02-11-2013, 09:19 PM
#53641 |
Mossy-Back
Oddometer: 714
Good birthday today! My wife got me some Tusk grip heaters, a Fog City helmet visor insert, and a gift certificate to my favorite local moto shop!
I need to pick up some Pillow grips for it and get these heaters on! What's the trick to installing the heater on the throttle side? And what's the best place to tap into power for a relay?
Evan Ooh-Rah! Once a Marine, always a Marine! '93 XR650L (Xena) |
#53642 |
Oddometer: 1,083
That thing would be fun to cut doughnuts with until you burned through all the rubber.
02-11-2013, 09:22 PM
#53643 | |
Oddometer: 34
02-11-2013, 09:23 PM
#53644 | |
Oddometer: 2,955
![]() ![]() Spud
2005 XR650L: Shorai Battery Relocation, Spud Oil Cooler, XR650R C/S Sprocket, Reinforced Subframe, Chain Slipper Roller, Performance Design Lowering Link, Baja Designs Headlight, FMF Hi-Flo Header, ManRacks SD Rack, CST Surge I Front Tire, D952 Rear Tire, Tusk D-Flex Handguards, Uni Air Filter, No-Toil Evolution air filter oil |
#53645 | |
Oddometer: 1,083
02-11-2013, 09:30 PM
#53646 | |
Oddometer: 2,955
http://www.rockymountainatvmc.com/p/...Front-Sprocket However, I recommend the PBI/Moose Racing, XR650R C/S sprockets. You can order the PBI sprockets directly from PBI, in Oregon. http://shop.pbisprockets.com/product...&categoryId=21 You can order the Moose Racing, XR650R sprockets from Motorcycle Superstore. http://www.motorcycle-superstore.com...50R-Parts.aspx It appears to me PBI manufactures these sprockets for Moose Racing. ![]() Spud
02-11-2013, 09:32 PM
#53647 | |
No Pretensions
Oddometer: 278
From Rocky Mountain ATV: Primary Drive Front Sprocket 14 Tooth - 2002 Honda XR650R 1021470119 $8.99 PLATE, FIXING (Honda Code 2917359) 131179007524 $8.14 From Motorcycle Superstore: Moose Racing 520 Front Countershaft Sprocket Color- Steel, Size- 14 SKU#145865 In Stock $20.95 I had to order from 2 different shops--what a pain. Anyway, that's what I did. Sorry, if I had thought about it I would have ordered 2 sets, and just mailed you a set. Forgot to use the noggin...PD
The Good Lord gave most of us 10 digits; mine are all thumbs. |
02-11-2013, 09:34 PM
#53648 | |
No Pretensions
Oddometer: 278
I can't even cut & paste fast enough before you beat me to the punch. Thanks for the good work; we all rely on you. You are like a fireman working 24 hour shifts. PD
02-11-2013, 09:35 PM
#53649 |
Oddometer: 1,083
Have someone in the states throw it on their order when they get free shipping and then ship it to you via first class mail to Canada.
02-11-2013, 09:37 PM
#53650 | |
Oddometer: 2,955
Download the supplemental, installation instructions at the Rocky Mountain ATV website. These instructions explain how to reinforce the wires on the throttle tube so they won't fail. ![]() http://rockymountainatvmc.com/docs/G...0Throttles.pdf I installed a single layer of 1-inch shrink tubing on the left handgrip before I installed the grip heaters. The single layer of shrink tubing works well as insulation. ![]() Spud
02-11-2013, 09:38 PM
#53651 |
Oddometer: 1,083
Does somebody know a good, fairly low profile, LED blinker? I ordered some cheap ones from ebay and they are CHEAP! The wires are about 32 gauge and they pull out of the body easily. I don't mind paying if they are bright and tough.
02-11-2013, 09:41 PM
#53652 | |
Oddometer: 2,955
If I knew you were racing to answer the question, I would not have responded. ![]() Spud
02-11-2013, 09:43 PM
#53653 | |
Oddometer: 2,955
![]() Your LED blinkers will work if you remove the turn signal, indicator light. However, if you want the indicator light to work, you need to install diodes, as I explained in a previous post. You can get the diodes from Radio Shack, or you can buy the wiring kit from Kuryakyn. Spud
2005 XR650L: Shorai Battery Relocation, Spud Oil Cooler, XR650R C/S Sprocket, Reinforced Subframe, Chain Slipper Roller, Performance Design Lowering Link, Baja Designs Headlight, FMF Hi-Flo Header, ManRacks SD Rack, CST Surge I Front Tire, D952 Rear Tire, Tusk D-Flex Handguards, Uni Air Filter, No-Toil Evolution air filter oil Spud Rider screwed with this post 02-11-2013 at 09:53 PM |
02-11-2013, 10:44 PM
#53654 | |
Oddometer: 7,730
I got a used throttle tube(free) and an extra set of grips(not free)...Left side is just like the right side now...handlebar, throttle tube, heater, grip. Nice and toasty! I did have to use a rubber mallet to "gently" tap the throttle tube on the left side as it has a knurled surface. Use a piece of a 2x4 placed against the throttle tube to help prevent breaking it while tapping.
2004 XR650L 1992 Specialized Stump Jumper FS NWVA TAG NWVA TAG MAP RTE THREAD & IN LIST |
02-11-2013, 11:37 PM
#53655 |
Ain't Dead Yet!
Oddometer: 49
Got a Renthal on mine. Works great and you'll save the shipping.
2001 XR650L With 97,000 miles. Nicest one around! |
