Old 06-18-2013, 03:37 PM   #60046
mcma111
mcma111's Avatar
Oddometer: 12,285
Originally Posted by Olderslowerguy View Post
You are correct, Steve!
I love being correct.
Do I get a cookie??
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-18-2013, 03:55 PM   #60047
Boojum
I Miss the PartyBoss
Boojum's Avatar
Oddometer: 5,959
Do I get a cookie??
There you go Steve!!!
"I aint no ruff guy, aint no tuff guy. Don't get out much, and don't dress up fly".......
Boojum is offline   Reply With Quote
Old 06-18-2013, 04:27 PM   #60048
nic579
x
nic579's Avatar
Oddometer: 380
Do I get a cookie??
Just don't try it with the wife.
nic579 is offline   Reply With Quote
Old 06-18-2013, 05:11 PM   #60049
nic579
x
nic579's Avatar
Oddometer: 380
Found an interesting read on tuning FCR carbs explaining one persons ideas of how all the adjustments affect fuel charge and power including what to look for on your lambda sensors.
http://patrick.my.cape.com/brm/carbkei.htm
Old 06-18-2013, 05:19 PM   #60050
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,555
I have yet to see an FCR-MX off of a CRF that had an air jet in the intake bell. I read somewhere... can't remember where that many/most CRF carbs did not have air jets.
Originally Posted by KyoXR View Post
I have the side draft and the more I read the more I believe that the jetting is different between the two.
Boojum:
As far as my jetting right now I suspect that I am robbing Peter to pay Paul but It works for me right now and I will fine tune it down the road.
I am tuning with a wide band O2 sensor.
my current setup (which confuses some but the bike runs pretty damn good):
Main Jet: 142
pilot jet: 42
Needle : NCVQ - (a rich needle) top notch. (needle bottomed)
AIR pilot: a half turn out.
AIR main: 200 (what it came with)
Stealth fuel screw- just cracked open
I would try raising the idle then lowering the idle
turn the fuel screw in all the way then try it out 3 turns
don't pump any fuel in while trying these, see If you can get it started playing around with these.
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Old 06-18-2013, 05:24 PM   #60051
nic579
x
nic579's Avatar
Oddometer: 380
Factory Pro's
patented HDJ MAJ installation for crf / wr / yfz
Keihin FCR carbs
Where's my main air jet and what do I do with that drill bit and tap that came in my Factory Pro HDJ kit for my Keihin FCR carb?
Follow link for info re: patented
FROM: http://www.factorypro.com/prod_pages...rf250x,04.html
nic579 screwed with this post 06-18-2013 at 05:52 PM
Old 06-18-2013, 05:36 PM   #60052
nic579
x
nic579's Avatar
Oddometer: 380
http://www.factorypro.com/tech/tech_...97_4gasEGA.htm
Old 06-18-2013, 06:02 PM   #60053
mcma111
mcma111's Avatar
Oddometer: 12,285
Whose wife?
Yours or mine???
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-18-2013, 06:06 PM   #60054
nic579
x
nic579's Avatar
Oddometer: 380
Whose wife?
Yours or mine???
No wife here I learn the hard way.
Old 06-18-2013, 06:54 PM   #60055
purpledrake
No Pretensions
Oddometer: 334
Originally Posted by fritzcoinc View Post
Something that should be checked is the alignment. I think it is possible that the snail adjusters on the rear axle could be way off on some bikes and Ok on others and for this reason some bikes may shake and others do not. Alignment turned out the be the reason why my Harley touring bike wobbled.
Mr. Fritz, I am not sure that I understand; could you explain this again? Are you saying that the snail adjusters--when set to the same number on both port/starboard sides--could actually cause the rear wheel to be mis-aligned?
Pardon the ignorance.
The Good Lord gave most of us 10 digits; mine are all thumbs.
purpledrake is offline   Reply With Quote
Old 06-18-2013, 08:32 PM   #60056
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,005
Please call me fritz or dumb dick or something. Mr. eludes to someone who has a clue!
Yes. because the port and starboard ( left and right ) adjusters may not be the same size and the stack up of tolerances of the various components of the swing arm could also throw off the location of the pins the adjusters butt against.
Next time you have the rear wheel off place the snail adjusters together. Line up the ID's and see if the notches line up. You could also compare each adjuster using a caliper to measure the dimension from the ID to notches 5, 10, 20, and so on. Another way is to measure from the center of the swing arm pivot bolt ( axle ) to the center of the rear axle on both sides and compare/adjust ( see below ).
The adjusters are stampings and usually have a pretty loose tolerance.
Better quality adjusters are available, but you should check what you have before getting new adjusters.
What I did was to line up both adjusters ID's and Rat Tail filed the notches to match each other.
Here's checking the swing arm pivot to axle centerlines on a Husky during chain adjustment. I put a tight fitting transfer punch in the swing arm pivot and axle then measure point to point on each side and adjust to same dimension. This makes the wheel axle parallel to the engine and it's shafts but not to the front wheel and will not line up the sprockets. :
To get the chain running true, if needed, you would need to change the length of the wheel spacers to shift the wheel side to side. A laser can be used for this as well ( see below ):
Since I have not had a wobble problem that was not attributed to tires I have never checked fnt. to rear wheel alignment on my Honda or Husky. But my Harley is a different story because the engine, trans, swing arm unit is rubber mounted in the frame. This unit needs to line up with the front wheel. I use a laser on each brake rotor to do this. The engine unit is then adjusted to line up with the front wheel. This ended the high speed cornering wobble these bikes are infamous for.
Note the offset in the wheels.
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc screwed with this post 06-18-2013 at 09:23 PM
fritzcoinc is offline   Reply With Quote
Old 06-18-2013, 08:36 PM   #60057
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,005
Someones wife
Regards
Fritzcoinc
Old 06-18-2013, 09:03 PM   #60058
KyoXR
Clouds, Snow, Rain
KyoXR's Avatar
Oddometer: 742
That sounds vaguely familiar and how some FCR-MX carbs come with a set AIR pilot jet (that can be swapped out for a different size) or can be swapped out with a adjustable one like the Side draft carbs in question have.
2007 XR650L,
Looking to acquire a stock XRL choke plunger.
The multi-quote function is your friend.
It's surprising how idiots have good luck, I don't have good luck.
KyoXR is offline   Reply With Quote
Old 06-18-2013, 09:09 PM   #60059
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,358
I need an ncvt,s, or r needle. My order in taking forever and I have a rally this weekend. Anyone hook a Mf up?
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 06-18-2013, 09:15 PM   #60060
nic579
x
nic579's Avatar
Oddometer: 380
Main air jet's relation to main jet + needle profile could explain the differences in fuel needs between the FCR-MX and Sidedraft seeing the locked position on the MX, also the float valve may be something to look at as per keihin's specs for HP. Ie: I bet the air valve flow + float valve could both be on the restrictive side from a crf250 carb and crf450 carb possibly being close to correct.
Now what size tap is needed for the MAJ threading? And did I order the wrong jets and needle.
nic579 screwed with this post 06-18-2013 at 09:21 PM
Times are GMT -7.   It's 05:50 PM.
