Old 02-04-2013, 05:07 PM   #53116
JWhitmore44
pistolero
JWhitmore44's Avatar
Oddometer: 1,212
Originally Posted by ADV BUM View Post
The tubliss creates a very stiff sidewall that will help protect the rim.
Are you talking about the bead being stiff? The sidewall being stiff, I would think, will be a combination of the tires sidewall material and how much air you have in the tire. I could see where only running 2 to 5 pounds in the tire would give it a lot of sidewall cushioning to prevent sharp hits against the wheel. I can kind of see where if you had a solid locking rim bead that you would support the rim a little better, possible.
84 Honda Goldwing (GL1200)
03 XR650L
JWhitmore44 is offline   Reply With Quote
Old 02-04-2013, 05:13 PM   #53117
ADV BUM
Oddometer: 118
http://www.google.com/url?sa=t&rct=j...ln6v0myvDXSELw
One of those things you would have to try for yourself.
ADV BUM is offline   Reply With Quote
Old 02-04-2013, 05:34 PM   #53118
mhking
mhking's Avatar
Oddometer: 45
need help with blinkers
Hey everyone I found these blinkers the other day and thought they would make great blinkers to mount in my hand guards but whenever I hook them up to be blinker wires they won’t flash, my blinkers just stays on like a bulbs burnt out. I know they are just accent lights but there has to be a way to be a way to bypass the future that stops them from blinking if a bulb is out. Any help would be great since I had to be an idiot and just cut my old blinkers so I’m blinker free until I figured this out.
http://www.superbrightleds.com/morei...ght-module/28/
I found this on their site to and was wondering if I could use this instead of my turn signal relay.
http://www.superbrightleds.com/morei...odule/196/846/
09 XR650L
mhking is offline   Reply With Quote
Old 02-04-2013, 05:37 PM   #53119
JWhitmore44
pistolero
Oddometer: 1,212
Good link, and it had the answer I was looking for
"Rim Protection
TUbliss protects the rim from dings and dents by holding the tire firmly and making the sidewalls stay upright and absorb the full impact, unlike bending and deflection of conventional tubes."
I wouldn't mind trying the setup. It always sounded like a good idea to me.
03 XR650L
Old 02-04-2013, 05:40 PM   #53120
JWhitmore44
pistolero
Oddometer: 1,212
You will probably need an electronic flasher, basically a flasher made for LED style trun signals.
http://www.superbrightleds.com/searc...ed%20flashers/
neat idea
03 XR650L
Old 02-04-2013, 05:42 PM   #53121
mhking
mhking's Avatar
Oddometer: 45
o ok so i cant just hardwire them in. that sucks.
09 XR650L
Old 02-04-2013, 05:49 PM   #53122
JWhitmore44
pistolero
Oddometer: 1,212
Are you leaving the stock front turn signals wired in? If so then I would have thought it would have worked. If not, you'll need the flasher.
03 XR650L
Old 02-04-2013, 05:53 PM   #53123
mhking
mhking's Avatar
Oddometer: 45
well i left the rear turn signal and just cut the front wires but everything else is stock so i guess ill have to buy the flasher.
09 XR650L
Old 02-04-2013, 06:00 PM   #53124
Ben99r1
Ben99r1's Avatar
Oddometer: 2,804
Originally Posted by Brown Falcon View Post
Got my muffler turn-down finished up. It works better than I expected. The XR600R muffler with the insert removed has about a 1-7/8" outlet. I used the same size turndown on the end cap, so the turndown is straight through 1-7/8".
At idle and low speeds it is somewhat quieter. Definitely not as harsh sounding. But it is MUCH quieter to me while riding at higher speeds (about 25 or so).
I like it. You should make me one. We can trade for the 7/8 bar riders that I was telling you about. PM and let me know
Ben99r1 is offline   Reply With Quote
Old 02-04-2013, 06:05 PM   #53125
Ben99r1
Ben99r1's Avatar
Oddometer: 2,804
Some what confused about the comment on the test light lighting when it contacts the bulb "housing". If you are talking about the metal part of the bulb socket causes your test light to light when you touch it, then something is wrong. The metal housing part of the bulb socket should be the ground. Inside at the bottom of the socket you should see a copper piece that resembles a nail head (if it's a two filament set up you will see two "nail heads). With alligator connector of you test light clipped to something metal on your bike touching the contact (that looks like a nail head) should cause the test light to blink (assuming the blinker switch is on) just like a bulb. If you have power at the connector under the seat, and possible in the bulb socket, then it's not the switch.
