Old 03-22-2013, 12:04 PM   #56701
tedmagnum
Ted_Magnum UK
Oddometer: 99
Originally Posted by fritzcoinc View Post
You will be fine. One thing about a Honda, you can find parts for it all over the world. Just like a M98 Mauser.
What can you tell me about tire pressure sensor calibration on a 07 K1200GT. Everythiong works but the reading on the dash is not matching my " calibrated, digital, two decimal place" air pressure gage.
I'd say the tyre sensor is probably knackered or the bike needs to be hooked up to a dealer MOS computer as have the sensor reset or recalibrated (if possible)
Any faults codes showing up ?
www.touringted.com - South America travel blog.
tedmagnum is offline   Reply With Quote
Old 03-22-2013, 12:30 PM   #56702
taco250
wannabe adventurer
taco250's Avatar
Oddometer: 1,329
Originally Posted by wyoxr View Post
I finally got some work done on my fork swap. They don't make the bike run cooler, but the sure make it look that way. The forks are 46mm KYB off of a Yamaha WR400.
Those look good. How did you do the swap?
Prov 3:5 & 6
www.benddualsport.com
300+ mile Paisley OR day ride
taco250 is offline   Reply With Quote
Old 03-22-2013, 01:11 PM   #56703
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,127
No faults. I have replaced both wheel sensors and the security module with the latest Rev. parts. There was a service bulletin on the securety module. Apparently the security system interfered with the tire pressure monitor system. The system works well now, just not super accurate. The air gage I have now allows me to actually set 36.3 PSI front and 41.6 PSI rear ( those germans ).
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 03-22-2013, 01:16 PM   #56704
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,127
Originally Posted by ONandOFF View Post
I can picture the scenario... engineers proposed a design which allowed at least a two-point calibration via software interface (easy to implement and adds versatility) but the marketeers picked up on an opportunity to save a couple bucks of development time and said naw, all we need is something ballpark.
Yikes!! You're right.... (for once)
Thats my big BITCH with BMW. They design a masterpiece of a machine then source the compoents from the lowest bidder. In doing so accept less than design intent.
Regards
Fritzcoinc
Old 03-22-2013, 01:46 PM   #56705
Super Dave Hawaii
Ain't Dead Yet!
Super Dave Hawaii's Avatar
Oddometer: 248
Yuuupp!
2001 XR650L With 112,034 miles. Nicest one around! CRF450 Rally Bike.
Super Dave Hawaii is offline   Reply With Quote
Old 03-22-2013, 02:15 PM   #56706
Spud Rider
Spud Rider's Avatar
Oddometer: 3,809
The WR400 forks look great! Please do give us the details on the installation.
P.S. You might want to route the front brake cable inside the fork leg.
Spud
Old 03-22-2013, 02:41 PM   #56707
wyoxr
wyoxr's Avatar
Oddometer: 29
Thanks Taco, I had a local machinist turn a bushing that pressed onto the xr stem then into the wr triple. The bushing ended up havin a double shoulder to allow for the circlip groove.
I had to have a little thickness machined off of the top clamp to allow for the length that was lost in to the stem bushing. The Yamaha top clamp has two threaded bosses on the right side for the stock odometer, the spacing is a little to wide for the xr key switch so I only used one bolt for now. For the gauge cluster I drilled and tapped two holes in the top clamp and made a couple spacers out of hardware store bushings to get it mounted up.
The brake calipers are the exact same part so that was easy. The honda brake line was just a little too short to get routed properly, so I swapped it out with the Yamaha line. The honda brake line has a slight bend at the master cylinder banjo bolt and the Yamaha does not but I was able to make it work.
Jason
2008 XR650L
wyoxr is offline   Reply With Quote
Old 03-22-2013, 02:45 PM   #56708
tedmagnum
Ted_Magnum UK
Oddometer: 99
Well I would assume sub-standard components then.... You've done pretty much everything you can.
When we PDI bikes we're meant to use the bikes on-board pressure sensors but we use our physically calibrated unit built into our airline.
I always recommend people use it as a guide only.....
Old 03-22-2013, 02:56 PM   #56709
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,127
Thanks for the info.
Cheers!!!
Regards
Fritzcoinc
Old 03-22-2013, 03:47 PM   #56710
Mossy-Back
Wet-Sider
Mossy-Back's Avatar
Oddometer: 1,646
Woohoo! Sold my old white 4.0 gallon tank. Almost made enough to cover the cost of my 4.7 gallon tank. Loving it so far. The black looks SO much better than the old yellowing white tank, and the extra fuel won't hurt.
I'd post a picture, but it's pouring rain right now...
'05 CRF450X
Once a Marine, always a Marine!
Mossy-Back is offline   Reply With Quote
Old 03-22-2013, 04:39 PM   #56711
mcma111
mcma111's Avatar
Oddometer: 12,431
Rain
Sucks to be you.
62' and not a cloud in the bright blue sky.
Been riding around all day doing errands.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 03-22-2013, 04:41 PM   #56712
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,330
Originally Posted by mcma111 View Post
Sucks to be you.
You gotta stop rubbin it in.......FFS......
Back to drinkin........you too Steve
B
techforlife is offline   Reply With Quote
Old 03-22-2013, 04:50 PM   #56713
JWhitmore44
pistolero
JWhitmore44's Avatar
Oddometer: 1,622
Sucks to be you.
B
+1 Getting ready for another "spring" blizzard. Supposed to move in tonight (actually tomorrow morning) and drop 8 to 14 inches. A lot of that will be getting blown around tomorrow. I'm bout ready to head south for the spring
84 Honda Goldwing (GL1200)
03 XR650L
JWhitmore44 is offline   Reply With Quote
Old 03-22-2013, 04:53 PM   #56714
taco250
wannabe adventurer
taco250's Avatar
Oddometer: 1,329
What year WR was it? I'm guessing '99 or 2000? Which rim/axle did you use?
Prov 3:5 & 6
Old 03-22-2013, 05:03 PM   #56715
XR650L_Dave
Oddometer: 3,755
Originally Posted by katbeanz View Post
I stole it from Flying Eyeball, Blakebird found the vid it's from.
I don't think it's an xrl
Of course not, if it were all the water would have splashed out of the creek!
---->>Thanks for the rotor, guys!<<----
XR650L_Dave is offline   Reply With Quote
Times are GMT -7.   It's 04:54 AM.
