Old 06-21-2013, 08:44 PM   #60181
super samurai
super samurai's Avatar
Oddometer: 316
Wife got mad at me for something she couldn't find so I bailed and went for a ride.
It cheered me up!
i know my clear tank is ugly!
super samurai is offline   Reply With Quote
Old 06-21-2013, 09:15 PM   #60182
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,555
Wise choice! Looks like a good ride... nice view. Surely better than fussing with the wife.
It cheered me up!
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Old 06-22-2013, 06:21 AM   #60183
Grayjet
Ride on!
Grayjet's Avatar
Oddometer: 453
Caliper pin
Mine was notched like Clint's, only more pronounced.
I would like to rebuild the caliper anyways, just due to age. Aftermarket rebuild kit, or just go OEM?
Originally Posted by absoluteclint View Post
Thanks Steve... The groove is about 1/8" flat but it does not go all the way along the pin... It is more of a notch that is 1/8" x 1/8". There are scratch marks along the middle portion of the pin where I can tell the pads have slid (or attempted to slide)... But this area is rounded all the way around... Not flat.
You can see the notch about 2/3 of the way down the pin from my finger.
What do you think? Clean it and let it ride or place an order for a new one?
Originally Posted by mcma111 View Post
Is the groove a 1/8" flat all the way along the pin? It's MADE that way so the lube has somewhere to go.
'93 Honda XR650L
'09 KTM 990 Adventure
Putting miles on the tires!
Grayjet is offline   Reply With Quote
Old 06-22-2013, 06:50 AM   #60184
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,329
Either should be fine.......i would not rebuild a caliper on a dirtbike myself unless i could get the stripped down caliper soda blasted to remove all corrosion under inside the piston bore and where the seal sits...corrosion expands and makes the piston stick,,,soda blasting removes all corrosion and no metal,,making it like new again...
B
techforlife is offline   Reply With Quote
Old 06-22-2013, 07:56 AM   #60185
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,076
Neither, don't bother with rebuild, buy another one on EBay. Price out the rebuild parts and check out EBay.
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 06-22-2013, 08:17 AM   #60186
super samurai
Oddometer: 316
GREMLINS
so i replaced my cdi that i figured was the culprit, guess again!
so here is what it does, run from home to gas station and no start,
it is not getting spark either, it doesn't even try to start.
then out of the blue it will start.
it is spuradic when it does this so it is hard to find.
so where do i start throwing $ or tearing apart.
i still have all my safetys but they all seem to work?
put the kick stand down and it will die.
never dies while riding ever.
so what else kills the spark?
i am thinking the kill switch?
at least i now have a good spare cdi!
thanks brian
Old 06-22-2013, 08:26 AM   #60187
ltcole
Herpetologist
ltcole's Avatar
Oddometer: 85
So I have this rattle.
When I accelerate really hard, throttle fully open, there is a noticeable rattle that is louder the higher the RPM. Is it just the chain, or something else? Could it be that the valves need adjusted?
Also, what skid plate would everyone recommend?
Thanks in advance,
LTCOLE
ltcole is offline   Reply With Quote
Old 06-22-2013, 08:28 AM   #60188
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,076
GREMLINS
thanks brian
Stop/run button. Just a guess. Mine has and is currently doing pretty much same. But mine is running today!
Check coil too.
Regards
Fritzcoinc
Old 06-22-2013, 08:32 AM   #60189
mcma111
mcma111's Avatar
Oddometer: 12,378
It's the stop/start button. Pull the switch assy off of the bars and hose the switch with electrical contact cleaner and cycle the switch back 'n forth. Does your bike live outside?
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-22-2013, 08:33 AM   #60190
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,076
Thanks in advance,
Do you have OEM drive chain guides?
Some of the after market chain guides use a hard plastic guides that last forever but are noisy.
made mine:
Regards
Fritzcoinc
Old 06-22-2013, 08:34 AM   #60191
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,076
Mine is a garage queen.
Regards
Fritzcoinc
Old 06-22-2013, 08:34 AM   #60192
mcma111
mcma111's Avatar
Oddometer: 12,378
Thanks in advance,
Engine PING? What gas ya running? How long has it been since you checked the valves? Got oil??
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-22-2013, 08:48 AM   #60193
ltcole
Herpetologist
ltcole's Avatar
Oddometer: 85
made mine:
I have yet to check the valves, definitely has oil. I am running the cheap 86 ethanol junk...... I have run higher octane, but that didn't seem to change the rattle. The rattle has continued with a new chain and sprocket setup, but does happen any other time except as described originally....
I am running an XRs only chain guide, but it rattled when I didn't have a chain guide on at all..... Oh yeah, I forgot about your setup for a skid plate. Maybe I can find some time to fab one up.
LTCOLE
Old 06-22-2013, 08:55 AM   #60194
Walterxr650l
Walterxr650l's Avatar
Oddometer: 1,269
GREMLINS
thanks brian
If not the kill switch it might be the pulse generator. This post tells how to check it.
Walter
"How much a dunce
That has been set to roam
Excels a dunce
That has stayed at home."
Walterxr650l is offline   Reply With Quote
Old 06-22-2013, 09:00 AM   #60195
Dooga
Adventure Tourer
Dooga's Avatar
Oddometer: 304
Originally Posted by joexr View Post
It's all here if you start at page one.
Zing
1995 BMW K1100LT
Dooga is offline   Reply With Quote
Times are GMT -7.   It's 02:33 AM.
