Old 07-11-2013, 03:31 PM   #60571
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,227
Look down the chain guide. That has to go on before the rest of the stack on the crankshaft that side anyway. With a 10mm socket. And then the cam chain sprocket, drive gear, PG and oil pump drive sprocket all held on with a 24mm nut. And make sure the washer says this side out.
I think.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 07-11-2013, 03:34 PM   #60572
mcma111
mcma111's Avatar
Oddometer: 11,905
B,
I'm not trying to piss you off. Even if I wanted to...
The gear has a spacer on one side. That spacer or collar goes towards the engine case and the gear teeth are away from the case.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 07-11-2013, 04:06 PM   #60573
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 6,821
I don't run spacers
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 07-11-2013, 04:16 PM   #60574
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,286
Originally Posted by mcma111 View Post
B,
So is this pic in the manual wrong..........i`m just looking for clarification Steve.........2 manuals...one shows this,,the older manual pic is kinda vague..........i`ve never looked down the chain to check,,didn`t figure i needed to..this clearly shows the collar side out??????????
B
techforlife is offline   Reply With Quote
Old 07-11-2013, 04:18 PM   #60575
techforlife
CDI REPAIR
Oddometer: 4,286
Originally Posted by fritzcoinc View Post
I don't run spacers
Look,go test an air filter or somethin usefull FFS.......
B
Old 07-11-2013, 04:28 PM   #60576
elsalvadorklr
southern xr rider
Oddometer: 4,154
brian just a question...you dont think youd see the big angle difference when the sprocket is on wrong?
like aligning a chain on a pedal bike...youll really see if its wrong...
if installed incorrectlly the chain will rub on the sliders...
manuals huh makes you want to double and triple check EVERYTHING
elsalvadorklr is offline   Reply With Quote
Old 07-11-2013, 04:37 PM   #60577
techforlife
CDI REPAIR
Oddometer: 4,286
I`ve never seen any irregular wear on the 2 sets of rails.........i`ve never looked down the hole either........but my manual shows a good side view and also the way to time that gear........
B
Old 07-11-2013, 05:06 PM   #60578
elsalvadorklr
southern xr rider
Oddometer: 4,154
hmm I was just mentioning it since I always check down the hole to make sure the chain hasnt fallen off and into the collar...to check timimg or after putting the head back on
Im so damn paranoid after reading all the cases of jumped timing caused by this that I have a long ass screw driver and a big light to see down there...
last time for some reason took me forever to get the chain back on..almost took the clutch cover off! jajaja
anywhoo
peace
Old 07-11-2013, 09:09 PM   #60579
prince_ruben
prince_ruben's Avatar
Oddometer: 1,726
What's the consensus on replacement of the regulator/rectifier? I've done all the checks via the Haynes manual and it seems my unit has failed 2002, 14k miles).
I'm looking on cheap cycle parts but it's not a Honda unit. Should I stick with OEM?
prince_ruben is offline   Reply With Quote
Old 07-11-2013, 10:00 PM   #60580
Mossy-Back
Wet-Sider
Mossy-Back's Avatar
Oddometer: 1,582
I am still alive, and the XR is still running strong! That is all...
Evan
2013 Husqvarna Strada
'93 XR650L (Gone, but missed)
Ooh-Rah! Once a Marine, always a Marine!
Originally Posted by kenny61 View Post
figures...my stud was rusty I played with my nuts a little and it cranked right over
Mossy-Back is offline   Reply With Quote
Old 07-11-2013, 11:17 PM   #60581
purpledrake
No Pretensions
Oddometer: 334
Glad to hear it. 2 more months to Roosie elk season, no?
The Good Lord gave most of us 10 digits; mine are all thumbs.
purpledrake is offline   Reply With Quote
Old 07-11-2013, 11:33 PM   #60582
RZRob
RZRob's Avatar
Oddometer: 1,522
Bike Porn
Thought I'd post a few pics of my Scotts Damper install. Fit nicely.
RZ Rob
RZRob is offline   Reply With Quote
Old 07-12-2013, 01:13 AM   #60583
KyoXR
Clouds, Snow, Rain
KyoXR's Avatar
Oddometer: 725
Originally Posted by XR650L_Dave View Post
I did not like the scorp pro front- a low-profile dirtbike tire? Super-foldy-knobs?
The XCMH front is better, I think. My current set of tires are the XCMHs. Excellent traction, as always lifespan is the issue.
I was looking at the XCMH as the next front tire to try ,
Have you tried a Surge I front tire? I would like to hear how you think that compares with the XCMH and the Scorpion Pro, traction wise.
(RZRob) the damper looks good, I really like mine.
2007 XR650L,
Looking to acquire a stock XRL choke plunger.
The multi-quote function is your friend.
My motorcycle is 5000 times faster then a centipede!
KyoXR screwed with this post 07-12-2013 at 01:21 AM
KyoXR is offline   Reply With Quote
Old 07-12-2013, 02:40 AM   #60584
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,576
I tried it with the lip towards the crank and gear facing the cover. I found the chain rubs the drive gear that way, so did this guy http://www.advrider.com/forums/showthread.php?t=676313
This vid shows it with the lip facing away from the crank too, as well as any other pictures and vids that I was able to locate
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Go forth and be a force of the awesome!
kenny61 is offline   Reply With Quote
Old 07-12-2013, 04:43 AM   #60585
techforlife
CDI REPAIR
Oddometer: 4,286
hmmmmmmmm..never heard of anyone with a bad reg yet,,this`ll be a first...i`d go OE...i`d never put anything but on these bikes as the charging is usually bulletproof...
B
Times are GMT -7.   It's 02:42 AM.
