02-11-2013, 03:51 PM
#53611 |
Oddometer: 8,011
No shit. What upside???
Steve in SF BMW's 58 R26 79 R100s 91 R100gs 87 Harley FXRS-SP ~ 06 KTM 625 SMC ~ 72 Honda CB750/915cc ~ 92 XR600/654cc ~ 95 XR650l/675cc ~ 03 CRF450r ~ 05 CRF450x ~ 02 XR650l/675cc ~ 86 YZ490 ~ 93 YZ80 ~ 93 XR650l Project |
02-11-2013, 04:19 PM
#53612 | |
Duel
Oddometer: 2,200
I run the www.versahaul.com hitch mount carrier. Rated for 500lbs. I load the xr650l with saddlebags and 5.8gallon Acerbis tank full, no problem with sway or bottoming out. This is with a stock 2007 four door jeep wrangler. I got my hitch hauler on Craigslist for about $100.00 ![]() ![]()
bomber1965 screwed with this post 02-11-2013 at 07:04 PM |
02-11-2013, 04:44 PM
#53613 | |
Must / takeit / easy
Location: Harrisonboiig; Shenandoah Valley riding wonderland
Oddometer: 4,393
Let's ride!!! ![]() - No offense, but there've been a lot of people over time who were just as sure, but got it wrong. - Una necedad, aunque la repitan millones de bocas, no deja de ser una necedad. |
02-11-2013, 04:47 PM
#53614 | |
Pig Wrangler
Oddometer: 1,576
Just like the piston in your engine. Low in the stroke now... what happens next?
02-11-2013, 05:06 PM
#53615 | |
Oddometer: 4,393
This winter and last haven't been typically bad here thankfully. Î was able to go for a nice xrl day long ride week before last. Fun and didn't get cold Maybe this year I'll get to do a multi-day xrl dirt trip... with camping...
02-11-2013, 05:11 PM
#53616 | |
CDI REPAIR
Oddometer: 3,339
![]() B
01 XR650L,102mm JE 11.25:1 ..NX650 second gear,FMX650 fifth gear,ported CW head,KW valve train,MegaCycle 173X25.Cycra probend CRM,Scott`s sharkfin,Xr`s Only casesaver.FMF "Q2",Sutton Oil Cooler,Clarke 4.0,Red XR`s Only skidplate,Doubletake mirrors,Manracks Rotopax rack..one Minature Schnauzer
02-11-2013, 05:24 PM
#53617 | |
Oddometer: 4,393
![]() Otherwise, right, piece of cake
02-11-2013, 05:33 PM
#53618 |
Oddometer: 8,011
Honda Gasket Removal
The factory gaskets are PAPER. No need for chemicals or paint remover. WATER is all you need to soften them up to assist with the removal. That and some fresh razor blades,
02-11-2013, 05:37 PM
#53619 |
Oddometer: 763
A sharp flat wood chisel makes a really good gasket scraper . Just dont use a hammer.
02-11-2013, 05:41 PM
#53620 | |
Oddometer: 1,083
Steve, I am hoping to have somebody help me with degreeing the damn cam in the next week. If that fails, I'm buying a degree wheel and giving it a go myself. Here's a good article I found: http://www.muzzys.com/articles/lobe_centers.html CW, says 110 degrees on the intake with zero lash. Different than how they are generally done I guess. |
02-11-2013, 05:43 PM
#53621 |
Oddometer: 641
Just changed from 20-50 to 10-40 full syn oil....WOW!!
The po of my bike had just changed the oil with fresh 20-50 when I bought it......I was able to get some good rides on the 20-50.....but it was due for an oil change, so I went ahead and picked up some valvoline 10-40 full syn, and a wix filter, and put them in today......the 10-40 made a huge difference in the power, downright shocking
I knew there'd be some diff because its been cold here, and the 20-50 isn't meant for cold weather riding. But I had no clue how big the difference was really going to be. On my high hp street bikes you don't really feel much diff....but on the lower hp dual sports you feel everything. The bike literally pulled like it was in a gear lower than it really was. I got on the gas and thought I was still in 4th and I was in 5th. And that was with the 4.6 IMS full, and heading up a slight hill. Thats never happened before on this bike ![]() Between the thinner oil and the powerbomb/cut airbox with some fine tuning, she's really pulling strong now for an xrl at 5000ft up ![]() The more power I'm getting the more I'm wanting tho ![]() The only thing I miss about the 20-50 is that the motor was a little quieter and smoother......but it felt like it was chained to a post before the 10-40. And I did most of my riding in warm weather with the 20-50.....and the difference is still this big. I just wanted to let you guys know my experience....if you're running 20-50 I'd recommend going down to 10-40, and a full syn at that Not sure why the po opted to run 20-50 in the poor xrl ![]() I bet a guy would notice even more of a diff if he went to a full syn 10-30....a little light for our bikes I think, but I bet it would raise the fun factor in the engine department even more And you could prolly pull it off in a colder climate for the winter riders
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack Sierra Thumper screwed with this post 02-11-2013 at 06:03 PM |
02-11-2013, 05:52 PM
#53622 | |
Oddometer: 4,393
![]() I think if going this way rather than roll my rear wheel, I'd build a dolly to put under my rear wheel.
02-11-2013, 05:53 PM
#53623 |
Oddometer: 8,011
Mendo,
I just read the cam timing article. I just wish that CW made the cam to drop in like a Mega Cycle cam. None of this degreeing crap. KISS...
02-11-2013, 06:02 PM
#53624 |
Oddometer: 641
Watch your harbor freight torque wrenches....I almost got the shaft from mine today
I have 3 harbor freight torque wrenches, a 150 ft-b, an 80 ft-lb, and an inch-lb. So far they've been great, I've actually cross-tested them with each other and they've all been very close. But today when I was using my inch-lb to tighten up the 8mm bolts on my oil filter cover, the little sob backed off the calibration nut on the handle without me noticing, and as I was tightening the bolts I was thinking, this doesn't feel right. Its VERY easy to strip those oily little filter cover bolts...I was able to catch it in time, and just used my 80 ft-lb instead.
But anybody using the harbor freights keep an eye on the calibration collar at the end of the handle......NOT the locknut sticking out the end, but the adjuster at the base of the handle. I found out today that they tend to loosen up VERY easily....poor design I know I know, thats what I get for using harbor freight crap ....but I've had the 2 bigger wrenches for years (gifts) and they've been flawless.... thats why I recently picked up the inch-lb......and got bit by the horrible freight bug
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack |
02-11-2013, 06:08 PM
#53625 | |
Oddometer: 4,393
![]() But yeah scraping a lot more is also a solution.