It lights up anywhere where it touches metal. So would it be safe to say that the ground wire being cut or disconnected to that bulb would cause that to happen?
Old 02-04-2013, 06:20 PM   #53126
Sierra Thumper
Oddometer: 641
Originally Posted by Lost on Row 1 View Post
Don't worry about losing any of your suspensions quality. Setting the sag is what gives the bike proper front to rear balance. When you have less than recommended sag you will have more weight toward the front of the bike, could be the cause of some front end wander on dirt roads. To much sag will have too little weight on the front and will push in a corner. Just remember that static sag and race sag are different. Set your race sag, 4 " with you in gear standing on the pegs with some one holding the bars. The other measurement is with the bike on a crate or stand with the rear wheel in the air. When you race sag is correct, the static sag will be also, IF your spring weight is. It does not matter what you set first, race or static, if the spring is wrong then so will be one of the sags.
Kinda ripping through this assuming you know some of it, be glad to help if not. This stuff is easy to do and really makes your bike handle as well as it can.
My legs are way shorter than I think.
I'm 6'3" and complaining about the height of an xrl....I guess that just tells you how tall these bikes really are
Originally Posted by ONandOFF View Post
It's worth checking. Don't forget, the static sag is measured as the vertical difference between the suspension fully extended, and where it rests with you sitting completely on it, feet on pegs. Kinda challenging without a helper. It should be a tad under four inches, or about 10cm. Needn't be perfectly on, just close. And it's possible there's a more optimal number for when you have a particular lowering link on, I don't know. Here's a very thorough description of how to proceed..
Thanks...I'll take the advice you guys have offered, and the link, and get on setting up my sag
Thats what I love about this place...always experienced info on the xrl at my fingertips.......I think I'm getting spoiled
Originally Posted by bwalsh View Post
The stock height is like sitting in the nose bleed section of a stadium. It's up there...
I read somewhere that the xrl had one of the tallest seat heights of any stock bike made......and I believe it. I've owned many dirt bikes, and my xrl lowered fits me like my true mx'ers did stock height
I think their comes a point of possibly being too high? Especially with an oversize tank on the xrl, it really carries the weight high .......but I can ride over anything
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Old 02-04-2013, 06:26 PM   #53127
mendoteach
mendoteach's Avatar
Oddometer: 1,083
I used to have many problems with flats. I am a large person and like to ride this bike hard. I then found tubliss. Not one issue since.
A tire I like for the rear is the MOTOZ Dot.
http://www.google.com/url?sa=t&rct=j...lJYdFGT1RKeaRw
I am going to try the Tubliss system after I get some experience with them on my smoker. I have a friend who swears by them. My only worries are how they hold up to the heat put in the tires by the twisties. Hmmm....
mendoteach is offline   Reply With Quote
Old 02-04-2013, 06:28 PM   #53128
mendoteach
mendoteach's Avatar
Oddometer: 1,083
Originally Posted by 3girlsdad View Post
if any of you have thought about a neck brace, motocrossgiant.com has the leatt adventure 3 on sale for a limited time starting today for only $169.99. free shipping over $85. it's black with some red, matching the XRL. there, this is now XRL related
linky
I wonder if you can look over your shoulder with one to change lanes? I too have thought hard about going to a Leatt.
Old 02-04-2013, 06:33 PM   #53129
Spud Rider
Spud Rider's Avatar
Oddometer: 3,000
You also need to remove the bulb from the turn signal indicator. Try removing this bulb before you go any further.
Spud
2005 XR650L: Shorai Battery Relocation, Spud Oil Cooler, XR650R C/S Sprocket, Reinforced Subframe, Chain Slipper Roller, Performance Design Lowering Link, Baja Designs Headlight, FMF Hi-Flo Header, ManRacks SD Rack, CST Surge I Front Tire, D952 Rear Tire, Tusk D-Flex Handguards, Uni Air Filter, No-Toil Evolution air filter oil
Old 02-04-2013, 06:37 PM   #53130
ADV BUM
Oddometer: 118
I am 6'5. When I first bought this bike (stock) I could not ride it. I was so hunched over, awkward and uncomfortable. It has taken many years for me to find the setup that fits me perfect. I run Rox 3 1/2 risers, which clears my stabilizer and I run ATV quad bend handlebars. This setup required custom cables, but was so worth it. I can stand up straight when riding in the open desert sand (yes). I also used powerpegz/ pivotpegs so the pegs lowered a tad and pivoted for more room. In the pics you can see how high the bars are in comparison to the fairing.
Times are GMT -7.   It's 12:42 AM.
