Old 06-21-2013, 12:54 PM   #60166
Spud Rider
Spud Rider's Avatar
Oddometer: 3,813
Yesterday I installed a Polisport CRF fender and a ManRacks FFF (Front Fender Farkle).
I put a 21-inch inner tube in the Honda tool bag, and there is room for some more stuff. I have most of the rest of my tools stored in my Harbor Freight tool tube, mounted on the front of the skid plate.
Spud
Old 06-21-2013, 01:01 PM   #60167
nic579
x
nic579's Avatar
Oddometer: 384
I want to go and stay in Idaho with my pig.
nic579 is offline   Reply With Quote
Old 06-21-2013, 01:24 PM   #60168
kdennan
kdennan's Avatar
Oddometer: 628
Originally Posted by nic579 View Post
Anyone live near you that can help you? Drill plug insert screw pull, air screw is most likely behind although I have heard of the low end hondas having the d sockets.
You could always try to pay a bike shop to gain access for you if you bring them in the carb.
I got it out. No big deal, just that I wasn't sure how much brass I had to drill cause of it's shape. The screw "was" a D-socket so I eased it out with a small regular driver and then cut a slot in it and put it back in. Out 2.5 turns, changed the jets out to 52/155 and she fired up real nice.
Seems like it starts easier.
But, I do notice that when I roll on the throttle it almost seems like something is kinda holding her back if you know what I mean. Not a hesitation, like just not allot of power or if I'm pulling something behind me
Any thoughts?
It sure is nice everywhere else and the pipe sounds great.
Thanks for the video tip. I had to get a sheet metal screw in order to bite into the plug because it was so different than the ones in the video.
"F#%* you I won't do what you tell me!"
Rage Against The Machine
kdennan is offline   Reply With Quote
Old 06-21-2013, 03:14 PM   #60169
nic579
x
nic579's Avatar
Oddometer: 384
Probably need to adjust the float level to kill the little lean surge. I have the same thing but decided to try an FCR-MX so have not attempted to remove the issue. I also wondered if it was caused by modifying the slide IE: slide rising too fast for fuel to keep pace under the slow air velocity. It would be interesting to try a stock and a modified slide back to back. You could try the 55 pilot my bike was rich with that, like fouling plug rich.
Any thoughts?
nic579 screwed with this post 06-21-2013 at 03:25 PM
Old 06-21-2013, 03:24 PM   #60170
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,562
Nothing to see here
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Old 06-21-2013, 03:27 PM   #60171
nic579
x
nic579's Avatar
Oddometer: 384
Originally Posted by ThumpnRed View Post
Nothing to see here
Been in SandPoint and Driggs beautiful country, if I had work there I would have stayed.
Old 06-21-2013, 03:36 PM   #60172
nic579
x
nic579's Avatar
Oddometer: 384
I
Read here this might be of some help. Also now that you are close change olny one thing at a time, so you know what is happening, notes can help over time also.
http://www.thumpertalk.com/topic/216...g-please-help/
Old 06-21-2013, 04:01 PM   #60173
kdennan
kdennan's Avatar
Oddometer: 628
It's gotta be the slide/needle as it is fine right off the bottom and perfect when I really hold the throttle open into the main.
So nothing can be done with the mixture screw? That is for response right off the bottom, right?
Hmmmmm
Old 06-21-2013, 04:11 PM   #60174
kdennan
kdennan's Avatar
Oddometer: 628
I thought it was lean. I remember someone explaining it somewhere long ago about the "boowahhh" means lean.
Crap, I can do pilots and mains. Now what? The needle is shimmed with one of those little Radio Shack washers, that's about all I know what to do from Dave's mod's.
It's not terrible. I'm just used to FI I guess. And my two strokes are easy.
Old 06-21-2013, 04:18 PM   #60175
nic579
x
nic579's Avatar
Oddometer: 384
Lean off idle rich otherwise, just for that surge causing moment that is what I am guessing with mine. 55 pilot rich 52 not lean but 2 3/4 turns out on the air mix screw and no resolution to the lean surge just off idle. Did you try the 55 with the 155 it might work for you and you can go to 2 3/4 technically with the air screw before you are supposed to go up a pilot size.
Joke was you cant adjust the float level.
nic579 screwed with this post 06-21-2013 at 04:31 PM
Old 06-21-2013, 05:45 PM   #60176
kdennan
kdennan's Avatar
Oddometer: 628
I was scratching my head
I'll give the 55 a shot and tweaker the AS
Old 06-21-2013, 05:49 PM   #60177
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,562
Yep... both really nice areas.
Old 06-21-2013, 05:53 PM   #60178
nic579
x
nic579's Avatar
Oddometer: 384
One at a time try air screw first see what you get.
Old 06-21-2013, 05:54 PM   #60179
joexr
Oddometer: 3,773
It's a FUEL screw.
Old 06-21-2013, 06:42 PM   #60180
kdennan
kdennan's Avatar
Oddometer: 628
Originally Posted by joexr View Post
It's a FUEL screw.
Oh yeah,
2-smokers got me on that one
Times are GMT -7.   It's 11:49 PM.
