Old 04-17-2013, 05:48 AM   #57736
ONandOFF
-ROAD-
ONandOFF's Avatar
Oddometer: 6,635
Let's ride!!! - No offense, but there've been a lot of people over time who were just as sure, yet got it wrong. - Una necedad, aunque la repitan millones de bocas, no deja de ser una necedad. - "you know that I could have me a million more friends and all I'd have to lose is my point of view" (Prine)
ONandOFF is offline   Reply With Quote
Old 04-17-2013, 06:53 AM   #57737
Cumbacheech
XRated
Cumbacheech's Avatar
Oddometer: 823
Chain
Hi Everyone,
I need to get some input on non-O-ring chains. I want to pick up a shorter chain for my supermoto setup and many people have said that a O or X ring chain is not required for road use. What are your thoughts??
I also posted this under sumo thread, but i figured i would post it here first... After all nobody knows the XRL better than you guys!
Cheers,
Cumbacheech
2001 XR650L - Done for now...!!
Pics: Adventure setup, SUMO setup, Dirt setup
Cumbacheech is offline   Reply With Quote
Old 04-17-2013, 06:59 AM   #57738
elsalvadorklr
southern xr rider
Oddometer: 4,154
this is true for sand riding too or motocross
get a very good quality, did, rk or any other roller chain with no rings...some are gold plated and say stuff like extra high tensile, or race only blah blah blah
use atf to clean and use oil to lube like trans gear oil, thick stuff
thats what I use on my bike...(i dont get the most expensive chains though)
cheers
elsalvadorklr is offline   Reply With Quote
Old 04-17-2013, 08:26 AM   #57739
bwalsh
bwalsh's Avatar
Oddometer: 11,914
Originally Posted by ThumpnRed View Post
Grip heaters... one of the BEST additions I have made to my bike
The last few mornings commuting in to work. Temps in the low 30's. Having to let my hands cool off at stop lights... PRICELESS!
Using the throttle tube on the left side...its warmer than the right side!
I may pull the right side off and realign the heating pad so it matches the left. I installed it so the middle of the heat pad(where the wires attach) is on the bottom. The left side is just the opposite. Hence the reason the left is warmer than the right. Just need to figure out where to route the wires once I do that so they're not getting in the way.
2004 XR650L
NWVA TAG NWVA TAG MAP RTE THREAD & IN LIST
bwalsh is offline   Reply With Quote
Old 04-17-2013, 08:29 AM   #57740
bwalsh
bwalsh's Avatar
Oddometer: 11,914
Originally Posted by fritzcoinc View Post
Hows that sign working out for you? Any beer show up at your door yet?
2004 XR650L
Old 04-17-2013, 08:40 AM   #57741
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,555
I used two two layers of heat shrink tubing on the left side. My right side grip might be a tad warmer, but they are very close to the same. I run both of my wires out the top. I ran the two wires on each side through a length of heat shrink tubing so the are one. On the throttle side I poked two small holes in the grip flange and zip tied the wires to the grip.
As far as wiring, I run the positive side through a relay so I can't kill the battery when I leave the toggle on. I also replaced the resistor with a thermal turn signal flasher.
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Old 04-17-2013, 10:02 AM   #57742
Cumbacheech
XRated
Oddometer: 823
If I remember correctly you have some pics of how you did the install. I can't search this thread for the life of me... Can you direct me to the post?? I want to do this mod in the near future.
Cheers,
Cumbacheech
Old 04-17-2013, 12:05 PM   #57743
pngaudioguy
Just...one...more...
pngaudioguy's Avatar
Oddometer: 502
Quick question for the video folks - do you use some kind of image stabilization on the stuff you post? I filmed my commute to and from work today. Both directions seemed like the camera was shaking quite a bit. Granted, the roads here aren't all that smooth. I had my GoPro mounted on top of my helmet with the curved adhesive mount, and the lowest profile adapter. Any suggestions?
pngaudioguy is offline   Reply With Quote
Old 04-17-2013, 12:32 PM   #57744
duckrogers666
Formerly Flying Cow
duckrogers666's Avatar
Oddometer: 40
Got the dash mostly squared away today. I might actually have this thing back on the trail sometime soon!
Hey ThumpnRed, I'm curious to know what thickness you used for your dash setup??? And have you noticed any vibrations from the dash? I.E. bouncing up and down? I'm still pre-planning my new dash and don't want to add to much weight but I do have to take into consideration the weight of my Zumo 450 and how far out in front of the bars it will be mounted....
Thanks!!!! And it looks great by the way!!!
82' GPZ 750 R1
93' ZX6E
93' XR650L
"...listen mister, you better not forget what you don't know!" ex-girlfriend
duckrogers666 is offline   Reply With Quote
Old 04-17-2013, 12:33 PM   #57745
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,555
Cheers,
Cumbacheech
It'll take me longer to find it than it will to do it over.
Wiring diagram:
Not current, but what it looked like when first installed. The relay's bolted to the top triple:
Old 04-17-2013, 02:27 PM   #57746
katbeanz
earthbound misfit, I
katbeanz's Avatar
Oddometer: 7,779
Wiring diagram:
Nice work, Amigo.
katbeanz is offline   Reply With Quote
Old 04-17-2013, 05:13 PM   #57747
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,329
B
techforlife is offline   Reply With Quote
Old 04-17-2013, 05:34 PM   #57748
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,555
1/8th inch. There isnt much weight on it so I dont worry about flex. It is rock solid... no noticeable vibration at all. I have had it at highway speeds and trail duty and it has done great with both.
Old 04-17-2013, 05:35 PM   #57749
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,555
Originally Posted by katbeanz View Post
Nice work, Amigo.
Old 04-17-2013, 06:13 PM   #57750
Hazman27
The Haz
Hazman27's Avatar
Oddometer: 680
Found some Pro Tapers?
Woods bend high, Pro Taper Aluminum Taperwall ..$50 bucks Never put on, Is this a good price, good alternative to Fly Bars? 1 7/8 or 1 1/8 ? I cant read the bar code, gonna seal the deal I guess
Hazman27 is offline   Reply With Quote
Times are GMT -7.   It's 04:48 AM.
