Old 05-17-2013, 09:27 PM   #58801
Mero
Oddometer: 317
not at all. I wish I would have went with the diesel 2500 hd version now. specially when pulling the toy hauler. normally get 13-17mpg with the trailer it drops to 8. But it looks good. lol
Mero is offline   Reply With Quote
Old 05-17-2013, 09:30 PM   #58802
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,714
Originally Posted by Brown Falcon View Post
Yep, I bet the MPG's don't make you smile...
Mine is right around 700 ft/lbs... 7.3 V8
And I still get 19-20 mpg on the freeway.
17mpg. I need to bump the timing a few degrees
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Go forth and be a force of the awesome!
kenny61 is online now   Reply With Quote
Old 05-17-2013, 09:31 PM   #58803
Mero
Oddometer: 317
diesel is cheating. lol
Old 05-17-2013, 09:43 PM   #58804
RZRob
RZRob's Avatar
Oddometer: 1,666
Originally Posted by aksinha88 View Post
the stator wire where the exit the case, there is a "rubbery" block that the wires run through and it also plugs the case. Can a replacement be found???
I'll bet you any of the stator vendors have one. I'd eBay search stators for vendors and contact one like Rick's Electric. Just an idea.
RZ Rob
RZRob is offline   Reply With Quote
Old 05-17-2013, 09:59 PM   #58805
RZRob
RZRob's Avatar
Oddometer: 1,666
Originally Posted by marlinjames View Post
does anyone know how much are bikes weigh?
Has anyone ever tried the trailer hitch mounted bike carriers? I know I know I shouldn't trailer it anywhere. but I want to go riding with the gf who rides the quad only, and I wont let her drive the truck. LOL
http://www.cyclegear.com/CycleGear/A.../p/43630_00000
I've got that exact carrier (one of many) and wouldn't trust that for anything heavier than a 2-stroke (they're cheap). I've got better ones but of course they're heavy. I've got aluminum ones too that again, light, but not for big bikes.
I've carried my XRL on the MotoJack, but make sure your frame/hitch can handle 500 pounds.
RZ Rob
Old 05-17-2013, 10:13 PM   #58806
v8toilet
Nothing to see here.
v8toilet's Avatar
Oddometer: 1,741
I'm chasing a noise in my xrl top end after inspecting the rockers, subrockers, cam the only thing that looks and sounds like the rattle I'm hearing is the decompression unit. It sounds like it engages every revolution regardless of RPM. Could this be the case?
v8toilet is offline   Reply With Quote
Old 05-17-2013, 10:15 PM   #58807
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,714
Check your top engine mount...don't ask
Old 05-17-2013, 10:35 PM   #58808
v8toilet
v8toilet's Avatar
Oddometer: 1,741
It's not installed and still ticking.
Old 05-17-2013, 10:57 PM   #58809
Mero
Oddometer: 317
RZ Rob
Even with a 500lb rating you wouldn't trust it huh? That sucks. I want something inexpensive yet sturdy. Lol I know I know you get what you pay for. I'm sure my truck can handle 500 lbs. My 26' toy hauler has to have a heavier tongue weight than that.
Samsung Galaxy S3
Old 05-18-2013, 03:23 AM   #58810
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,330
Originally Posted by fritzcoinc View Post
Now how can you say one state or province is higher than another? Isn't the earth round? And there isn't an up or down in space.
Space........the final frontier,between Fritz's ears........
Just kiddin...
B
techforlife screwed with this post 05-18-2013 at 03:33 AM
techforlife is offline   Reply With Quote
Old 05-18-2013, 07:30 AM   #58811
aksinha88
YETI ADV RIDER
Oddometer: 86
RZ Rob
I ended up slicing the old piece to accomodate the new thicker gauge wires from the upgraded stator and slopped it up with black RTV gasket maker. Once I get her hooked up and running I'll see if the seals hold. Thanks for the tip!
YETI ADV RIDER
http://www.facebook.com/YetiAdventures
aksinha88 is offline   Reply With Quote
Old 05-18-2013, 08:54 AM   #58812
Mossy-Back
Wet-Sider
Mossy-Back's Avatar
Oddometer: 1,646
diesel is AWESOME!
Fixed it for you...
'05 CRF450X
Once a Marine, always a Marine!
Mossy-Back is offline   Reply With Quote
Old 05-18-2013, 09:22 AM   #58813
zulusafari
E African ADVRDR
zulusafari's Avatar
Oddometer: 299
Texas being the lowest state to the equator has a lower COG than any other state. Now some may argue but due to FL being on the edge vs center of the United States centrifical force and curvature of the earth keeps it from actually being so
+1
missing home
2006 XR650L - Nairobi, Kenya
zulusafari is offline   Reply With Quote
Old 05-18-2013, 09:26 AM   #58814
zulusafari
E African ADVRDR
zulusafari's Avatar
Oddometer: 299
Samsung Galaxy S3
I think he was referring to the hitch mounted on the car, not the carrier. There is usually two different weight measurements. One is tongue weight and one is hauling weight, not sure of the exact terms. All that matters is the tongue weight. I think anything that's decent can handle 1,000 lbs.
Old 05-18-2013, 09:39 AM   #58815
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,714
Your gonna want at least a class III hitch. you have to add the additional leverage to the weight of the bike because it is at least 12" from the actual hitch
Class III Trailer Hitch Receivers:
  • Designed for trucks, vans and sport utility vehicles
  • 2" x 2" receiver hitch opening
  • Rated up to 6,000 lbs GTW with 600 lbs TW
  • Allows for more gear to be carried or towed
  • Works with all Class III accessories, such as bike racks, cargo carriers, and tube covers
    • Class I and Class II (1-1/4") hitch accessories can also be used with an adapter
  • Ball mounts are sold separately.
  • NOTE: Most manufacturers call any hitch with a 2" x 2" opening a Class III hitch
    • It is not uncommon to see a 2" hitch rated at 3,500 lbs GTW called a Class III hitch
  • Available in square and round tube designs.
Class II Trailer Hitch Receivers:
  • Designed for light-duty towing
  • Are rated up to 3,500 lbs GTW and 350 lbs TW
  • 1-1/4" x 1-1/4" receiver hitch opening
  • Will work with Class I and Class II accessories, such as bike racks, cargo carriers, and tube covers
  • Requires a Manufacturer-recommended, hitch specific drawbar or ball mount to tow a trailer
    • A 1/2" pin must be used to secure the ball mount in place.
    • Drawbars may be included with hitch or sold separately
  • Will work with hitch balls with 3/4" diameter shank
Times are GMT -7.   It's 12:27 PM.
