Old 05-24-2013, 12:51 PM   #59041
Walterxr650l
Walterxr650l's Avatar
Oddometer: 1,287
Originally Posted by kdennan View Post
Will the 650 support a heated jacket?
+ heated grips?
Heated jacket, yes.
Heated grips, yes.
Heated jacket, and heated grips, both at full power, NO.
Heated jacket, and heated grips, both on partial power, Maybe. This will depend on what kind of heat controllers you have.
Walter
"How much a dunce
That has been set to roam
Excels a dunce
That has stayed at home."
Walterxr650l is offline   Reply With Quote
Old 05-24-2013, 12:53 PM   #59042
thebigman
bout a dollar 3.98
thebigman's Avatar
Oddometer: 3,524
[QUOTE=ThumpnRed;21484705]
[QUOTE=techforlife;21484723]
Originally Posted by ThumpnRed View Post
B
[QUOTE=ThumpnRed;21483700]It'll look good with knobs mounted up
I knew when I posted I was gonna get fucked with .
Marko
08 xr650l ,99 xr650l, 10 HDXR1200X ,84atc200s 85atc200s, 80ct110 ,99xr70, 04xr650l ,
Dumb ass people do dumb ass things
thebigman is offline   Reply With Quote
Old 05-24-2013, 12:57 PM   #59043
thebigman
bout a dollar 3.98
thebigman's Avatar
Oddometer: 3,524
[QUOTE=fritzcoinc;21483938]
Originally Posted by therealbigman View Post
I've never seen pine trees in Galveston??????????????
Huntsville , where it came from .
Marko
Old 05-24-2013, 01:10 PM   #59044
XR650L_Dave
Oddometer: 3,761
Pikers, the lot a ya...
---->>Thanks for the rotor, guys!<<----
XR650L_Dave is offline   Reply With Quote
Old 05-24-2013, 01:44 PM   #59045
Jud
Jud's Avatar
Oddometer: 2,542
+ heated grips?
No,,,, not if both are run on "high". I have can either run my grips on high or my vest {and the vest uses less current than a jacket}. If your grips use a resister to control heat, it's basically on "high" all the time so you will have to run the jacket on low reguardless of where the grips are run.
Pics- http://s563.photobucket.com/albums/s...eon/?start=all
Places visited on two- http://s563.photobucket.com/albums/s...0two%20wheels/
Endeavor to Persevere
Blue Skies Coming
Jud is offline   Reply With Quote
Old 05-24-2013, 02:13 PM   #59046
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,332
Originally Posted by KyoXR View Post
Any chance you (or anyone else) could measure the height from the mounting surface to the knurled screw on that quick shot 3? I want to make sure it's not going to hit my starter,
I have read the quick shot 3 should work on my carb as well,
also how much did that quick shot 3 set you back? I'm trying to find the best price on one.
Looks like about 43mm .but it`s off at an angle so not sure where it`ll sit bolted in the bike yet..
B
techforlife is offline   Reply With Quote
Old 05-24-2013, 02:16 PM   #59047
KyoXR
Clouds, Snow, Rain
KyoXR's Avatar
Oddometer: 769
Steve hit it , That's about the cheapest your gonna get 1 for .
Thank you and Thank you.
2007 XR650L,
Looking to acquire a stock XRL choke plunger.
The multi-quote function is your friend.
It's surprising how idiots have good luck, I don't have good luck.
KyoXR is offline   Reply With Quote
Old 05-24-2013, 02:18 PM   #59048
KyoXR
Clouds, Snow, Rain
KyoXR's Avatar
Oddometer: 769
B
ok, cool, thanks, I'm gonna run out to the garage and take a preliminary reading.
2007 XR650L,
Old 05-24-2013, 03:02 PM   #59049
aksinha88
YETI ADV RIDER
Oddometer: 86
+ heated grips?
I'm currently rebuilding my L and just upgraded to a 260watt stator. I'm about to plug in my heated grips and a plug for my jacket aswell (in addition to my HID projector lights). I'll let you know how it goes if you're not in a hurry.
If you do decide to go ahead and plug things in I'd invest in a small voltmeter through ebay (got mine for $5-$10 calibrated with papers and all) that you can attach to your dash to keep an eye on things while you run your gear.
You can find the upgrade stator here http://www.procycle.us/bikepages/xr650l.html#electrical
YETI ADV RIDER
http://www.facebook.com/YetiAdventures
aksinha88 is offline   Reply With Quote
Old 05-24-2013, 03:47 PM   #59050
joexr
Oddometer: 3,773
Originally Posted by aksinha88 View Post
I think you and Steve were right! Just plugged the starter to the car battery and it spun right off the bat. I'll check the relays and grounds one more time, but looks like it is infact the doomed Battery.
So since I'm most likely getting a new battery, is it worth the money to pay more for a smaller battery and do the battery relocation under the seat? as mentioned in this post http://www.advrider.com/forums/showthread.php?t=666195
I mostly ride back and dirt roads, the occasional highway and have an arsenal of heated grips, jackets and hid projector lights waiting to be installed.
Thanks again ya'll
Cyclegear has LIFETIME BATTERIES.
Old 05-24-2013, 03:58 PM   #59051
aksinha88
YETI ADV RIDER
Oddometer: 86
It could be the battery. A while ago one of my XRL's started but stalled while on choke and as I tried to restart the engine I got nothing. No click, no lights, nothing. I was able to bump start the bike as I was on a hill. The battery decided to have a heart attack and that was that. New battery and all was good to go.
Just installed a new battery and my goodness is it happy to crank. You Sir are a wizard! Thanks
YETI ADV RIDER
Old 05-24-2013, 04:43 PM   #59052
Mero
Oddometer: 310
I'm using honda 10 40. Is it normal to burn a bit of oil? I was about full. Did about 250 miles now I'm roughly 3/4 a quart low. It's not leaking any where or coming out the exhaust. Bike is just under 4k miles on it
Samsung Galaxy S3
Mero is offline   Reply With Quote
Old 05-24-2013, 04:48 PM   #59053
aksinha88
YETI ADV RIDER
Oddometer: 86
I think thats normal, Kinda. I run the same oil and mine burns about the same amount and I havent seen any leaks or off colors exhaust smoke. How often do you change your oil and have you checked to see if the color of the oil is too dark when you do?
Samsung Galaxy S3
YETI ADV RIDER
Old 05-24-2013, 05:46 PM   #59054
mcma111
mcma111's Avatar
Oddometer: 12,578
The bill is in the mail.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-24-2013, 06:31 PM   #59055
RoadHawg14
CRASH
RoadHawg14's Avatar
Oddometer: 128
Please Help, Starting Issues After Bike Fell over
Please Help! XR650L
I've been out of town for some time, I get back hoping to ride. My son tells me me bike fell over on the left side not sure how long it was down. He tried to start it and it would not fire but did turn over.
When I got home I tried and the bike fired up rode for a few miles and it cut off. I changed the plug and cleaned out the carb.
Bike fired up and ran shut it off and went back today to ride and bike would not fire all it will do is turn over.
Any help in trying diagnose the problem so I may ride before I go back out of town would be helpful.
Life is not a journey to the grave with the intention of arriving safly in a pretty and well preserved body, But rather to skid in broadside, Thoroughly used up, Totally Worn Out and Loudly Proclaiming - WOW - WHAT A RIDE!
RoadHawg14 screwed with this post 05-24-2013 at 06:44 PM
RoadHawg14 is offline   Reply With Quote
Times are GMT -7.   It's 09:35 AM.
