Old 06-17-2013, 08:12 AM   #59971
kdennan
kdennan's Avatar
Oddometer: 621
Originally Posted by Dooga View Post
You're going to want to check out Sweet Cheeks butt pads http://cycle-analyst.com/sweetcheeks and carry fuel bottles. I can ride so many more comfortable miles on that simple pad. Cheap but good.
I'm going with the IMS tank because it is the smallest. I want more range of course, but I am also doing allot of woods roads, etc., so I want the bike to remain as nimble as possible. I went out around 5 this morning and hit some dirt roads, then some of the work roads on the ski area and out a sled trail to a forest service/sled corridor and had a blast. I really missed XR's I guess. The 20mm bar risers are going to be a perfect fit I suspect. I was really pleasantly surprised by how the Trailwings handled everything. I'm running 20psi and it seems to do ok everywhere.
Question about the suspension. That seems to be the only issue I can see. It's a bit harsh. I did the progressive fork springs and that is better. I know there isn't much else to do. I soften the compression damping, right? I notice it on square edged hits and washboard on the dirt roads.
Did somebody say the Dunlop D606 front sucks?
I don't mind puttering on the slab, I can go in the woods
"F#%* you I won't do what you tell me!"
Rage Against The Machine
kdennan is offline   Reply With Quote
Old 06-17-2013, 08:13 AM   #59972
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,512
Originally Posted by nic579 View Post
Is there a difference between the yamaha and Kawasaki part other price?
Yamaha
Part #: 5TA-14916-VT-00
NEEDLE (#NCVT)
$11.39MSRP: $11.39
Kawasaki
Part #: 16187-0216
NEEDLE-JET,NCVT
$18.55MSRP: $24.73
They are all the same. The one I got for Brian's carb was from the Honda shop. I got mine at Yamaha.
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Old 06-17-2013, 08:14 AM   #59973
kdennan
kdennan's Avatar
Oddometer: 621
Originally Posted by mastera210 View Post
well I got one of rear spacers because in trying to get as much clearance for my SM rears my mach buddy checked and that is what he came up with if using rear spacer he is taking some off the XRR counter so it will be in alinement
Where did you get the spacer?
I have the R CS sprocket but hesitate to run it if it's out of alignment.
I like things gnat's ass
Old 06-17-2013, 08:15 AM   #59974
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,512
Originally Posted by RZRob View Post
OK, may swap it tonight and compare performance.
Runs pretty darn good now. Big difference, but I was going from a bike that I don't believe even had Dave's mods. I did Dave's to my old bike and the difference was huge - especially when I added the cam.
RZ Rob
Who knows if there isn't something different between our set-ups. I just know that mine ran like poo when it got warmed up. The plunger off of my CV cured it.
Old 06-17-2013, 08:22 AM   #59975
RZRob
RZRob's Avatar
Oddometer: 1,514
Plug for Rocky Mtn ATV.
I needed a couple parts for other bikes so I was already at Rocky Mountain ATV but the needle was just $10.99. Reached the free shipping limit too. Of course had to get the adjustable Accelerator Pump cover to get there.
RZ Rob
RING-O,FLOAT CHAMBER
Part # 131180004580
$11.141$11.14
RING-O
Part # 131180004590
$11.141$11.14
HOLDER-CARBURETOR
Part # 131180001372
$30.031$30.03
START SET, HOT (Honda Code 6911606)
Part # 131179000994
$20.241$20.24
NEEDLE (#NCVT) | AP
Part # 131204022052
$10.991$10.99
JET, SLOW (#42) (Honda Code 2001436)
Part # 131179006064
$10.051$10.05
JET, MAIN (#158) (Honda Code 0328542)
Part # 131179006054
$5.901$5.90
Boyesen Quickshot 3 Accelerator Pump Cover - 2006 Honda CRF450R
Part # 1264760001
$101.991$101.99
RZRob is offline   Reply With Quote
Old 06-17-2013, 08:44 AM   #59976
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,280
B
techforlife is online now   Reply With Quote
Old 06-17-2013, 08:46 AM   #59977
techforlife
CDI REPAIR
Oddometer: 4,280
RZ Rob
Part # 131180004580
$11.141$11.14
RING-O
Part # 131180004590
$11.141$11.14
HOLDER-CARBURETOR
Part # 131180001372
$30.031$30.03
Part # 131179000994
$20.241$20.24
NEEDLE (#NCVT) | AP
Part # 131204022052
$10.991$10.99
Part # 131179006064
$10.051$10.05
Part # 131179006054
$5.901$5.90
Part # 1264760001
$101.991$101.99
101 bucks well spent if you don`t have to frig with pullin leak jets and changing them for weeks i thought
B
Old 06-17-2013, 09:39 AM   #59978
RideAbout
Mentally Retired
RideAbout's Avatar
Oddometer: 1,681
FCR this, FCR that!
