Old 06-19-2013, 10:17 AM   #60076
elsalvadorklr
southern xr rider
Oddometer: 4,154
Originally Posted by aksinha88 View Post
WTH is a FAT IDLE?
rich
common symptom caused by fat loving jet recomendations
elsalvadorklr is offline   Reply With Quote
Old 06-19-2013, 10:49 AM   #60077
aksinha88
YETI ADV RIDER
Oddometer: 86
Originally Posted by elsalvadorklr View Post
rich
HAAH! thanks for clarifying that!
YETI ADV RIDER
http://www.facebook.com/YetiAdventures
aksinha88 is offline   Reply With Quote
Old 06-19-2013, 11:08 AM   #60078
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,577
Originally Posted by mastera210 View Post
If you have a FCR carb and it dont have a brass jet in left hole on airbox side you will NEVER get it right!
Mine does great.... no brass in the hole.
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is online now   Reply With Quote
Old 06-19-2013, 01:39 PM   #60079
RZRob
RZRob's Avatar
Oddometer: 1,746
Good, there's enough brass holes in the world.
RZ Rob
RZRob is online now   Reply With Quote
Old 06-19-2013, 02:02 PM   #60080
nic579
x
nic579's Avatar
Oddometer: 382
fcr-mx + throttle and cables showed up today its jetted 175/42 can't quite read the needle but will pull some glasses when its done soaking and see. Still need the noss adapter but was wondering how it connects to the carb.
nic579 is offline   Reply With Quote
Old 06-19-2013, 02:10 PM   #60081
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,352
You grind the ribs off the carb inlet and the Noss slides right on,,then either use silicone or do what i did and JB WELD it on...i like it solid
Gotta be carefull to not plug off the 2 holes in either piece though..i had it on and done in 5 minutes
B
techforlife is offline   Reply With Quote
Old 06-19-2013, 02:42 PM   #60082
mcma111
mcma111's Avatar
Oddometer: 12,854
Same here. Ground off the one rib. Applied the JB Weld and slid on the NOSS. Scrapped the excess JB off. Clean as a whistle.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-19-2013, 03:06 PM   #60083
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,276
Having a weird issue. The bike cranks fine, no problems with cold start, idles pretty good around 1900rpm and dont really notice a problem with throttle response.
HOWEVER, after riding for a few minutes if I come to a stop and idle at the light for eg. it slowly dies .
Im at 450ft elevation and the adjustment screw on the carb is set around 2 1/2 turns. Stock motor and exhaust. Although I did put in a K&N filter in the stock airbox.
Any idea what I should be looking at?
Are you running the 8 heat range plug on the highway? If yes try the 9. I had same stalling problem you describe and the correct heat range plug fixed it.
Regards
Fritzcoinc
fritzcoinc is offline   Reply With Quote
Old 06-19-2013, 03:49 PM   #60084
kdennan
kdennan's Avatar
Oddometer: 630
Installed the FMF Q
Now I have de-smog, snorkel gone, uni-filter, dave's mods, 55/158 jets and about 1,500' elevation.
Started the bike and maybe I didn't warm it up enough (how much is enough?) but after a minute of half choke when the rev's started to die down, I fully (un)chocked and ran for another minute and then rev'd the engine a few times. A faster crack of the throttle had it cough and pop. Normal?
"F#%* you I won't do what you tell me!"
Rage Against The Machine
kdennan is offline   Reply With Quote
Old 06-19-2013, 04:29 PM   #60085
techforlife
CDI REPAIR
Oddometer: 4,352
Originally Posted by kdennan View Post
Installed the FMF Q
what did you set the fuel screw to???????????
I still think 55/158 is kinda rich...
B
Old 06-19-2013, 04:52 PM   #60086
nic579
x
nic579's Avatar
Oddometer: 382
B
My bike in near same condition is 52/155 except my alt is closer to 600ft
nic579 screwed with this post 06-19-2013 at 04:59 PM
Old 06-19-2013, 05:14 PM   #60087
aksinha88
YETI ADV RIDER
Oddometer: 86
I believe I am. I'll try swapping in a new 9 plug tomorrow and see if that helps.
I got the mixture kindof tuned to the point where its not bogging, idling rough or dying anymore when I come to a stop. But, if im going anything over 40mph and pull the clutch in and try to coast with the motor idling it dies . No problem bringing it back to life letting the clutch go though. Lets see if the plug helps. Thanks!
YETI ADV RIDER
Old 06-19-2013, 05:42 PM   #60088
kdennan
kdennan's Avatar
Oddometer: 630
B
My fuel screw is fixed or basically sealed. I can't get at it. There is a brass plug and that's it.
I can try 52/155 I guess. Not allot of fun pulling that carb.
Old 06-19-2013, 06:21 PM   #60089
nic579
x
nic579's Avatar
Oddometer: 382
Post a picture, usually with this type "brass cap over screw" you drill into the cap and pull it out with a screw giving access to air screw.
Is it like this?
Old 06-19-2013, 07:03 PM   #60090
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,610
SparkPlug
How to Read Spark Plugs
Spark Plug Reading Secrets
Spark Plugs
Spark plug reading
My new spark plug reading folder of bookmarks. Get ready.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
beechum1 is online now   Reply With Quote
Times are GMT -7.   It's 06:45 AM.
