02-19-2013, 10:06 AM
#54271 |
Oddometer: 7,801
May the Farkle be with you!
2004 XR650L 1992 Specialized Stump Jumper FS NWVA TAG NWVA TAG MAP RTE THREAD & IN LIST |
02-19-2013, 10:35 AM
#54272 | |
Crash test dummy
Oddometer: 5,234
I will differ with some of the thoughts above. I am 6'6" 250. If you plan on spending any time on the pegs at all go with a 3.5" + lift on the bars, I did that and installed KX High bars. Spend the $ call motion pro and get the longer choke, clutch cables. The throttle cables are long enough when rerouted. At 300 lbs even with a fork brace you will feel the forks twist if you are agressive at all. I am doing the CRFx fork swap. While you are at it change out the foot pegs to a wider one. I run a 14 tooth up front for most times, unless there is a long street ride then I will install a 15.
Where am I? "I love the wild spaces above the border, takes some work to get here, ain’t a Starbucks run." jdrocks F*CK Cancer |
02-19-2013, 11:30 AM
#54273 | |
Oddometer: 34
Purpledrake, how well does the CSS fit? is there any play, (or "wobble" to use the correct tehnical term) evident now? BTW, feel free to stop by on your way up island if you come through Vic. |
02-19-2013, 12:00 PM
#54274 | |
Must / takeit / easy
Location: Harrisonboiig; Shenandoah Valley riding wonderland
Oddometer: 4,407
Let's ride!!! ![]() - No offense, but there've been a lot of people over time who were just as sure, but got it wrong. - Una necedad, aunque la repitan millones de bocas, no deja de ser una necedad. |
02-19-2013, 12:07 PM
#54275 | |
Oddometer: 4,407
![]() Sorry... couldn't resist picking on getting the wrong word... ![]()
02-19-2013, 12:30 PM
#54276 | ||
Pig Wrangler
Oddometer: 1,607
![]() If you are gonna bird shit it on, there isn't any point in using an XRR sprocket as the spline interface is irrelevant at that point. (sorry... welded on sprockets are still a sore spot for me )I have a once welded 15T sprokie that I'll let you have for the cost of shopping!
ThumpnRed screwed with this post 02-19-2013 at 12:36 PM |
02-19-2013, 12:36 PM
#54277 | |
Oddometer: 4,407
02-19-2013, 01:05 PM
#54278 |
Oddometer: 171
suspension
Alrighty im going to re do my suspension. before i buy the fork solution kit with the .80 springs. http://procycle.us/bikepages/xr650l.html
i wanted to see if a fork swap all together is a better idea or what. id hate to spend 300 to rebuild what i have when its still junk and theres something better |
02-19-2013, 01:10 PM
#54279 | ||
Pig Wrangler
Oddometer: 1,607
My vote is for a USD swap
02-19-2013, 01:15 PM
#54280 |
Oddometer: 3,164
If a USD swap is price-comparable with a fork rebuild, that is one of the worlds top no-brainers.
---->>Thanks for the rotor, guys!<<---- |
02-19-2013, 01:25 PM
#54281 |
Oddometer: 171
Usd swap?
Sent from my SCH-I535 using Tapatalk 2 |
02-19-2013, 01:31 PM
#54282 |
Oddometer: 8,167
U Up, S Side, D Down As in installing CRF forks on your XRL
Steve in SF BMW's 58 R26 79 R100s 91 R100gs 87 Harley FXRS-SP ~ 06 KTM 625 SMC ~ 72 Honda CB750/915cc ~ 92 XR600/654cc ~ 95 XR650l/675cc ~ 03 CRF450r ~ 05 CRF450x ~ 02 XR650l/675cc ~ 86 YZ490 ~ 93 YZ80 ~ 93 XR650l Project mcma111 screwed with this post 02-19-2013 at 01:41 PM |
02-19-2013, 01:39 PM
#54283 |
Oddometer: 2,438
Has anyone replaced their stock shock with one of these Ricor shocks?
02-19-2013, 01:44 PM
#54284 |
Oddometer: 27
Muff Pot Food Warmer
I was wondering if anybody has every mounted something up like this on their piggy? I saw a lot of guys use them on snowmobiles and use oven bags so there is no leakage. I was thinking maybe a guy could mount it against the muffler above the tire and take it off when not in use. Any ideas guys?
Thanks, Kyle |
02-19-2013, 01:47 PM
#54285 |
Oddometer: 171
What do crf forks go for? And what else would I have to buy to make them fit? And just buy those and they're good to go. They don't need gold valves oil or springs?
Sent from my SCH-I535 using Tapatalk 2 marlinjames screwed with this post 02-19-2013 at 01:53 PM |
