Old 02-11-2013, 09:31 AM   #53566
ltcole
Herpetologist
ltcole's Avatar
Oddometer: 85
Worn clutch?
New to this XRL thing, here is my question for the all knowing.
Should the bike jump a little when shifted between the gears, the clutch fully depressed and standing still? Not a big jump, but you can tell it has itchy feet and feels like it wants to get going. How do I know when the clutch needs replaced?
I have an 07 with 5700 miles, and when I bought it at 4400 the PO had the clutch adjustment way too tight in my opinion. There was no free play, which made it not even any fun to ride because you didn't have any control besides full out clutch.
I am constantly trying to learn as much as I can about these bikes because I want mine to last as long as possible, and you guys seem to be in the know.
Thanks ahead of time for any advice/suggestions.
LTCOLE
ltcole is offline   Reply With Quote
Old 02-11-2013, 09:41 AM   #53567
Sierra Thumper
Oddometer: 641
Originally Posted by Spud Rider View Post
I don't remember anything specific regarding the J.T. sprocket. However, any of the XR650R C/S sprockets can be "persuaded" onto the XR650L countershaft, provided you do enough grinding to the inside of the inner chamfer. You can get the Primary Drive, XR650R C/S sprocket for $8.99 from Rocky Mountain ATV/MC.
http://www.rockymountainatvmc.com/p/...Front-Sprocket
However, definitely be prepared to grind on the thicker, Primary Drive, XR650R C/S sprocket. The PBI/Moose Racing C/S sprockets will install much more easily.
Spud
Spud isn't steering you wrong, I listened to his excellent advice and picked up a Moose 15 tooth XRR sprocket to put on my bike with 11,800 miles on it, the moose sprocket went on with some grease and a big socket over it and a few taps with my rubber mallet.....super easy. When I changed to a 14 tooth Moose front it went on just as easy. And the sprocket is ROCK solid. Spud documented thousands of miles of riding with the XRR sprockets and he completely stopped the cs wear.
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Old 02-11-2013, 09:47 AM   #53568
Mossy-Back
Wet-Sider
Mossy-Back's Avatar
Oddometer: 1,652
Originally Posted by rmhrc628 View Post
At the risk of offending the gurus here, may I ask what chain everyone uses these days?
The reason I ask is that nowadays we have t rings, o rings and now x rings. I have 2 Crf450s hence my confusion :)
Since my xr is a 2000 model I grew up using o ring chains. But which chain do I use nowadays ?
I really like my RK X-ring chain. Good quality, decent price, no stretch so far. Bought mine from Rocky Mountain ATV
'05 CRF450X
Once a Marine, always a Marine!
Mossy-Back is offline   Reply With Quote
Old 02-11-2013, 09:49 AM   #53569
Sierra Thumper
Oddometer: 641
Originally Posted by dcparks View Post
sign me up for the "my CS is munched" club. .
Based on Spuds sage advice, i pulled the cover off - ! - rust! lots of it, and lots of in-out play. The inboard side of the retainer is mangled, and there is about 30% wear on the CS splines. . open beer. curse fate. recognize own culpability. pull self together. This is what it looks like:
the retainer:
so, given all that,
  • I rely on this bike. ride it every day. 21000 km (a little over 13K miles). no other obvious issues.
  • cant afford to pay someone to rebuild.
  • never rebuilt an engine, but willing to try (there is no try...do, or do not..)
  • have space and tools. some time (but not much...)
So, given the above, what would you do?rebuild?, or 650r sprocket and tack weld? given the advanced wear, will the 650R sprocket have enough to seat on? Thanks to Spud for the cautionary heads up.
whale oil beef hooked.
A new retainer and an XRR sprocket and you'll prolly be good to go longer than you'll own the bike. The XRR sprockets REALLY take up ALL the available spline area, and because of that they slow down the wear dramatically. With a new retainer and XRR sprocket I wouldn't even sweat that
Old 02-11-2013, 09:53 AM   #53570
elsalvadorklr
southern xr rider
Oddometer: 4,154
you can also "rebuild" the splines...
start throwin flames! I know
I did it and it worked till I split my cases for a complete engine rebuild! jajajajaa
elsalvadorklr is offline   Reply With Quote
Old 02-11-2013, 09:56 AM   #53571
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,332
If the bike is fully warmed up you should be able to shift into gear with little to no clunking or movement....
