Old 02-02-2013, 07:58 PM   #53011
ltcole
Herpetologist
ltcole's Avatar
Oddometer: 51
Pictures
Thank you everyone for the excellent pictures showing the dipstick measurements. That helps out a lot, and I am happy to report I have been running it right at the stock full level just by dumb luck.
bwalsh the reason that link probably didn't work was because I ordered that part as soon as that link was posted. I will be happy to have the suspension back to stock....... Major reason, I don't feel like doing all the other adjustments to the suspension with the lowering link installed. I researched this subject quite a bit and saw several reports that if those adjustments weren't made it made the bike handle a little funky.
On another note, I have had my XRL a little over a month now and have officially logged my first 1000 miles. Pretty easy to do out here in NM though, and most of those miles have been slab miles. Along with my daily commute of ~40 miles roudtrip, I also logged another ~150 miles on Friday, with ~40 of those being offroad.
I changed the oil around 600 miles ago, and changed from the honda 10/40W part synthetic to Mobil full synthetic 20/50w. Needless to say, I have run the bike at 75 to 80 mph for at least 15 minutes at a time, and my highest temp has been about 270. Also, I have not "lost" any oil since I did the oil change. My bike really likes to cruise at 70mph, and my temp sits between 250 and 255. It might help that I went to a 40 tooth sprocket and the plug the owners manual recommends for a lot of highway riding. I see between 48 and 52 miles per gallon so far, but that seems to be influenced by how often I roll on the throttle hard (who would have thought?!?!?!?!).
This thread has been a huge help to this new comer, when it stays on subject that is.
Thanks again, happy trails.
LTCOLE
ltcole is offline   Reply With Quote
Old 02-02-2013, 08:11 PM   #53012
KyoXR
KyoXR's Avatar
Oddometer: 402
Apparently these are new hot off the press, (what I have read anyway).
they won't do me any good with my 320mm front rotor...
http://www.maier-mfg.com/catalog/hon...orkdisc-guards
Fork/ Disc guards.
2007 XR650L,
Looking to acquire a stock XRL choke plunger.
KyoXR screwed with this post 02-02-2013 at 10:37 PM
KyoXR is offline   Reply With Quote
Old 02-02-2013, 08:31 PM   #53013
Barron
M0DAH0LIC
Barron's Avatar
Oddometer: 1,943
Originally Posted by ltcole View Post
...It might help that I went to a 40 tooth sprocket...
What size front sprocket do you have? When I went to a 40 tooth rear with a 15 front the bike was sluggish as hell pulling off (my bike was still OEM as far as the engine went then)... it just felt like too much for the bike. I went to a 43 for a while and liked that but got sick of it robbing the ratio from the rest of the gears just for commuting. So I went back to a 45tooth rear with a NX650 5th which handles every bit of legal speed limits with ease and still has the umpf in the first 4 gears... but now that I'm in Japan and the speed limit on most of the roads I I ride on is only 37MPH (50KPH) I'm changing it up again
1. For more "fun" and off-road ability
2. To keep me from speeding every time I shift into 4th gear (I'm still gonna have to watch it though)
-Barron
1996 XR650L with a couple mods
If everyone brewed beer there would be no war.
Barron is offline   Reply With Quote
Old 02-02-2013, 08:56 PM   #53014
ADV BUM
Oddometer: 119
Barron it seems the nx650 5th gear is hard to get here. Do you have a good source to get over there. Also the 2nd gear. I am not sure if you can use the xr600 2nd or have to use the Nx.
ADV BUM is offline   Reply With Quote
Old 02-02-2013, 09:01 PM   #53015
Spud Rider
Spud Rider's Avatar
Oddometer: 2,940
The NX650 second gear is very easy to purchase in the United States. The NX650 was imported into the United States in 1988-1989. The NX650 second gear, part #23421-MN9-010 will close the gap between 1st and 2nd gear in the stock transmission. The NX650 second gear is part #5 in the following diagram.
Spud
2005 XR650L: Shorai Battery Relocation, Spud Oil Cooler, XR650R C/S Sprocket, Reinforced Subframe, Chain Slipper Roller, Performance Design Lowering Link, Baja Designs Headlight, FMF Hi-Flo Header, ManRacks SD Rack, CST Surge I Front Tire, D952 Rear Tire, Tusk D-Flex Handguards, Uni Air Filter, No-Toil Evolution air filter oil
Old 02-02-2013, 09:08 PM   #53016
ADV BUM
Oddometer: 119
Thanks Spud, what about the elusive 5th?
Old 02-02-2013, 09:49 PM   #53017
Spud Rider
Spud Rider's Avatar
Oddometer: 2,940
The FMX650 was never imported into the United States. Therefore, you can only obtain the FMX650 fifth gear from either Europe or Japan. For XR650L owners, replacing the stock fifth gear on the countershaft with the FMX650 fifth gear, part #23491-MW2-780, will increase the gap between 4th and 5th gear in the stock transmission, allowing lower engine rpms in fifth gear. The FMX650 fifth gear is part #16 in the following diagram.
I have heard you can acquire the FMX650 fifth gear from the following website in Japan.
http://www.motobike.jp/
Apparently the vendor above will acquire part #23491-MW2-780, and mail it to your U.S. Postal Service address for a fee of approximately $120.
