Old 06-14-2013, 05:59 AM   #59866
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,513
Group buy?
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 06-14-2013, 07:26 AM   #59867
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,161
Originally Posted by mcma111 View Post
Fritz,
How about you putting that link in your signature line?
You got it Steve!
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 06-14-2013, 07:44 AM   #59868
mcma111
mcma111's Avatar
Oddometer: 12,549
Originally Posted by fritzcoinc View Post
You got it Steve!
Where is it????
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-14-2013, 08:32 AM   #59869
scootergmc
Oddometer: 52
Originally Posted by beechum1 View Post
Little bit of a redesign and this is nearly what it will look like on the bike. The drawings are more advanced than what's on the bike just now. I went with a 2mm fin @ 2mm spacing. I'll make a ~1mm gasket to fit between the body and the cap and will secure with M6x25 machine screws and I've put dowel slots into the cap to body holes. I'll use the standard valve cover dowels. The rear bracket will be M8x20mm into the threaded body mounting holes.
I'll use 3/8 NPTF to 3/8 barbed 45 to 3/8 transmission/oil line and into the oil return on the bike on the right side and I'll have to take it through where the R/R is and move that into the airbox I suppose.
Beech-
Maybe I missed it but what's the reason for mounting the oil cooler out on the rally mount, say, over a setup like the Sutton or a more traditional xr400 style setup? I realize it's a solid mount directly to the frame stem, but I would be worried an impact on a front end digger would snap everything right off, rendering the bike unrideable. Don't get me wrong, I think it's a neat design, just wondering the thought behind.
scootergmc is offline   Reply With Quote
Old 06-14-2013, 08:49 AM   #59870
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,513
Originally Posted by scootergmc View Post
Beech-
XR400 doesn't work because of the anchor on the stem. Sutton is directly behind the front wheel, GSMark is off to the side so in a fall, which I fall mostly to the left, could get damaged. Transmission heat sinks have small fins, the Jagg cooler I have in my garage is too weak (in case of impacts) and again would be off to one side, probably left. I could go for an XR400 if the anchor wasn't in the way, and I've only gone down once where the tower even bent a little bit, so my bets are, it's a safe location considering the options.
And I designed it. like everything else on the tower brackets.
Old 06-14-2013, 09:04 AM   #59871
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,161
I know it is a little late to ask this question, but, since you seem to be a highly skilled designer, could you make the mount itself a cooler in similar fashion to the use of the frame as oil storage/cooler.
Regards
Fritzcoinc
Old 06-14-2013, 09:11 AM   #59872
nic579
x
nic579's Avatar
Oddometer: 384
I was thinking the same thing, save weight and add heatsink mass in the same step.
nic579 is offline   Reply With Quote
Old 06-14-2013, 09:40 AM   #59873
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,513
It's never too late. I hadn't thought of that. I kind of like it for a bit of space savings and the design challenge. I have the space between the towers that isn't being used for anything and I need the increased stremf I know dis. I suppose I could engineer in proper support and protection to avert propensity for fracturing. I'm going in. See you guys on sunday.
Old 06-14-2013, 10:08 AM   #59874
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,332
I don't need to waste good ( GOOD ) beer when I'm hangen round the house:
nice tats.........
B
techforlife is online now   Reply With Quote
Old 06-14-2013, 10:45 AM   #59875
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,513
and
FCR-MX, NGK R2525-11 (coldest plug I can find from NGK that fits), LC-1 O2 Sensor and Gauge, SSI-4 , and header with O2 bung welded in. Just need to get my FCR adapterPrinted by a buddy of mine Chris Vestal with Rally Moto Kit LLC (link below) and i'm running like a pro. I also am waiting for my DB9 to USB adapter to plug into the computer for logging TPS, RPM and O2 signal. I can hopefully create a comprehensive profile of feedback so I can jet perfectly.
Old 06-14-2013, 10:50 AM   #59876
pngaudioguy
Just...one...more...
pngaudioguy's Avatar
Oddometer: 515
Originally Posted by techforlife View Post
nice tats.........
B
I was glancing out the window at the neighbor's cows, and after the page loaded I somehow saw teats instead of tats. Guess I've had enough to drink for the evening. Haha.
pngaudioguy is offline   Reply With Quote
Old 06-14-2013, 11:08 AM   #59877
mcma111
mcma111's Avatar
Oddometer: 12,549
Jeremy,
In case you can't get the carb adapter printed I just received my Noss adapter.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-14-2013, 11:16 AM   #59878
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,513
Jeremy,
It's on the way. Left yesterday from Co springs.
Old 06-14-2013, 11:51 AM   #59879
nic579
x
nic579's Avatar
Oddometer: 384
and
Looks like a fun filled weekend, love to see the O2 sensor setup at work.
Old 06-14-2013, 12:03 PM   #59880
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,513
Hopefully the USB adapter will be here today or tomorrow. I'd like to see it setup too!! If it doesn't, I'll be fiddling with the eddie carb and needles this weekend. I have a feeling I need to just spend the money and get some quality fuel, there's a place in Reno that sells different blends. I still have top end pinging.
Times are GMT -7.   It's 09:12 AM.