If it`s cold,that`s a different story,,thick cold oil between the plates/frictions will cause quite a bit more noise shifting into gear from neutral and will also make it hard to push the bike forward with clutch in and not running in gear,,that...IMHO is normal if only doing this when cold..it`s due to the thick cold oil taking up space between the plates and dragging acting like a slightly dragging clutch would...depends on temperature too...
B
techforlife is offline   Reply With Quote
Old 02-11-2013, 09:57 AM   #53572
mcma111
mcma111's Avatar
Oddometer: 12,549
The tell-tale sign of a worn clutch is that the bike will have a very hard time, if not impossible, finding neutral when at a complete stop. Prior to this is when at a stop, in gear the bike wants to creep which is a dragging clutch.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 02-11-2013, 09:59 AM   #53573
Sierra Thumper
Oddometer: 641
That stinks, Falcon. You can practically plate a riding lawnmower, here in Idaho. When I titled my CRF250X at the DMV, I filled out a dual sport form at the same time. I walked out of the DMV in ten minutes, with my license plate in hand. I had not done any street legal modifications at that time, and I didn't even need to present the bike for an inspection.
In Idaho, all you need is a headlight, tail light, brake light, horn, and a single mirror. You can mount a clown horn, if you like. The police don't bother us here.
Spud
Pretty much the same in Nevada....except you need it inspected
Old 02-11-2013, 10:01 AM   #53574
WMD
WMD's Avatar
Oddometer: 54
Originally Posted by ThumpnRed View Post
If you are going to keep that up, you need to think about reworking your suspension. Perhaps pick up a spare frame when you see one for cheap
Haha, nope it was just a one time thing to see if she would fly.
WMD is offline   Reply With Quote
Old 02-11-2013, 10:05 AM   #53575
techforlife
CDI REPAIR
Oddometer: 4,332
Anything can fly...........landing...........not so much
B
Old 02-11-2013, 10:20 AM   #53576
mcma111
mcma111's Avatar
Oddometer: 12,549
Gravity sucks
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 02-11-2013, 10:37 AM   #53577
chipbl
chipbl's Avatar
Oddometer: 288
Originally Posted by ADV BUM View Post
Would it be easier and more cost effective to use the dash with indicator lights that trailtech offers and then incorporate that into the mount you are designing.
ThumpnRed, have you looked at some of the products HDB makes? But I get it if you want to make your own!
2008 XR650L, tons of goodies.
chipbl screwed with this post 02-11-2013 at 10:48 AM
chipbl is offline   Reply With Quote
Old 02-11-2013, 10:44 AM   #53578
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,562
How's that work? I can see how one would rebuild splines on a large shaft, but how in the heck would you accomplish it on such small splines? Heat treating?
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Old 02-11-2013, 10:52 AM   #53579
ltcole
Herpetologist
ltcole's Avatar
Oddometer: 85
B
Thanks, and thanks Steve. That all makes sense. Once it is fully warmed up, it still clunks a little, and it depends on the day whether it decides to go easily into N. Sometimes it goes in with no problem, and sometimes it takes me a try or two.
Maybe it's getting close. I will pay a little more attention to things and hopefully not have to do it too soon.
LTCOLE
Old 02-11-2013, 10:53 AM   #53580
Spud Rider
Spud Rider's Avatar
Oddometer: 3,811
Originally Posted by mendoteach View Post
Spud those bikes need very frequent air filter, and oil service intervals. Otherwise the motors live in dog years. Synthetic oil too!
Thanks for the warning, Teach. Compared to the XR bikes, the CRF motorcycles are maintenance whores. The stock, titanium intake valves usually last 100 hours, or less, before they recess into the valve seats. Fortunately, the previous owner recently rebuilt the top end of my engine. Most importantly, he sent the cylinder head to CRFs Only for Kibblewhite, stainless steel valves and machining.
http://www.crfsonly.com/catalog/prod...oducts_id/3974
Spud
Times are GMT -7.   It's 09:04 AM.