Spud
Old 02-02-2013, 10:01 PM   #53018
beechum1
beechum1's Avatar
Oddometer: 4,796
Send a message via AIM to beechum1 Send a message via MSN to beechum1 Send a message via Yahoo to beechum1
Has that joe guy quit pissing on the bushes then?
www.bajastarz.com \\\ 94 XR650L, 85 GL1200A
Rally Moto Kit /// Vendor Thread
Old 02-02-2013, 10:57 PM   #53019
Ironman2001
Oddometer: 27
Originally Posted by Brown Falcon View Post
I wish I could afford to do that. Maybe someday. It would sure be nice to have a dedicated set of dirt knobbies and some good sticky street rubbers on separate rims.
A set of 17's with street tires would be awesome to swap on for pavement duty!
I have a 21 front and 18 rear on both sets. I don't have to worry about relocating brake calipers or machining parts to fit.
Ironman2001 is offline   Reply With Quote
Old 02-02-2013, 11:00 PM   #53020
KyoXR
KyoXR's Avatar
Oddometer: 402
I forgot to weigh them minus the stock shields to see how much weight I'm adding.
I'm not sure what was going on with the pain of me installing these but I found I only have mere millimeters between the bar clamps and the tank,
Am I the only one who has tried to put Cycra Pro bends on a XRL with stock bars and a 4.7 Clarke tank? because the shields would hit the tank and I had to trim them.
The other problem I had was the Russel braided front brake line has a funky angle to it and is hitting the brace.
I will probably modify the line stop on the master cylinder so I can rotate the brake line for better clearance...but not today...
on another subject:
out with the old:
in with the new:
So far I like the looks of the Surge-I and I like how it's taller, even though it's a bit more narrow then the Scorpion Pro, I haven't ridden with it yet and I still need to re-calibrate my Vapor because of the added height.
found this during R/R of the front tire:
cracked speedo housing.
2007 XR650L,
KyoXR screwed with this post 02-02-2013 at 11:10 PM
Old 02-02-2013, 11:29 PM   #53021
Spud Rider
Spud Rider's Avatar
Oddometer: 2,940
Originally Posted by KyoXR View Post
...out with the old:
...in with the new:
You're going to like the Surge I, front tire, Kyo. However, don't be surprised if you notice the narrower front tire turns in more quickly than the older, wider tire.
To get maximum mileage from this aggressive tire, I recommend you rotate the tire every 2,000 miles when you change the engine oil. Also, the tire will last much longer if you keep the pressure at 26 psi, at least while riding on pavement.
Spud
Old 02-03-2013, 05:29 AM   #53022
Lost on Row 1
Oddometer: 43
What kind of link do you have? Are you wanting to swap out for a stock link? If so I am interested. Let me know.
Dave
1993 XR650L
Lost on Row 1 is offline   Reply With Quote
Old 02-03-2013, 06:15 AM   #53023
ONandOFF
Must / takeit / easy
ONandOFF's Avatar
Location: Harrisonboiig; Shenandoah Valley riding wonderland
Oddometer: 4,383
Originally Posted by Sierra Thumper View Post
... I am going to check my static sag, the suspension was set up for the po who was quite a bit heavier than me, so I'm prolly not getting the proper sink when I sit on the bike. ...
It's worth checking. Don't forget, the static sag is measured as the vertical difference between the suspension fully extended, and where it rests with you sitting completely on it, feet on pegs. Kinda challenging without a helper. It should be a tad under four inches, or about 10cm. Needn't be perfectly on, just close. And it's possible there's a more optimal number for when you have a particular lowering link on, I don't know. Here's a very thorough description of how to proceed..
Let's ride!!!
- No offense, but there've been a lot of people over time who were just as sure, but got it wrong.
- Una necedad, aunque la repitan millones de bocas, no deja de ser una necedad.
ONandOFF is offline   Reply With Quote
Old 02-03-2013, 06:23 AM   #53024
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 3,310
Originally Posted by bwalsh View Post
What? No Bacon?
I`ll check with the chef.......don`t recall
B
01 XR650L,102mm JE 11.25:1..NX650 second gear,FMX650 fifth gear,ported CW head,KW valve train,MegaCycle 173X25.Cycra probend CRM,Scott`s sharkfin,Xr`s Only casesaver.FMF "Q2",Sutton Oil Cooler,Clarke 4.0,Red XR`s Only skidplate,Doubletake mirrors,Manracks Rotopax rack..one Minature Schnauzer
techforlife is offline   Reply With Quote
Old 02-03-2013, 06:26 AM   #53025
techforlife
CDI REPAIR
Oddometer: 3,310
Originally Posted by ONandOFF View Post
Got some good dark beers up there? I'm drinking a coffee stout by Hardywood Park Brewery in Richmond my son brought; feels good
Dave was here between his two visits to you and spoke kindly of you and your wife. You were very generous to take care of him in his time of great need. My admiration really goes out to you for that!
If I don't get up there first, y'all come by here!
It was a great time.for both of us,,we enjoyed his company...love to do something like that again...dark beer eh.........alrighty then,,i can manage that me thinks..
B
Times are GMT -7.   It's 11:52 AM.
