Old 07-15-2013, 03:15 PM   #60661
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,354
Originally Posted by RideAbout View Post
http://www.procycle.us/bikepages/xr650l.html#a520x110
... one option and right in your back yard.
15/48 and 112 links has worked for me.
now there`s a bright freeking bunch.........they say 110 links is stock from 93-2000............but 2001 up is 120 links.......
Someone better measure there 2001 and up swingarm,,seems they lengthened it alot in 2001......or they run 15/75 sprockets...
They say if you want to run a 48 tooth rear.get the 130 link chain
Someone smokin a little weed there me thinks......
B
techforlife screwed with this post 07-15-2013 at 03:20 PM
techforlife is offline   Reply With Quote
Old 07-15-2013, 03:31 PM   #60662
joexr
Oddometer: 3,773
B
It's probably a sales technique. They'll sell more un-needed chain.
Old 07-15-2013, 04:13 PM   #60663
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,290
15 x 48 at 110 works for me. Adjuster will be at 5 or 7.
I always buy extra links to have spare O rings in case I need to open the master link.
Regards
Fritzcoinc
fritzcoinc is offline   Reply With Quote
Old 07-15-2013, 04:21 PM   #60664
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,290
Originally Posted by zulusafari View Post
I hav the 908 on my rear. I have been running it the whole time I've been in Africa. I have about 7,000 miles on it and I guess I'll take it off after about another 1,000 to put a 606 on for a few long trips I'm doing later. I've not had a single puncture on the 908. Is 7-8k miles a lot? Was it worth double or triple most other tires? I don't know since it was my first, but honestly have no complaints. But I don't really know any better. I do fear hating everything else I put on after though.
Has anyone used Goldentyre from Italy? Considering a set of those on my 'new' 1994 I just got last week. Going to rebuild it and replace a lot of parts. It only has 5,500 miles but looks like it's taken a handful of really hard spills.
For me I never had a rear tire go more than 3200 or so till I came across the 908, but I ride a long ways on the street to get to the off road. I read on another forum a guy got 12K from a 908 on a KTM 990! But I think the 990 uses a wider tire than a 140.
I had the misfortune to have two blow outs on the front 908 on my Husky. Both due to spokes breaking and punching through the tube. Both times I rode the completely flat 908 over twenty miles to get home. That tire is still on my Husky.
Golden Tyre, HUMMMMM checking that out.
Regards
Fritzcoinc
Old 07-15-2013, 04:28 PM   #60665
techforlife
CDI REPAIR
Oddometer: 4,354
Yup,,i was runnimng 15/48 last week at 5 on the adjusters.....i`m running 14/48 right now..i like it better........
B
Old 07-15-2013, 04:29 PM   #60666
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,290
Temp gage
Go to an industrial hose supplier and ask for a Seal Fast PT1550. This thermometer has a range of 50 to 550 DF. This is an industrial thermometer made to endure a tough environment and not a "candy " ass application.
Drill a tight hole for the stem along side the dip stick.
Regards
Fritzcoinc
Old 07-15-2013, 04:31 PM   #60667
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,290
B
Here I go again.
Use the biggest sprockets you can to get the desired reduction.
The chain will deflect less around a larger diameter sprocket and wear less as will the sprockets. More teeth to absorb the wear.
Regards
Fritzcoinc
Old 07-15-2013, 04:51 PM   #60668
alvincullumyork
I wish I was cool
alvincullumyork's Avatar
Oddometer: 2,137
I feel like a dirty BMW rider the cheapest closet DID Xring chain was at the Touratech store. They were very nice and helpful though.
Thanks for the advice Steve.
Anyone have a favorite chain breaker?
How to ride your XR650L to South America: http://advrider.com/forums/showthrea...2#post19932112
If you're in my area on a ride and need a place to crash, a hot meal, or some beer let me know. 913 260 7873
On a one man mission to stop people from buying boring bikes (cough cough klr)
alvincullumyork is offline   Reply With Quote
Old 07-15-2013, 05:07 PM   #60669
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,827
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Go forth and be a force of the awesome!
kenny61 is offline   Reply With Quote
Old 07-15-2013, 05:13 PM   #60670
Walterxr650l
Walterxr650l's Avatar
Oddometer: 1,311
If you just want to break the chain this one works well no grinding required.
If you want to be able to break the chain, press on the new link and rivet it, then this is a good option.
There are cheaper chain tools, but I'm told you must grind the riveted head off of the chain link's pin, or you will break the tools pin.
Walter
"How much a dunce
That has been set to roam
Excels a dunce
That has stayed at home."
Walterxr650l is offline   Reply With Quote
Old 07-15-2013, 05:19 PM   #60671
alvincullumyork
I wish I was cool
Oddometer: 2,137
Walter
Edit: I'm stoopid. Click the picks for the links.
Where can you get these?
Old 07-15-2013, 05:29 PM   #60672
vector_dumb
Happier Here
vector_dumb's Avatar
Oddometer: 325
Ahhh, now we are getting somewhere. I bounced around a bit looking for a place that might sell Seal Fast stuff - I didn't turn up anything really close. But based on the description of the unit it seems like what I'm looking for is an industrial pocket thermometer. The 5" stem, 1" dial, 50-550, seems like a standard size.
I'll probably toss one in with my next amazon order:
http://www.amazon.com/dp/B001U1U57G/ref=biss_dp_t_asn
or maybe this one...
http://www.amazon.com/Rubbermaid-Com.../dp/B005KCG4QC
I'm sure the cooking thermometers are fine, but with the aftermarket tank the 1" dial face would give nice clearance. I fumble enough as it is just getting the dipstick in and out.
Thanks again!
Fritzcoinc - I'm surprised to hear you run with a temp gauge or even a dipstick after reading your posts from this weekend
Mac, you have an exceptional number of bugs in your teeth. You're gonna wanna rinse those out. It's disgusting. (Always Sunny)
vector_dumb is offline   Reply With Quote
Old 07-15-2013, 05:32 PM   #60673
joexr
Oddometer: 3,773
The bottom one is $95.00 at Cyclegear.
Old 07-15-2013, 05:58 PM   #60674
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,290
Diamond brand.
Regards
Fritzcoinc
Old 07-15-2013, 06:00 PM   #60675
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,290
Thanks again!
Just trying to keep up appearances.
Regards
Fritzcoinc
Times are GMT -7.   It's 11:34 PM.