Riding!
West - "Oeste Sanchez"
RideAbout is online now   Reply With Quote
Old 06-17-2013, 09:41 AM   #59979
JWhitmore44
pistolero
JWhitmore44's Avatar
Oddometer: 1,608
I'm surprised you find the front harsh, most find it too soft. Maybe lighter fork oil?
Most of what I read say the D606 front doesn't work as well as other tires for both street and dirt.
84 Honda Goldwing (GL1200)
03 XR650L
JWhitmore44 is offline   Reply With Quote
Old 06-17-2013, 09:43 AM   #59980
JWhitmore44
pistolero
Oddometer: 1,608
Put the R sprocket on with the flat side towards the outside or away from the motor. I don't think you'll notice any miss-alignment. Where you will see it is that the outside of the CS sprocket teeth will get a little shinny.
03 XR650L
Old 06-17-2013, 10:00 AM   #59981
kdennan
kdennan's Avatar
Oddometer: 621
If it's good in the dirt I'll be happy.
It was soft before the progessive springs. I'll play with the clickers a little.
Just an FYI..... Tubliss rules! Word from Jeff Douglas is that they will have a DOT version by the end of the year! I'm already signed up.
kdennan screwed with this post 06-17-2013 at 10:05 AM
Old 06-17-2013, 10:02 AM   #59982
kdennan
kdennan's Avatar
Oddometer: 621
Thanks, will do. I have a 48t steel sprocket coming too. I felt that the 45 was ok today though, but I'll swap it out and see what happens. Again, not really concerened with top cruising speed on the dreaded slab.
Old 06-17-2013, 10:02 AM   #59983
nic579
x
nic579's Avatar
Oddometer: 380
Originally Posted by RideAbout View Post
FCR this, FCR that!
Riding!
Yha, Yha, but some people are addicted to more than just riding. I have known people that just build and rebuild bikes for their hobbies and one of them cant even ride due to his paralysis he owns more bikes now than I have had my whole life. You remind me I need to finish up my sumo wheels as they got mothballed out of laziness "+ the fact I ride every day" and my dual-sport tires are disappearing too quickly.
nic579 is offline   Reply With Quote
Old 06-17-2013, 02:19 PM   #59984
RZRob
RZRob's Avatar
Oddometer: 1,514
Steering Stabilizers
OK folks, I'm hoping you guys want to talk steering stabilizers for a minute. I know things like this often mask set-up issues, but I noticed my new XRL in its current form and my old one too have this near-death front end wallow above 60MPH that's likely related to the D606s or maybe the windscreen on my bike but either way, both bikes had the same issue and these were two things in common.
So, I'm thinking of springing for Scotts because at 60MPH I'm barely breaking idle. I realize I'll need taller bars and probably have to MacGyver a few things.
Any comments, suggestions?
RZ Rob
Old 06-17-2013, 02:35 PM   #59985
mcma111
mcma111's Avatar
Oddometer: 11,869
Steering head bearing adjustment
Tire pressures
Shock pre-load
Loose nut behind the wheel.
Oh, that's right. No steering wheel...
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Times are GMT -7.   It's 06:20 PM.
