Old 04-30-2013, 08:49 PM   #58171
bwalsh
bwalsh's Avatar
Oddometer: 11,510
Originally Posted by mcma111 View Post
Sorry sonny the way to check if the cam chain is stretched is to put the engine at TDC and then check the cam timing alignment marks. If the marks at 9 and 3 o'clock don't line up with the edge of the head THEN the cam is stretched. BTDT....
Originally Posted by techforlife View Post
True......but if the chain lifts easily off the sprocket it is stretched too...just like a drive chain.........either way works well..alignment marks being off is definately a clear sign,,unless the head has been shaved,then the alignment marks will be off even with a new chain..
B
Now that I think about it the chain could be stretched and letting the timing "roam", hence the on again and off again noise. It sounds just like a loose rocker arm striking the valve stem...
Hey Walter, I'm curious...you have 90,000 miles on your XR. Have you replaced the Cam chain & sprockets on your engine? If so, at what mileage?
I think I'm going to start getting some parts together. The engine uses a little more oil then normal. I may pull the piston, hone the cylinder and slap some new rings on the piston while I have it apart. Next time it needs work I'll talk to CW.
Originally Posted by joexr View Post
I slotted my cam sprocket. Found a happy spot at 3 degrees retarded.
Who was wondering awhile back how to change the timing on the XRL? This mod would do it! Interesting...
That's one of the mods some folks do to a Cummins to change the timing.
2004 XR650L
NWVA TAG NWVA TAG MAP RTE THREAD & IN LIST
bwalsh is offline   Reply With Quote
Old 04-30-2013, 09:00 PM   #58172
bwalsh
bwalsh's Avatar
Oddometer: 11,510
Originally Posted by Spud Rider View Post
Also, you can't beat the price.
Spud
Originally Posted by kenny61 View Post
x2
+1000!
I was going with the double takes but $11 a mirror verses $50 a mirror...Ken Sean's it is...er was!
2004 XR650L
Old 04-30-2013, 09:14 PM   #58173
joexr
Oddometer: 3,773
I also slotted the holes on my pulse generater to advance the ignition.
Old 04-30-2013, 09:28 PM   #58174
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,578
I slotted my sprocket bolts and advanced them 6.7* and my rotor bolts and retarded them 2.05* My bike now accelerates and stops faster than anybody elses
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Go forth and be a force of the awesome!
kenny61 is offline   Reply With Quote
Old 04-30-2013, 09:33 PM   #58175
Walterxr650l
Walterxr650l's Avatar
Oddometer: 1,256
Yes, at about 55,000 miles. Then I replace the motor at about 70,000 miles.
Walter
"How much a dunce
That has been set to roam
Excels a dunce
That has stayed at home."
Walterxr650l is offline   Reply With Quote
Old 04-30-2013, 09:40 PM   #58176
Spud Rider
Spud Rider's Avatar
Oddometer: 3,771
+1000!
I suggest you don't buy either the Emgo, or the Baja Designs copies. Make sure you purchase either the Ken Sean, or the Bikemaster mirrors. The Emgo mirror is less expensive, but it is inferior.
The Ken Sean mirrors are larger in diameter, and slightly convex. The Emgo mirrors are flat. Also, the screws which tighten the Emgo mirrors to the stem are threaded directly into plastic, and will loosen. The screws for the Ken Sean mirrors are tightened into a nut which is embedded in the plastic.
http://www.thumpertalk.com/topic/768...olding-mirror/
The Bikemaster mirrors are the exact same mirrors as the Ken Sean mirrors. However, the Ken Sean mirrors come with installation instructions, and the Bikemaster mirrors do not. If you get a better deal on the Bikemaster mirrors, here's a link to the installation instructions.
http://www.sandslave.com/2003wr250f/mirrors/index.html
Spud
Spud Rider screwed with this post 04-30-2013 at 10:10 PM
Old 05-01-2013, 06:19 AM   #58177
smokeeater495
smokeeater495's Avatar
Oddometer: 603
If I do replace the clutch disks what aftermarket brands are good?
Harley, been there done that. Don't want to be a pirate.
smokeeater495 is offline   Reply With Quote
Old 05-01-2013, 06:56 AM   #58178
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,538
Did you advance your countersprocket also? Harder to do, but there is some serious midrange power to be had there. It's easiest if you just grind out the middle of the sprockie, degree it on the shaft and then weld it on. Little known secret.... I learned it from the PO of my bike. You heard it here first!
The hot set-up!
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Old 05-01-2013, 07:36 AM   #58179
mcma111
mcma111's Avatar
Oddometer: 12,097
I have had good results with EBC clutch kits. Except one time the wrong, to short springs were in the kit. Opps.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-01-2013, 07:36 AM   #58180
RZRob
RZRob's Avatar
Oddometer: 1,579
I don't like giving up secrets, but hey, we're family. Have you tried putting a smaller front tire on these bikes? It makes them go faster. I didn't believe it until I looked on the speedometer.
RZ Rob
RZRob is offline   Reply With Quote
Old 05-01-2013, 07:51 AM   #58181
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 6,973
Are you high?
There is no friggen way a delta of 4.65 deg. could produce the results you are describing.
Now if, and ONLY if, the TARSC ( total advance/retard setting change ) was 4.732 deg. NOW you would have something to brag about. Simply put 4.65 is insufficient.
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 05-01-2013, 07:58 AM   #58182
JT
JT's Avatar
Oddometer: 344
My XRL always shifted stiff and notchy and was almost impossible to find neutral no matter how the cable was adjusted. It seemed a little better on fresh oil, but not much. The only way to find neutral was to blip the throttle while trying. Finally dropped in a $50 RMATV clutch kit and its like a new bike. Shifts smooth and slick and neutral is first time every time. Make sure to order and replace the o-ring for the oil pump to side cover fitting.
JT
JT is offline   Reply With Quote
Old 05-01-2013, 08:58 AM   #58183
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,306
Originally Posted by JWhitmore44 View Post
Mine is doing the same thing with a little over 7000 miles on it. I used Delo 15w-40LE diesel last 2 oil changes. I have new clutch packs on order About he only way I can find neutral is to kill the motor and shift once I'm stopped. Guess I'll see how the friction material looks on the plates when I change them.
Usually the plates(steels) are warped too......best to do it all together.WITH SPRINGS..
B
techforlife is offline   Reply With Quote
Old 05-01-2013, 09:02 AM   #58184
techforlife
CDI REPAIR
Oddometer: 4,306
Originally Posted by fritzcoinc View Post
Are you high?
Don`t need to if Fritz gets the sprocket coated with teflon,,,
B
Old 05-01-2013, 09:28 AM   #58185
Northern Hooligan
Northern Hooligan's Avatar
Oddometer: 140
Although its still snowing... off and on in Edmonton, I have gone for a few rides on my newly acquired XRL and it will need new tires soon. The current D606 seem to be ok, but I will do more road travel until I get to the BC area where I will head into woods. My 50/50 tire of choice is leaning towards the K60's. The PO of the bike switch the stock tires to the D606 and they lasted only 4500KM ( 5200km on it now )
So, my question: Has anyone purchased the Heidenau K60 in the stock form 120/90-18..... only to go "damn, should have bought the 140" ?. The price difference here is about $70.00 to go to the 140, which I do not mind spending. I see a few of you have done it with no mods required ( unless I skipped a post ).
G
Northern Hooligan is offline   Reply With Quote
Times are GMT -7.   It's 03:01 AM.
