Old 02-19-2013, 10:11 AM   #54256
elsalvadorklr
southern xr rider
Oddometer: 4,154
Originally Posted by fritzcoinc View Post
no, not at all. Mine runs just fine. Wana race? My bike is 95% faster than yours, 3% of the time.
^^^^^like
elsalvadorklr is offline   Reply With Quote
Old 02-19-2013, 10:40 AM   #54257
bwalsh
bwalsh's Avatar
Oddometer: 11,496
Originally Posted by Sierra Thumper View Post
My wife has a modular HJC helmet....she only used it a few times over a number of years, and the locking mechanism for the lift up front broke.....so I took it apart to check it out. The locking mechanism is made of super cheap, thin, flimsy plastic that I would NEVER trust to stay closed in ANY kind of impact....hell, it just broke from her using it a few times.
The HJC flip-up is complete junk....stay far far away
I've heard from more than a few sources(owners) that modular helmets will fail when you need it to work the most...
Personally I wouldn't own one.
2004 XR650L
NWVA TAG NWVA TAG MAP RTE THREAD & IN LIST
bwalsh is offline   Reply With Quote
Old 02-19-2013, 10:47 AM   #54258
purpledrake
No Pretensions
Oddometer: 334
Originally Posted by super samurai View Post
i was rather thinking of keeping the rear sprocket stock tooth count and changing the css to a 14 tooth and be in the range between the 14/45 and the 15/48 stock gears. that way i would be somewhere in the middle range and not have to sacrafice top end for low end.
make any sense
And, if you decide to go down from your current 15T XRR CSS to a 14T version, remember that I have a brand new Primary Drive front sprocket (14T) for your use. (And, you have Dremels galore to make the bloody thing fit!)
PD
The Good Lord gave most of us 10 digits; mine are all thumbs.
purpledrake is offline   Reply With Quote
Old 02-19-2013, 11:06 AM   #54259
bwalsh
bwalsh's Avatar
Oddometer: 11,496
The power of the Farkle Side is strong ...
May the Farkle be with you!
2004 XR650L
Old 02-19-2013, 11:35 AM   #54260
Lonestar2112
scatology expert
Lonestar2112's Avatar
Oddometer: 7,203
Originally Posted by JWhitmore44 View Post
The type of riding you plan on doing can make a difference on what you may want to do with your suspension. A couple of things you can do to your forks before you spend big bucks is, as some one has said before, add heavier fork oil. You can also put a spacer made out of PVC pipe, about 1/2 to 3/4 inch long, and place it on top of the springs to add some preload. lastly, add a fork brace. This all keeps the ride a bit cushy, lessens the front end dive on breaking, and keeps the front wheel from deflecting. Now if you plan and getting the bike air borne a lot or hammer corners hard and canyon racing, then you'll probably want to consider a USD conversion :)
Actually, the type of riding will probably dictate what kind of mods you want to add.If you are doing mostly trails and back roads and very little black top then a 48 tooth rear sprocket is a good choice and then tun a 15 or 14 CS sprocket depending on how slow you want to go. I find my self on gravel roads, jeep trails, some quad or single track trails and quite a bit of blacktop in between and I prefer the 15/45 combo. But it's open and flat around here so even the two lane highway it's easy to run 70 to 75. If you are trail riding you may be looking at trimming weight, I think there is a whole thread on dropping weight of the XRL. If you plan on doing some camping or traveling then you will want a rear rack and probably some sub frame supports. Check out manracks for those items.
As tall as you are you'll probably find the bars a bit low and the position a bit cramped. Some bar riser and high bend bars help a lot in bot setting and standing position. You can typically go 2 inch risers with high bend bars without changing cables, although I found my clutch cable to be just a little short with the bars locked clear to the right. Wider foot pegs will give you a better platform for your feet. You don't have to go expensive as there are some economical ones on ebay that work good.
I will differ with some of the thoughts above. I am 6'6" 250. If you plan on spending any time on the pegs at all go with a 3.5" + lift on the bars, I did that and installed KX High bars. Spend the $ call motion pro and get the longer choke, clutch cables. The throttle cables are long enough when rerouted. At 300 lbs even with a fork brace you will feel the forks twist if you are agressive at all. I am doing the CRFx fork swap. While you are at it change out the foot pegs to a wider one. I run a 14 tooth up front for most times, unless there is a long street ride then I will install a 15.
http://share.findmespot.com/shared/f...SKgzdmS9ir0XK3
Wypierdalaj ty chuju jebany
F*CK CANCER
Lonestar2112 is offline   Reply With Quote
Old 02-19-2013, 12:30 PM   #54261
dcparks
Oddometer: 132
Originally Posted by purpledrake View Post
Meanwhile, back at the ranch, I will take SpudRider's advice, and have SuperSamurai tack weld the XRR CSS to the countershaft. This will prevent any unnecessary "wobble" (technical term). After I weld the CSS on, the only way to remove the chain will be to break it, correct? (Break = remove the master link) In other words, the chain cannot be slipped over the CSS, can it?
