Old 05-01-2013, 09:44 AM   #58186
JWhitmore44
pistolero
JWhitmore44's Avatar
Oddometer: 1,619
Originally Posted by smokeeater495 View Post
If I do replace the clutch disks what aftermarket brands are good?
I went with the Tusk kit from RMATV
http://www.rockymountainatvmc.com/p/...rm=tusk+clutch
It looked like folks had good luck with those kits. I've heard good things about the EBC's that Steve mentioned also.
fyi, I ordered the gaskets from a different source, including that little O ring like JT mentions.
84 Honda Goldwing (GL1200)
03 XR650L
JWhitmore44 screwed with this post 05-01-2013 at 09:53 AM
JWhitmore44 is offline   Reply With Quote
Old 05-01-2013, 09:47 AM   #58187
JWhitmore44
pistolero
Oddometer: 1,619
Originally Posted by techforlife View Post
Usually the plates(steels) are warped too......best to do it all together.WITH SPRINGS..
B
Gotcha, thanks! that's the plan.
03 XR650L
Old 05-01-2013, 09:51 AM   #58188
JWhitmore44
pistolero
Oddometer: 1,619
Originally Posted by JThompson View Post
My XRL always shifted stiff and notchy and was almost impossible to find neutral no matter how the cable was adjusted. It seemed a little better on fresh oil, but not much. The only way to find neutral was to blip the throttle while trying. Finally dropped in a $50 RMATV clutch kit and its like a new bike. Shifts smooth and slick and neutral is first time every time. Make sure to order and replace the o-ring for the oil pump to side cover fitting.
JT
Another confirmation that I have a worn clutch, thanks!
03 XR650L
Old 05-01-2013, 09:54 AM   #58189
mcma111
mcma111's Avatar
Oddometer: 12,254
Can't shift into neutral when at a stop?? Just hit neutral as your rolling to that stop. Geezzzz. Rocket science this ain't.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-01-2013, 10:20 AM   #58190
joexr
Oddometer: 3,773
Thumb
I've been doing this for years too.
Old 05-01-2013, 10:46 AM   #58191
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,000
Originally Posted by joexr View Post
i've been doing this for years too.
+1
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 05-01-2013, 10:48 AM   #58192
JWhitmore44
pistolero
Oddometer: 1,619
You can do that?
Currently this is working about 20% of the time.
03 XR650L
Old 05-01-2013, 11:02 AM   #58193
joexr
Oddometer: 3,773
In fact , I usally go from second into neutral.
Old 05-01-2013, 11:07 AM   #58194
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,643
Originally Posted by fritzcoinc View Post
Are you high?
There is no friggen way a delta of 4.65 deg. could produce the results you are describing.
Now if, and ONLY if, the TARSC ( total advance/retard setting change ) was 4.732 deg. NOW you would have something to brag about. Simply put 4.65 is insufficient.
Originally Posted by ThumpnRed View Post
Did you advance your countersprocket also? Harder to do, but there is some serious midrange power to be had there. It's easiest if you just grind out the middle of the sprockie, degree it on the shaft and then weld it on. Little known secret.... I learned it from the PO of my bike. You heard it here first!
The hot set-up!
I invented that set up. But its out of date.. I slotted my engine mounts and advanced the c/s along with the engine, cam , and ignition timing.. Top that mother fuckers
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Go forth and be a force of the awesome!
kenny61 is offline   Reply With Quote
Old 05-01-2013, 12:00 PM   #58195
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,328
I took the cam chain out,,machined new crank / cam sprockets and now run belt drive valve train..beat that fukers..
B
techforlife is offline   Reply With Quote
Old 05-01-2013, 12:55 PM   #58196
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,643
Mine runs on unicorn farts
Old 05-01-2013, 01:15 PM   #58197
gammel
gammel's Avatar
Oddometer: 524
I'm thinking this one's the winner!!
Bergie
gammel is offline   Reply With Quote
Old 05-01-2013, 01:22 PM   #58198
mcma111
mcma111's Avatar
Oddometer: 12,254
As illusive as unicorns are trying to catch it's farts is gonna be a real test.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-01-2013, 02:21 PM   #58199
Spud Rider
Spud Rider's Avatar
Oddometer: 3,777
This is the hands down winner. Contest over.
Spud
Old 05-01-2013, 02:45 PM   #58200
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,000
So your bike is already at the place you are going.
Regards
Fritzcoinc
Times are GMT -7.   It's 05:43 PM.
