Old 05-19-2013, 07:54 PM   #58861
Hazman27
The Haz
Hazman27's Avatar
Oddometer: 681
Thanks to MrFixit and Bomber for converting the pics, I'll try harder next time
Hazman27 is offline   Reply With Quote
Old 05-19-2013, 08:07 PM   #58862
Hazman27
The Haz
Hazman27's Avatar
Oddometer: 681
Crick Crossing
[IMG][/IMG]
Old 05-19-2013, 08:42 PM   #58863
Mossy-Back
Wet-Sider
Mossy-Back's Avatar
Oddometer: 1,652
Very nice bike Hazman. Makes me want to consider going all black on my bike...
How's the handling off the pavement with the wide front tire?
'05 CRF450X
Once a Marine, always a Marine!
Mossy-Back is offline   Reply With Quote
Old 05-19-2013, 08:50 PM   #58864
aksinha88
YETI ADV RIDER
Oddometer: 86
Thats one good lookin ride Hazman. Any info on the wheels? Super moto kit or something you put together yourself? Did you keep the stock calipers? I was considering doing something with my wheels maybe next winter since I rarely (if ever) hit the trails and mostly ride backroads etc.
By the way since we're on the topic of wheels, anyone tried this plastidip stuff? I was thinking about coating my rims with it purely for cosmetic reasons.
http://www.plastidip.com/
YETI ADV RIDER
http://www.facebook.com/YetiAdventures
aksinha88 is offline   Reply With Quote
Old 05-19-2013, 09:29 PM   #58865
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,166
Originally Posted by joexr View Post
Hey Fritz , what's the coating on your engine cases and how was it applied ?
Its a PTFE coating. These guys applied it: http://www.polydyn.com/intake_manifolds.htm Bead blast first, then phosphate, then the PTFE coating. And it's available in several colors. This coating is good on guns as well. These guys do header coatings too.
I am experimenting with their coatings on several items. Mainly because here on the Gulf Coast corrosion is a problem especially when you ride on the beach a lot like me. The only one I can 100 % recommend is PTFE coating axles. With these coatings the axle slides right out and right back in. These coatings have excellent corrosion resistance. Additionally, anything coated is a snap to dissemble and reassemble. Nothing sticks to the coating, just like a non stick fry pan.
I hope something goes wrong with the carb on my Husky so I can tear it down and see how the coatings are holding up. After a year or so no need. I had some sprockets coated but I don't think I'll be able to tell if there is any improvement in their life vs an uncoated sprocket. there is just to many variables in operation.
When new:
And some three years later. I liked this coating because it just looks so OEM. No mas corrosion on the retainer or coated countershaft sprocket:
Newly coated:
Recent photo of clutch side:
You can see just a trace of the coating in the teeth. The coating starts with a phosphate coating first, then the PTFE. The PTFE actually gets into the tiny voids between the alloy crystals.
I can't say the coating improved the life of this countershaft sprocket, but it sure didn't hurt it; but note the absents of corrosion:
Axle:
I had my wheels relaced a while ago with stainless spokes. The old spokes started to break because they rusted away! I got the hubs coated, the cool thing here is that they are super easy to clean, nothing sticks to the coating.
This is a second axle set I had coated, note the contrasting axle and adjuster colors. OOOO ah:
Experiment in progress:
All steel items in my 86 Husky rear linkage I had coated:
Axles, spacers, brake mount bolts, all coated:
Same in back plus the drum brakes parts, backing plate and cams:
The carb, now this should be the nuts. No sorry ethanol sticking to my carb. Every parts coated, none lost:
Need to change jets? Come on in!:
Need to check the piston, bring a lantern:
This is pretty slick too:
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc screwed with this post 05-19-2013 at 09:35 PM
fritzcoinc is offline   Reply With Quote
Old 05-20-2013, 04:07 AM   #58866
Hazman27
The Haz
Hazman27's Avatar
Oddometer: 681
I normally steer with the rear, my style of riding. Point and shoot. The fat front does well in the loose loam, sand bearm, kinda floats instead of cutting in. I prefer the lower stance, gets me in to the turn earlier, then throttle out. I do ride 60% dirt and mud., 40% commute (40 miles daily) hence the Shinko 705's. Tire shop, know your options before doing the super motard thing. The rims I run are 17's and the fronts are more rare in the width I keep.
Old 05-20-2013, 03:29 PM   #58867
bwalsh
bwalsh's Avatar
Oddometer: 12,197
Originally Posted by ThumpnRed View Post
Great picture! Looks like a marketing shot for Honda... All it needs is a catchy tag line.
On the prowl.
2004 XR650L
NWVA TAG NWVA TAG MAP RTE THREAD & IN LIST
bwalsh is offline   Reply With Quote
Old 05-20-2013, 03:57 PM   #58868
joexr
Oddometer: 3,773
When new:
Newly coated:
Axle:
That's not Mrs. Fritz. What I was thinking about with the coating was my buddies BST40 carb slide and guides on his , dare I say it , DR650. They tend to wear. Thanx.
Old 05-20-2013, 04:14 PM   #58869
purpledrake
No Pretensions
Oddometer: 334
Originally Posted by bwalsh View Post
On the prowl.
Clever!
The Good Lord gave most of us 10 digits; mine are all thumbs.
purpledrake is offline   Reply With Quote
Old 05-20-2013, 07:20 PM   #58870
RZRob
RZRob's Avatar
Oddometer: 1,699
I'd like to coat that with my own PTFE....
RZ Rob
RZRob is online now   Reply With Quote
Old 05-20-2013, 08:31 PM   #58871
RZRob
RZRob's Avatar
Oddometer: 1,699
You know what really burns my pants?
I've like never had this problem before, but in the last couple years I noticed I'm continually burning my pants on my XRL & my riding gear on my CRF. It's really starting to piss me off.
Can anyone suggest a dainty pipe guard that really works - and looks "factory"?
RZ Rob
Old 05-20-2013, 09:01 PM   #58872
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,564
RZ Rob
I have never had a problem with that before this year. I rode out to the Honda shop during lunch one day and got back to work... sitting in a meeting and noticed that the cuff of my pants was fried! Same burn that you have on yours!
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Old 05-20-2013, 09:08 PM   #58873
absoluteclint
absoluteclint's Avatar
Oddometer: 206
Well that's the first skidmark I've seen at the bottom of a pair of pants.. Most seem to surface a little higher and more central to the ass cheeks... Particularly after being dared to hit a big jump, climb a waay too steep hill, etc.!!
Also... Is that Tupac keeping an eye on your bike for you??
absoluteclint is offline   Reply With Quote
Old 05-20-2013, 09:13 PM   #58874
RZRob
RZRob's Avatar
Oddometer: 1,699
We know how to party
No I dared a whiff and it's burned. Thought it might be dog crap myself.
Yep, that's Tupac. You know us Californian's
RZ Rob
Old 05-20-2013, 09:16 PM   #58875
Spud Rider
Spud Rider's Avatar
Oddometer: 3,815
RZ Rob
I like my DRC Heat Shield.
http://www.drcproducts.com/exhaust/d31-02/index.html
Spud
Times are GMT -7.   It's 07:11 AM.
