Old 06-02-2013, 11:51 AM   #59401
marlinjames
Oddometer: 276
Does anyone know if you can use a center stand and the side stand? Not at the same time but have both on the bike
Samsung Galaxy S3
marlinjames is offline   Reply With Quote
Old 06-02-2013, 11:57 AM   #59402
marlinjames
Oddometer: 276
Originally Posted by Barron View Post
Sure did man. I didn't or should I say wouldn't drill into my caliper. They have a cable that you can stick to the caliper, mine stayed just fine, but I doubled down with a zip tie. FWIW, I JB welded the magnet into my rotor where it is to this day also.
-Barron
I had to do the exact same thing. I even called trail tech and they told me I needed the stick on type sensor and to silicone the magnet to the rotor
Samsung Galaxy S3
Old 06-02-2013, 12:11 PM   #59403
b3h
ol dog on a stray
b3h's Avatar
Oddometer: 181
Samsung Galaxy S3
Yep
b3h is online now   Reply With Quote
Old 06-02-2013, 12:14 PM   #59404
Stretch67
Bent, But Not Broken
Stretch67's Avatar
Oddometer: 6,291
NX650 Second Gear for sale in the Flea Market...
http://advrider.com/forums/showthread.php?t=892245
IBA # 33113
Alaska
Blue Ridge Parkway & Outer Banks
XR400 Index
Stretch67 is online now   Reply With Quote
Old 06-02-2013, 12:18 PM   #59405
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,576
Busy day in Dr. Steves emergency room
http://advrider.com/forums/showthread.php?t=892234
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Go forth and be a force of the awesome!
kenny61 is offline   Reply With Quote
Old 06-02-2013, 12:28 PM   #59406
Deliverator
not a replicant
Deliverator's Avatar
Oddometer: 79
Originally Posted by mcma111 View Post
Top end smoked.
On which bike?
“Strength does not come from physical capacity. It comes from indomitable will.” -Ghandi
Deliverator is offline   Reply With Quote
Old 06-02-2013, 12:45 PM   #59407
mcma111
mcma111's Avatar
Oddometer: 11,888
Originally Posted by Deliverator View Post
On which bike?
Keep up will ya??? Geezzzzz
http://advrider.com/forums/showthread.php?t=892027
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-02-2013, 12:52 PM   #59408
Deliverator
not a replicant
Oddometer: 79
This is telemedicine then?
Old 06-02-2013, 12:54 PM   #59409
mcma111
mcma111's Avatar
Oddometer: 11,888
Hold it up to the phone so I can get a better look at it.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-02-2013, 01:06 PM   #59410
super samurai
super samurai's Avatar
Oddometer: 316
I think my Cdi is failing
Sometimes after a short run the bike will not start.
Last night I tapped on the plastic under the seat and it started.
It did this to me last year but only a few times.
So where is the best place to buy a new one at and also is there any instructions on fixing the common problem with them.
I know tech for life I believe fixes them and I would like to fix it myself.
Buying a new one is not out of the question as I have the money.
Thanks brian
i know my clear tank is ugly!
super samurai is offline   Reply With Quote
Old 06-02-2013, 01:19 PM   #59411
Deliverator
not a replicant
Oddometer: 79
Thanks brian
Check the wiring first to see if there's a short of some kind.
Old 06-02-2013, 01:43 PM   #59412
Spud Rider
Spud Rider's Avatar
Oddometer: 3,758
Thanks brian
Here's a link to Brian's thread on this topic.
http://www.thumpertalk.com/topic/881...lp-cdi-repair/
I would buy a new, OEM CDI unit from one of the online parts vendors, and keep the repaired CDI unit as a spare.
http://www.servicehondapsn.com/fiche...13&fveh=162565
However, you can also buy an aftermarket CDI unit from Germany. I don't have a link for that vendor.
Spud
Old 06-02-2013, 02:07 PM   #59413
XR650L_Dave
Oddometer: 3,724
Originally Posted by kdennan View Post
The more annoying issue is the stumbling or hesitation from just open to 1/4 throttle. That's the pilot. Too lean?
If it is totally necessary, I'll file the tab. I just don't want to do any mods outside of replacing the pilot and main jets, removing the snorkel and adding an FMF Q
I should have the smog removal kit tomorrow or tuesday so I'll pull the carb then.
I didn't follow the thread from the start- if you're stock it's probably lean.
If you diverge from the recipe, results are uncertain.
---->>Thanks for the rotor, guys!<<----
XR650L_Dave is offline   Reply With Quote
Old 06-02-2013, 02:10 PM   #59414
RonZacapa
RonZacapa's Avatar
Oddometer: 61
Cdi
There you go:
http://www.motorbike-shop.de/index.php?a=3153&lang=eng
I replaced my CDI about 2 months ago with one of these units. Service was good, shipping was cheap and if you tell Götz to drop the Mehrwertssteuer (VAT) the unit will ship for I think 19% less.
Very happy with mine so far.
RonZacapa is offline   Reply With Quote
Old 06-02-2013, 02:34 PM   #59415
purpledrake
No Pretensions
Oddometer: 334
Thanks brian
That sucks, Brian.
I have a new one (spare) that you can use in the meantime. I also have an old one (dead) that needs to be repaired. If you are going to do the brain surgery (lots of solder work), use my dead CDI as a test case.
The Good Lord gave most of us 10 digits; mine are all thumbs.
purpledrake is offline   Reply With Quote
Times are GMT -7.   It's 03:33 PM.
