light enough that one might just be worth packing on the long trips. I like the way they firmly attach to the bottle and nicely fit the fill hole on the XR.
Thought I'd pass this along for any of you guys that need a little help.
RZ Rob
That's pretty cool, I was just at horrid freight getting a transmission jack and would have snagged that if I'd seen it.
Now if it had a trigger and a shutoff right at the tip so I could stop overfilling the reservoir, I'd pay 10 bucks for it.
---->>Thanks for the rotor, guys!<<----
XR650L_Dave is offline   Reply With Quote
Old 01-22-2013, 06:05 AM   #52107
Barron
M0DAH0LIC
Barron's Avatar
Oddometer: 2,460
Me too
1996 XR650L with a couple mods
If everyone brewed beer there would be no war.
Barron is offline   Reply With Quote
Old 01-22-2013, 06:17 AM   #52108
bwalsh
bwalsh's Avatar
Oddometer: 12,021
I don't want to have to take the side panel and battery cover off every day...
Most any bike shop will have a bunch the battery tender leads on the parts counter, especially this time of year.
Sounds like carbon build up to me too. How many miles on the engine?
First thing I'd do is add some Sea Foam and go out and ride it. One tank may clear it up...maybe two.
I was having he same issue with mine last summer and the Sea Foam cleared it up quickly.
2004 XR650L
NWVA TAG NWVA TAG MAP RTE THREAD & IN LIST
bwalsh is offline   Reply With Quote
Old 01-22-2013, 06:28 AM   #52109
Sub Zero
Ice Breather!
Sub Zero's Avatar
Oddometer: 813
Hey guys,
I use something almost identical to this one. you can get em at any auto zone
I notice your using the HP4 oil! good stuff but expensive as shit! I know they make 2 versions one with moly and one without. are you using the one with?? If so I would recommend switching over to the oil without moly. those oil friction additives can ruin your clutch. oil with moly is mainly used in super high performance sport bikes like ducatis etc. sure you know this but i wanna sound smart and inform anyone else that dosnt know.
1994 WR250-Z | 1997 KX500 | 1998 KLX300 | 2004 CRF450R (Motard) | 2009 KX450F | 2001 XR650R | 1992 WR200R | 1992 WR500-Z | 1986 GPZ900 | 2005 RMZ450 | 1986 CR500AF in a 1998 CR250R frame | all street legal
"Great! What am I supposed to use now?! Harsh language?"
- Duke Nukem
Sub Zero is offline   Reply With Quote
Old 01-22-2013, 06:35 AM   #52110
elsalvadorklr
southern xr rider
Oddometer: 4,154
thats my thoughts too...and I second the seafoam to see if it does something...
you can also try the water misting trick but you need a helper for this
ive done it on my boat engines a few times now and it works...
smokes white clouds like hell for a while but in that cloud is all that buildup of carbon bits...
upping the main a size or 2 IS A LOT in my book. Ive learned my lessons on jetting now...one if which is avoid the common mistake of overjetting...too big!
elsalvadorklr is offline   Reply With Quote
Times are GMT -7.   It's 01:16 PM.
