Old 07-09-2013, 07:22 PM   #60526
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,301
Originally Posted by kenny61 View Post
Good thing I have a brand new one in the bike
not anymore.........
look again..
B
techforlife is offline   Reply With Quote
Old 07-09-2013, 07:47 PM   #60527
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,576
Bastard
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Go forth and be a force of the awesome!
kenny61 is offline   Reply With Quote
Old 07-09-2013, 09:39 PM   #60528
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,311
Originally Posted by mcma111 View Post
OK, Here goes.
Piston looks like it's jetted FAT. Or your oiling past the rings. But that would show up as a clean area at the outer edge of the piston which you don't have.
Plug looks LEAN.
Correct heat range of PLUG???
What octane fuel are you using? Ethanol?
Scrape the top of the piston off with a razor blade. Make sure no debris gets in the rings and reassemble.
At what point was the plug turned off. Idle? Idle looks lean. Shit on the piston looks fat. Ground strap looks too white. But check the jetting first. one at a time.
Put it back together and do the water torture to clean the piston.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 07-10-2013, 06:00 AM   #60529
kdennan
kdennan's Avatar
Oddometer: 624
I did install progressive fork springs, but what do you guys suggest I do to the forks/shock?
Race Tech?
Springs?
Valving?
Really want good off road.
Thanky
EDIT: Or even where to set the clickers with the set up I have?
"F#%* you I won't do what you tell me!"
Rage Against The Machine
kdennan is offline   Reply With Quote
Old 07-10-2013, 07:24 AM   #60530
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,536
Originally Posted by kdennan View Post
i did install progressive fork springs, but what do you guys suggest i do to the forks/shock?
Race tech?
Springs?
Valving?
really want good off road.
thanky
edit: Or even where to set the clickers with the set up i have?
usd
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is online now   Reply With Quote
Old 07-10-2013, 08:13 AM   #60531
rrittner
SometimesY
Oddometer: 249
Race Tech?
Springs?
Valving?
Thanky
Put a cr250 front end on it!! Way better the bike actually goes where you point it.
rrittner is offline   Reply With Quote
Old 07-10-2013, 09:49 AM   #60532
sc-razor
sc-razor's Avatar
Oddometer: 3,770
Originally Posted by ThumpnRed View Post
THere used to be a watering hole tucked away in the trees up where we ride. back in the 70's and 80's it was dirt bike heaven... parking lot was always full of bikes. I cant begin to count the times when a bunch of us would have a few too many and then strike out for the ride home. Always the same... "NO RACING... we are all too damned drunk"... That would last until someone got tired of eating dust and the race was on. We'd all end up in a big pile a few corners later. That same story would play itself out four or five more times before we'd get home. Five drunks on dirt bikes... in the dark... two bikes with lights... what could possibly go wrong with that?!
Thinking back on it now... we were a bunch of knuckleheads!
2009 XR650L
2009 KTM 300XC-W
Steve
sc-razor is offline   Reply With Quote
Old 07-10-2013, 10:30 AM   #60533
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,311
Race Tech?
Springs?
Valving?
Thanky
I have a CRF250X front end with fresh oil 5w in one, 7.5w in the other, and an XR600R shock with a race tech spring, can't remember the weight. I haven't messed with internals yet on the shock but here are some references
Shock Service https://docs.google.com/open?id=0BwZ...thkey=CO-Np5cM
Shock Fiche https://docs.google.com/open?id=0BwZ...thkey=CJX3lpcH
Both documents are Public Domain.
Old 07-10-2013, 04:35 PM   #60534
ltcole
Herpetologist
ltcole's Avatar
Oddometer: 85
CDI repair help
Ok, I have the CDI pulled apart, the majority of the potting pulled off, and I was just wondering if trying to remove all the tiny spots of potting from the board is necessary or not? When I say tiny spots, I mean anything out in the open that is very small, or even any of the stuff stuck under the legs of the components.....
I just want to get as good of a re-solder as possible, and didn't know if leaving that on there while desoldering would make a difference or not.
Thanks,
LTCOLE
ltcole is offline   Reply With Quote
Old 07-10-2013, 08:17 PM   #60535
techforlife
CDI REPAIR
Oddometer: 4,301
Thanks,
PM sent..........
Get the stuff out from under the bent over legs,,sometimes easier after desoldering........as long as the areas being soldered are clear of the shit you are good........i use a lighted magnifier and a utility knife or pick to get that crud out from under the bent over component legs,it WILL affect the solder joint if left there..
B
Old 07-10-2013, 08:22 PM   #60536
cypert2
Oddometer: 69
Tires
I have about worn out the factory tires on my 650 and am looking for replacement advise. I'm a newb, this is my first bike. I ride some pavement, a little dirt, and a whole lot of gravel. Any advise appreciated. Also what size front and back do I need.
cypert2 is offline   Reply With Quote
Old 07-10-2013, 10:35 PM   #60537
RZRob
RZRob's Avatar
Oddometer: 1,571
Originally Posted by cypert2 View Post
I have about worn out the factory tires on my 650 and am looking for replacement advise...
Oh no, here we go again... Don't ask about oil, please don't ask about oil.
RZ Rob
RZRob is offline   Reply With Quote
Old 07-10-2013, 11:07 PM   #60538
Spud Rider
Spud Rider's Avatar
Oddometer: 3,771
RZ Rob
Don't ask about air filters or countershaft sprockets.
Spud
Old 07-11-2013, 04:47 AM   #60539
techforlife
CDI REPAIR
Oddometer: 4,301
Spud
Fine,let`s talk carbs then..you go first..
B
Old 07-11-2013, 04:47 AM   #60540
nic579
x
nic579's Avatar
Oddometer: 381
I need mirrors, are there any good options as I have only one tattered stock and a mirror off a 70s rd at the moment.
Looking at doubletake and ken shane, are the double take really worth the extra cost.
nic579 screwed with this post 07-11-2013 at 05:13 AM
nic579 is offline   Reply With Quote
Times are GMT -7.   It's 12:59 AM.