First, thanks again to spud, purpledrake, and others for the CSS wisdom. We are truly blessed. I am still waiting for my Moose XRR CSS (bugger, wish i had ordered a 15T now, plus i could have walked to Oregon and back by now). Anyway,
Purpledrake, how well does the CSS fit? is there any play, (or "wobble" to use the correct tehnical term) evident now?
BTW, feel free to stop by on your way up island if you come through Vic.
dcparks is offline   Reply With Quote
Old 02-19-2013, 01:00 PM   #54262
ONandOFF
-ROAD-
ONandOFF's Avatar
Oddometer: 6,234
... How does one decide if the chain is too short? ... On&Off often posts a great graphic, which shows how to properly adjust the chain (putting tension on the rear suspension...). Isn't any chain size "correct" in the sense that if chain tension is properly set, then all is well?? ....
Yes, PD; your reasoning is correct. If you can just relieve the tension at the maximum sprocket separation, that is where the sprocket centerlines form a line with the swingarm centerline, then your chain is optimally set and it is not too short. The caveat to the "any size correct" assertion is that if you find the adjusters close to coming off the rear of the swingarm under the above condition, then the chain, although fine at the moment, may be too long to allow further adjustment once the chain stretches a bit.
Let's ride!!! - No offense, but there've been a lot of people over time who were just as sure, yet got it wrong. - Una necedad, aunque la repitan millones de bocas, no deja de ser una necedad. - "you know that I could have me a million more friends and all I'd have to lose is my point of view" (Prine)
ONandOFF is online now   Reply With Quote
Old 02-19-2013, 01:07 PM   #54263
ONandOFF
-ROAD-
ONandOFF's Avatar
Oddometer: 6,234
Originally Posted by mendoteach View Post
... It won't make you faster on a fire road, though you will fell like it. ...
In that case, better not. I hate falling on fire roads...
Sorry... couldn't resist picking on getting the wrong word...
Old 02-19-2013, 01:30 PM   #54264
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,537
Gaaaa!
If you are gonna bird shit it on, there isn't any point in using an XRR sprocket as the spline interface is irrelevant at that point. (sorry... welded on sprockets are still a sore spot for me)
I have a once welded 15T sprokie that I'll let you have for the cost of shopping!
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed screwed with this post 02-19-2013 at 01:36 PM
ThumpnRed is offline   Reply With Quote
Old 02-19-2013, 01:36 PM   #54265
ONandOFF
-ROAD-
ONandOFF's Avatar
Oddometer: 6,234
Originally Posted by thumpnred View Post
gaaaa! .... (sorry... Welded on sprockets are still a sore spot for me)
+1
Old 02-19-2013, 02:05 PM   #54266
marlinjames
Oddometer: 289
suspension
Alrighty im going to re do my suspension. before i buy the fork solution kit with the .80 springs. http://procycle.us/bikepages/xr650l.html
i wanted to see if a fork swap all together is a better idea or what. id hate to spend 300 to rebuild what i have when its still junk and theres something better
marlinjames is offline   Reply With Quote
Old 02-19-2013, 02:10 PM   #54267
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,537
That's a loaded question. Let the opinions fly...
My vote is for a USD swap
Old 02-19-2013, 02:15 PM   #54268
XR650L_Dave
Oddometer: 3,731
If a USD swap is price-comparable with a fork rebuild, that is one of the worlds top no-brainers.
---->>Thanks for the rotor, guys!<<----
XR650L_Dave is offline   Reply With Quote
Old 02-19-2013, 02:25 PM   #54269
marlinjames
Oddometer: 289
Usd swap?
Sent from my SCH-I535 using Tapatalk 2
Old 02-19-2013, 02:31 PM   #54270
mcma111
mcma111's Avatar
Oddometer: 12,083
Usd swap?
U Up, S Side, D Down
As in installing CRF forks on your XRL
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
mcma111 screwed with this post 02-19-2013 at 02:41 PM
Times are GMT -7.   It's 10:24 AM.
