Old 03-14-2013, 07:08 AM   #56086
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,512
Originally Posted by Ray Paul View Post
Be careful ! That stuff will have you thinking and acting like fritz !
The effect wears off quickly. I lived "down there" and drank that rat piss for years (actually got to thinking it was good there towards the end). I was OK once I got about as far as Colorado.
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is online now   Reply With Quote
Old 03-14-2013, 07:21 AM   #56087
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 6,809
Originally Posted by techforlife View Post
B
Here's your goal gents: Drink these all day long during a summer Willie Nelson concert at Texas International Raceway.
Good luck finding your car, man.
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 03-14-2013, 07:22 AM   #56088
ONandOFF
-ROAD-
ONandOFF's Avatar
Oddometer: 5,880
Maybe that's the new code for what adjusts his attitude? Musta happened across some good stuff! Some of these 'drink anything, as long as it's a lot' guys will try anything to get people's goad...
Let's ride!!! - No offense, but there've been a lot of people over time who were just as sure, yet got it wrong. - Una necedad, aunque la repitan millones de bocas, no deja de ser una necedad. - "you know that I could have me a million more friends and all I'd have to lose is my point of view" (Prine)
ONandOFF is offline   Reply With Quote
Old 03-14-2013, 07:24 AM   #56089
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 6,809
Are you high this morning?
Regards
Fritzcoinc
Old 03-14-2013, 07:25 AM   #56090
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,279
OK.......has anyone put a brighter bulb in their headlight....the stock one isn`t bad..but more=better.
B
techforlife is offline   Reply With Quote
Old 03-14-2013, 07:32 AM   #56091
ONandOFF
-ROAD-
ONandOFF's Avatar
Oddometer: 5,880
Why, what are you offering? I'm choosey!
Old 03-14-2013, 07:43 AM   #56092
ONandOFF
-ROAD-
ONandOFF's Avatar
Oddometer: 5,880
So, it started to get almost warm here early in the week. I rolled the XRL out into the warm sunlight and eagerly went over it, checking, lubing, cleared the fuel bowl and it fired right up... was psyched to go for a ride soon and then it got cold... nasty cold now... but at least the bike and I are ready to learn how to ride again!
Brian, I make an effort to be back home on the xrl before dark.
PS: why do you use "backwards" apostrophes?
Old 03-14-2013, 07:51 AM   #56093
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 6,809
B
I have a 100w high beam thta came with my Husky if you want it. I was scared it would burn up the wires.
But yeah, the Sylvania Ultras are much brighter but don't last as long. Maybe a third the life of standard bulb. Here's a tip. Get a Harley headlight bulb. More expensive, YES but a hell of a well made bulb. If anybody knows how to build something to resist vibration, Harley does. Their tail light bulbs are kick ass as well. I have had both in my Honda for over two years now. Still going! I learned about the supierior quality of Harley bulbs from a Houston motorcycle cop.
You will be able to see this better with a Harley bulb:
Regards
Fritzcoinc
Old 03-14-2013, 08:08 AM   #56094
RZRob
RZRob's Avatar
Oddometer: 1,513
Tapping Switched & Unswitched Power
OK, I did it the hard way before, but this time I'm considering the simplest means of power and want your opinions.
The Ignition Switch delivers switched power (to drive GPS, grips etc.) on one side and unswitched (cigarette lighter) on the other (both I'd fuse of course). And then I was going to add a rocker switch between the ground for both which I was going to draw from a forked spade connector off the horn.
The idea of the switch was so I could kill everything if/when needed yet otherwise had the logical accessories on switched power and the cigarette outlet powered for things like my air compressor etc., without having to turn the key on. I liked these sources because I don't have to modify the factory harness. I'm a big fan of KISS.
Anyone got a problem with this?
RZ Rob
RZRob is offline   Reply With Quote
Old 03-14-2013, 08:11 AM   #56095
super samurai
super samurai's Avatar
Oddometer: 316
B
I did the 100 watt high and 85 watt low in my cyclops housing. Was good but wanted more so i bought a high low h.i.d. kit and love it. And it only uses 35 watts on high or low.
i know my clear tank is ugly!
super samurai is offline   Reply With Quote
Old 03-14-2013, 08:11 AM   #56096
LexLeroy
Aging Gracelessly
LexLeroy's Avatar
Oddometer: 1,958
B
Can't speak to the XRL but I rewired my VStrom headlights direct to the battery through relays triggered by the stock headlight circuit. Got an immediate increase in brightness due to the reduced voltage drop, plus the current draw through the headlight switch was reduced.
I've got the stuff to do the XRL but I couldn't get my lazy ass into the unheated garage this last winter to do the work. Maybe later this month....
"That's MISTER Crash to you, sonny...."
LexLeroy is offline   Reply With Quote
Old 03-14-2013, 08:14 AM   #56097
super samurai
Oddometer: 316
I tried the 100 watt high 85 watt low and wanted more.so i bought an hid high low kit for my cyclops housing and love it. Now i see clearly!
Old 03-14-2013, 08:15 AM   #56098
super samurai
Oddometer: 316
Ohh and my hid kit uses 35 watts on high or low.
Huge draw drop.
Old 03-14-2013, 08:24 AM   #56099
RZRob
RZRob's Avatar
Oddometer: 1,513
Can't Compete
How am I supposed to compete with all this T & A?
Go back and look at my accessory power source questions above and please give me your opinions.
RZ Rob
Old 03-14-2013, 08:41 AM   #56100
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 6,809
RZ Rob
No problem at all. Kiss had some good songs. "Hard Luck Woman", Black Diamond"" Love Gun" to name a few.
I think I would run the air compressor straight off the bat. and not the wire harness at all. A switch to " kill" everything sounds like something waiting to go wrong.
Regards
Fritzcoinc
Times are GMT -7.   It's 05:45 AM.
