01-22-2013, 06:17 AM
#52111 | ||
Oddometer: 7,715
First thing I'd do is add some Sea Foam and go out and ride it. One tank may clear it up...maybe two. I was having he same issue with mine last summer and the Sea Foam cleared it up quickly.
2004 XR650L 1992 Specialized Stump Jumper FS NWVA TAG NWVA TAG MAP RTE THREAD & IN LIST |
01-22-2013, 06:28 AM
#52112 |
Ice Breather!
Oddometer: 639
I use something almost identical to this one. you can get em at any auto zone
![]() I notice your using the HP4 oil! good stuff but expensive as shit! I know they make 2 versions one with moly and one without. are you using the one with?? If so I would recommend switching over to the oil without moly. those oil friction additives can ruin your clutch. oil with moly is mainly used in super high performance sport bikes like ducatis etc. sure you know this but i wanna sound smart and inform anyone else that dosnt know.
1994 Yamaha WR250-Z 2005 Gas Gas FSE450 "Great! What am I supposed to use now?! Harsh language?!?!?" - Duke Nukem |
01-22-2013, 06:35 AM
#52113 | |
Oddometer: 3,964
you can also try the water misting trick but you need a helper for this ive done it on my boat engines a few times now and it works... smokes white clouds like hell for a while but in that cloud is all that buildup of carbon bits... upping the main a size or 2 IS A LOT in my book. Ive learned my lessons on jetting now...one if which is avoid the common mistake of overjetting...too big! |
01-22-2013, 06:40 AM
#52114 | |
Oddometer: 3,964
so the pinging happened once already at which time you upped the main(have you done dave mods, or no) if so that means that you have responded to a symptom by compensating 3 times with a richer main thats MASSIVE... not all exhaist show soot...supertraps are famous for getting sooty...my powercore 4 has SOME soot, etc... some blow fumes clean out and dont show much... its kind of hard to know if you are rich or lean just by looking at the exhaust...it can help for sure, but seat o pants and a dyno are about the only ways unless you have an af meter hooked up all the time to know if you are good on all circuits... anywhoo good luck I would get a helper after you check for air leaks and all and try to do the misting water intake trick...you need a steady control of the throttle to avoid hydro lock...a helper is paramount while you mist the intake... |
01-22-2013, 06:42 AM
#52115 | |
Enjoying my last V8
Oddometer: 5,306
Regards Fritzcoinc 96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT, 86 Husky 400 XCE, 03 Harley Road King Police, 00 Husky Te 610 e, 1999 Husky TC610 SM, |
01-22-2013, 06:47 AM
#52116 | |
Enjoying my last V8
Oddometer: 5,306
The forks are both set at 3. The rear shock gets 7 and 10.
01-22-2013, 07:05 AM
#52117 |
Oddometer: 661
Oil & Filler
Hey Sub Zero,
The HP4 is just for illustrative purposes. Actually I use GN4 in the XR. That was from my CRF where I use the "With Moly" (silver bottle) for the engine, and the "Without Moly" (gold bottle) for the transmission. As for the filler, I have the same Trans Filler funnel you show, but found the portability and tidiness of the little Horrid Freight interesting. RZ Rob |
01-22-2013, 07:16 AM
#52118 | |
Feral Chia tamer
Oddometer: 2,596
![]() These thread on to your oil jug, only a few dollars, and made in the USA. I bought three when I ran across them. http://www.starbrite.com/productdeta...&ProductSSCat=
Mutt'n the custard. On the outside with my back turned. |
01-22-2013, 08:30 AM
#52119 | |
CDI REPAIR
Oddometer: 3,316
I find my bike hits every bump/rock hard........really jolts you......with fresh oil at spec height..... Then again.i wonder if it`s the cheap crap Kenda 270 front...i don`t think i felt this with the MT21 front or D606....... Love to have my suspension set up properly,,,engines i know.suspension,,,,,,not one helluvalot.. ![]() B
01 XR650L,102mm JE 11.25:1 ..NX650 second gear,FMX650 fifth gear,ported CW head,KW valve train,MegaCycle 173X25.Cycra probend CRM,Scott`s sharkfin,Xr`s Only casesaver.FMF "Q2",Sutton Oil Cooler,Clarke 4.0,Red XR`s Only skidplate,Doubletake mirrors,Manracks Rotopax rack..one Minature Schnauzer
01-22-2013, 09:15 AM
#52120 | |
Oddometer: 79
http://reno.craigslist.org/mcy/3557496520.html |
01-22-2013, 09:35 AM
#52121 | |
Oddometer: 3,076
---->>Thanks for the rotor, guys!<<---- |
01-22-2013, 09:44 AM
#52122 | |
Oddometer: 220
2008 XR650L, tons of goodies. |
01-22-2013, 09:46 AM
#52123 | |
Must / takeit / easy
Location: Harrisonboiig; Shenandoah Valley riding wonderland
Oddometer: 4,390
![]() Good one, Rob!
Let's ride!!! ![]() - No offense, but there've been a lot of people over time who were just as sure, but got it wrong. - Una necedad, aunque la repitan millones de bocas, no deja de ser una necedad. |
01-22-2013, 09:49 AM
#52124 | |
No Pretensions
Oddometer: 277
The Good Lord gave most of us 10 digits; mine are all thumbs. |
01-22-2013, 10:01 AM
#52125 |
Oddometer: 4,390
The biggest thing is the spring tension on the rear shock. It should be set so that when you are on the bike it rests at just under four inches or say 10cm. below fully extended. You can find several examples online of procedures for setting the 'static sag'.
