Old 06-01-2013, 10:05 PM   #59386
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,412
Originally Posted by joexr View Post
Shouldn't that be Tiajuana ?
NO. That's how white people say it.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
beechum1 is online now   Reply With Quote
Old 06-01-2013, 10:15 PM   #59387
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,412
Originally Posted by aksinha88 View Post
Does anyone run a separate fuse panel for their accessories etc? Beechum1 recommended the Centech CP2 http://www.racerpartswholesale.com/p...ry_Fuse_Panels
Do I have any other reliable options? Also, im sure these come with instructions to install but is it fairly easy to run them through a key on/off?
Here is what I'm trying to run
1. Heated Grips
2. 12v oulet for gps/phone etc
3. Aux lights in the future
The always on circuit gets a cable directly from the battery. The switched power gets a leg from after whatever switch you happen to be running for on/off. the ground gets run to wherever you want on the frame or even back to the battery.
Easy Peasy.
and wiring cleanup:
Old 06-01-2013, 11:15 PM   #59388
aksinha88
YETI ADV RIDER
Oddometer: 86
Easy Peasy.
and wiring cleanup:
Well, when you put it that way. Thanks man. I think I'll be going with that.
Also, that is a ridiculous set up you've got there. I dont think I've ever seen pics of your ride. Got pics of it fully assembled? and what kinda sorcery do you have going on there?
YETI ADV RIDER
http://www.facebook.com/YetiAdventures
aksinha88 is offline   Reply With Quote
Old 06-02-2013, 12:09 AM   #59389
aksinha88
YETI ADV RIDER
Oddometer: 86
Question TT Vapor Speedometer
Anyone here install a Trail Tech Vapor speedometer cable WITHOUT DRILLING? I just dont like the idea of drilling into the caliper.
YETI ADV RIDER
Old 06-02-2013, 12:39 AM   #59390
Barron
M0DAH0LIC
Barron's Avatar
Oddometer: 2,454
Sure did man. I didn't or should I say wouldn't drill into my caliper. They have a cable that you can stick to the caliper, mine stayed just fine, but I doubled down with a zip tie. FWIW, I JB welded the magnet into my rotor where it is to this day also.
-Barron
1996 XR650L with a couple mods
If everyone brewed beer there would be no war.
Barron is offline   Reply With Quote
Old 06-02-2013, 02:52 AM   #59391
aksinha88
YETI ADV RIDER
Oddometer: 86
-Barron
Sweet! Think you could post some pics brother? Also, do you remember or have it noted down what your calculated wheel size came up to? (i.e if you have the stock L front wheel)
YETI ADV RIDER
Old 06-02-2013, 03:13 AM   #59392
Dooga
Adventure Tourer
Dooga's Avatar
Oddometer: 304
Like most people said on here, just mount it to the fender. Drill holes in the plates (at your own risk) or on the fender and make sure the little clear slit at the bottom of the tail light makes it semi readable.
I am going to go that route. Thank you!
1995 BMW K1100LT
Dooga is offline   Reply With Quote
Old 06-02-2013, 04:24 AM   #59393
mcma111
mcma111's Avatar
Oddometer: 12,404
Your not drilling in to the caliper but the caliper to fork bracket. It's only a 1/8" hole. No big deal.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-02-2013, 08:06 AM   #59394
katbeanz
earthbound misfit, I
katbeanz's Avatar
Oddometer: 7,780
Is Dr. Steve on call?
http://advrider.com/forums/showthread.php?t=892027
katbeanz is offline   Reply With Quote
Old 06-02-2013, 08:20 AM   #59395
mcma111
mcma111's Avatar
Oddometer: 12,404
Originally Posted by katbeanz View Post
Top end smoked.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-02-2013, 08:30 AM   #59396
katbeanz
katbeanz's Avatar
Oddometer: 7,780
Top end smoked.
That sucks, Ophir is one of the easy ones.
Old 06-02-2013, 08:56 AM   #59397
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,412
Herro everybody!!
I just got an FCR-MX-39 skeleton, and it's missing a few parts. Mostly notably, the entire slide/needle assembly and the hot start. The rest I can pickup here or there, but the cost of those parts new are very scarey. Anyone have parts bin I can pull from?
Old 06-02-2013, 10:14 AM   #59398
kdennan
kdennan's Avatar
Oddometer: 624
Originally Posted by XR650L_Dave View Post
File the tab on the bowl, not the screw.
If you have a small file you can file the bowl tab with the carb and bowl in place.
The more annoying issue is the stumbling or hesitation from just open to 1/4 throttle. That's the pilot. Too lean?
If it is totally necessary, I'll file the tab. I just don't want to do any mods outside of replacing the pilot and main jets, removing the snorkel and adding an FMF Q
I should have the smog removal kit tomorrow or tuesday so I'll pull the carb then.
"F#%* you I won't do what you tell me!"
Rage Against The Machine
kdennan screwed with this post 06-02-2013 at 11:13 AM
kdennan is offline   Reply With Quote
Old 06-02-2013, 10:32 AM   #59399
zulusafari
E African ADVRDR
zulusafari's Avatar
Oddometer: 299
Aftermarket Dash
Does anyone make a bolt-on, aftermarket dashboard to fit our bikes?
2006 XR650L - Nairobi, Kenya
zulusafari is offline   Reply With Quote
Old 06-02-2013, 10:44 AM   #59400
Stretch67
Bent, But Not Broken
Stretch67's Avatar
Oddometer: 6,662
Never-installed Cigar Mike's centerstand in the Flea Market:
http://advrider.com/forums/showthread.php?t=892238
IBA # 33113
Alaska
Blue Ridge Parkway & Outer Banks
XR400 Index
Stretch67 is offline   Reply With Quote
Times are GMT -7.   It's 12:15 PM.
