01-28-2013, 06:08 PM
#52546 | |
Oddometer: 79
Removed wheel bearings and powder coated the entire wheel. |
01-28-2013, 06:20 PM
#52547 | |
Oddometer: 641
, but I'm tired of working on bikes...I want to spend the rest of my life riding them
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack |
01-28-2013, 06:23 PM
#52548 | |
x
Oddometer: 128
Good eye on the brake side it is looking tight, hopefully the information I have seen is correct and it will make it in there. |
01-28-2013, 06:25 PM
#52549 |
Oddometer: 79
My friend Chane is a powder coater and XRL owner. He does nice work.
![]() Chane's wheel. |
01-28-2013, 06:27 PM
#52550 |
TAT'erd
Oddometer: 1,815
![]() The L is running great so I need something to keep me occupied this winter besides work.John
Endeavor to suck less--Gaspipe I would rather be riding an imperfect bike than waiting around for perfection. --JDowns |
01-28-2013, 07:54 PM
#52551 |
Oddometer: 51
Hey XRL guys, got a couple questions now that I've had the maiden voyage on my new '05 6-fiddy.
Question #1, does anyone make lower pegs for the XR's? I remember FastBoy pegs were the answer for my YZ450, but the XR's have that asymetrical peg-hanger frame thing going on. I've got really long legs, see pic below, and need more room for stretch. Even a half inch would help. Question #2. Whats the best twin round headlight source for the XR's. The headlight on mine is next to worthless at night and I always did like the double six inch round light baja look. Thanks much.
WMD screwed with this post 01-28-2013 at 08:04 PM |
#52552 |
Oddometer: 2,364
01-28-2013, 08:04 PM
#52553 | |
Oddometer: 1,025
Right side. ![]() Left side. ![]() HT's top rack is supported in the back by the bikes sub frame. The bikes sub frame is very weak where this attachment is made. I didn't like that system. Any other racks I saw available when I bought my bike, January of 2006, seemed to use the same system. So I made my own, again with the help of a coworker who welds. The back of my top rack is supported off of the back of the HT side racks. You can see part of those support tubes in the pictures above. This is a picture of the rack off of my bike, just after it was powder coated. ![]() This is a close up of it mounted on the bike. ![]() Since adding the side rack braces, I have ridden someplace between 60 and 70,000 miles with no more problems.So I consider my racks to be fixed. The lower brace on each side seems to be the one that did the job. If I was buying the HT racks new now, I would add those braces before I ever installed the racks on my bike. On the other hand Twisted throttle now has a set of racks for the XRL. From what little I can see in their pictures and video, my guess is they will need no modification to hold up to the job. Walter
"How much a dunce That has been set to roam Excels a dunce That has stayed at home." |
01-28-2013, 08:09 PM
#52554 |
Oddometer: 1,446
WMD,
The double headlight is usually Buell Lightning headlights.
"I refuse to tiptoe through life only to arrive safely at death" 2009 Buell XB12X(sold), 2006 Triumph Sprint ST, 2006 Tiger 955i, 01 XR650L replaced by a KLR, and now a 2010 Honda NT700V for the wife. |
01-28-2013, 08:11 PM
#52555 | ||
Pig Wrangler
Oddometer: 1,565
![]() I suspect he was the bastard who stole it several months later... Karma's a bitch!
#52556 |
Oddometer: 51
01-28-2013, 08:17 PM
#52557 |
Oddometer: 750
Baja Designs is what you were referring to the lights. Or trailtech.
01-28-2013, 08:20 PM
#52558 | |
Oddometer: 119
I use pivotpegz. Lower, wider and pivoting for large feet. If you want old school double round, you can go with BAJA DESIGNS dual fuego. |
01-28-2013, 08:30 PM
#52559 | |
frozen dead guy
Oddometer: 619
Yes he does, that's beautiful. |
01-28-2013, 08:46 PM
#52560 | |
frozen dead guy
Oddometer: 619
I am currently refurbishing them because I didn't do a good enough job sealing them up and they got a bit of water inside, which jammed up a high-beam solenoid. They aren't that great in tight corners. I figure I will add a helmet light at some point to fill in the corners. This is low-beam, looking up a hill: Here's more info. But if lack of DOT approval is ok for your use, these are very simple, pretty easy to install, are very durable and don't use much power: ![]() They are also available in a 10-inch version. There is no dimming control yet, to my knowledge. I don't know if they can be safely dimmed either with your own controller. I have one of the 6-inch versions on my XR600R and it lights up the night very well for singletrack riding!! flyingwombat screwed with this post 01-28-2013 at 08:55 PM |
