Old 03-29-2013, 02:19 PM   #57046
Kilroy_1911
Kilroy_1911's Avatar
Oddometer: 168
Sorry bout the picture size...
And yes, I am utilizing a 45 cal bead offset tool
Kilroy_1911 is offline   Reply With Quote
Old 03-29-2013, 02:51 PM   #57047
ONandOFF
-ROAD-
ONandOFF's Avatar
Oddometer: 6,938
Originally Posted by Dorsland View Post
Time for another XRL pic:
Why does "darkest Africa" look like it could be Virginia?
Let's ride!!! - No offense, but there've been a lot of people over time who were just as sure, yet got it wrong. - Una necedad, aunque la repitan millones de bocas, no deja de ser una necedad. - "you know that I could have me a million more friends and all I'd have to lose is my point of view" (Prine)
ONandOFF is offline   Reply With Quote
Old 03-29-2013, 04:14 PM   #57048
MyFriendofMissouri
Oddometer: 35
bad gas mileage
my bike has been getting terrible gas mileage. i started noticing it about 6 months ago. i have a 5.8 gal tank and every time i would fill up i would lose 5 to 10 mpg. it could get 55 mpg pretty easy but now im down to about 35. doesnt seem like it has lost any power but top speed has went from 95 to 75.
trying to fix it i have:
replaced the spark plug (didnt help)
checked valves (still in spec, no changes since initial adjustment)
changed oil (doesnt seem to make a difference. i use ams oil or rotella synthetic)
replaced chain and sprockets (gained 5-10 mph, now will do almost 85)
disassembled carb (clean as a whistle, slide free, float not sticking as far as i can tell. no visible wear. it doesnt seem like anything is flowing out of the over flow tube)
checked wheels for free spinning (no problems, brakes not dragging)
played with tire pressures (still nuthin)
removed exhaust baffle and ground away the welds on inside of header (ran out of ideas so now im just screwing around. gained some power but now the bike sounds pretty dumb, btw.)
may run a compession test some time but im sure its ok
it is a 2012 with 13,500 miles on it.
daves mods with 55/158 jets and 0.20 shim
uni filter with snorkle removed
smog block off
stock gearing
whats going on???
MyFriendofMissouri is offline   Reply With Quote
Old 03-29-2013, 04:55 PM   #57049
Ben99r1
Ben99r1's Avatar
Oddometer: 3,081
MYFriend. You have a air leak. It was cause by your thorthol cables being to tight. I had the same problem it took me months to figure it out. Here look at this picture to see where the leak is coming from. Its leaking from the little circlip under where the chock cable bolts into the carb. Turn on the bike and spray some carb cleaner or break cleaner at the circlip. If the rpm changes is leaking from the shaft at that spot. The bad news is the fix is going to be a new carb.
Ben99r1 is offline   Reply With Quote
Old 03-29-2013, 05:24 PM   #57050
gammel
gammel's Avatar
Oddometer: 547
Or California
Bergie
gammel is offline   Reply With Quote
Old 03-29-2013, 05:27 PM   #57051
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,752
Or NY
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Go forth and be a force of the awesome!
kenny61 is offline   Reply With Quote
Old 03-29-2013, 05:51 PM   #57052
rmhrc628
rmhrc628's Avatar
Oddometer: 2,622
Originally Posted by reddesertwonderer View Post
Well boys and girls. After finger blasting my computer many many times And reading all the info I could on the more economic dual sports DR,KLR,and XRL and XRR. I pulled the trigger yesterday and picked up a 09 L. I dropped 4 grand like it ment nothing on a bike with 611 miles on it! Yes I have found it is TALL! Lol but man talk about a great bike. It is dead stock for now but plans to remedy that include tank, skid plate, Big Gunn,Carb work,Xrr front sprocket, Rad Cush Drive,606's Cyclops 7inch adventure headlight,case saver and decent disk grads,Wolfman bags or maybe the Giant Loop or Dirt Bags . Oh ya and lose the octopus hanging off the left side of the motor! Thank you fellow riders for all the great info. And keep it coming I'm a roast...bast me!
Maybe do my under the seat battery mod so you can do mount the xr600 lhs side cover ?
rmhrc628 is offline   Reply With Quote
Old 03-29-2013, 06:38 PM   #57053
Ray Paul
Oddometer: 53
Originally Posted by mcma111 View Post
Kilroy,
Perhaps you can make your pictures just a bit
BIGGER!!!
That's funny ! Same thing i was thinking !
Ray Paul is offline   Reply With Quote
Old 03-29-2013, 06:43 PM   #57054
Ray Paul
Oddometer: 53
Originally Posted by fritzcoinc View Post
He He.
See what i use to plug a hose:
Damn dude, that thing been rode yet ?
Old 03-29-2013, 06:44 PM   #57055
Sycklemotor
Oddometer: 184
Originally Posted by purpledrake View Post
All B&W. This is going to be beautiful.
My thoughts exactly! I've been wanting to build this bike for a few years now and have thought a lot about how to do it.
I have built several BMW GS's and have always used the black/white theme , so I guess it's now my trademark of sorts.
Got the Warp 9 wheels in ( all black with stainless spokes). First purchase from them and they look good. Was contemplating Excel rims with Talon hubs laced by Woody's but recently saw some Warp 9 wheels and gave them a call.Very good pricing , so I went with those.
Parts are coming in and I'm getting everything laid out.
I will be sending the motor to CW for the 711 motor kit.
Here's the motor list
CW rod and piston
Ported and Polished
Big fin cylinder
Black powder coat
2nd and fifth gear change
Stainless steel valves
Hardened rockers
Oil pump modification
New cam etc., etc, etc,
Motor build is supposed to be about 6-8 weeks so I'll be working on the frame and suspension.
I will start with photos next week and will try to keep everyone posted on the build.
Sycklemotor is offline   Reply With Quote
Old 03-29-2013, 06:44 PM   #57056
RZRob
RZRob's Avatar
Oddometer: 1,693
For the last few years I've been serving as a corner worker at Seca. Best seat in the house and you get paid for it.
RZ Rob
RZRob is offline   Reply With Quote
Old 03-29-2013, 06:49 PM   #57057
RZRob
RZRob's Avatar
Oddometer: 1,693
Originally Posted by MyFriendofMissouri View Post
my bike has been getting terrible gas mileage. It could get 55 mpg pretty easy but now im down to about 35. doesnt seem like it has lost any power but top speed has went from 95 to 75.
whats going on???
You've probably come to terms with the bike and don't baby it like you did when it was new. Your mileage is about what I get - and always got. Can't talk abou the top speed, but I'm not comfortable going much over 75 on mine either.
RZ Rob
Old 03-29-2013, 06:57 PM   #57058
Ray Paul
Oddometer: 53
CW rod and piston
Ported and Polished
Big fin cylinder
Black powder coat
Hardened rockers
I'm jealous !
Old 03-29-2013, 06:59 PM   #57059
Ray Paul
Oddometer: 53
RZ Rob
I'm jealous !
Old 03-29-2013, 07:15 PM   #57060
mcma111
mcma111's Avatar
Oddometer: 12,553
Now I've Done It
Oh Snap
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Times are GMT -7.   It's 01:29 AM.
