Old 07-18-2013, 04:25 PM   #60736
Hazman27
The Haz
Hazman27's Avatar
Oddometer: 679
Xr/xrl
Hey guys, I'm looking for the plastic frame guards, just above the foot pegs, not the metal plate style, but the zip tie "Y" shape style. Any leads? Thanks
Hazman27 is offline   Reply With Quote
Old 07-18-2013, 05:10 PM   #60737
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,661
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Go forth and be a force of the awesome!
kenny61 is offline   Reply With Quote
Old 07-18-2013, 05:51 PM   #60738
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,329
Originally Posted by kenny61 View Post
oh god there goes the neihbourhood,,,,,,,,,,,,,,again
B
techforlife is offline   Reply With Quote
Old 07-18-2013, 05:59 PM   #60739
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,661
Originally Posted by techforlife View Post
neihbourhood
B
Oh mY gOd!!!!
Old 07-18-2013, 06:47 PM   #60740
tractor4play
Oddometer: 111
xrl bottom end with xl 600 top end
i have just done a dry build with a rfvc 650 bottom mated to xl600r barrel,stock piston and twin carb head.
without gaskets the piston is 1.3mm above deck height.so with double base gaskets and stock head gasket i should just about clear zero deck.
has anybody done this without issues..valve to piston clearance etc.
any advice would be great.
tractor4play is offline   Reply With Quote
Old 07-18-2013, 09:35 PM   #60741
joexr
Oddometer: 3,773
Acerbis made the white ones. Don't know if they're still available though.
Old 07-19-2013, 06:27 AM   #60742
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,078
That much piston above the top of the cylinder is not going to work.
The head gaskets are designed to be between a flat surfaces and not another gasket.
If you want to pursue make a 1.3MM solid copper cylinder base gasket.
Back in the late 70's when alcohol fuels first hit the scene, I was riding a Moto Guzzi Sport and tried two head gaskets to reduce the compression to something that the alcohol/gasoline fuel could tolerate without knocking like a forge hammer. The stack of gaskets just would not hold a seal long.
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 07-19-2013, 06:33 AM   #60743
smokeeater495
smokeeater495's Avatar
Oddometer: 602
Doesn't alcohol fuel like higher compression?
Harley, been there done that. Don't want to be a pirate.
smokeeater495 is offline   Reply With Quote
Old 07-19-2013, 06:57 AM   #60744
Break_Syncro
Oddometer: 189
If you make a 1.3 mm copper , there might be a chance that your timing chain will end up tighht. Ask me how I know...
'95 XR650L - Dave's Mod and de-smogged, XRs Only header with XR600R muffler , XRs Only temp gauge, Twin air filter, CRF USD Fork with RSW clamps, Acerbis CRF vented front fender, MSR brush and hand guards, Trail Tech temp gauge, Acerbis 5.8 gal tank, XR400R oil cooler, D606 tires for dirt! Excel sumo wheel ! EBC 320mm Sumo front rotor for street carnage! Thanks to you all the your help!
Break_Syncro is offline   Reply With Quote
Old 07-19-2013, 07:17 AM   #60745
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,078
When alcohol/ethanol fuels hit the market even my 6 cyl. Ford knocked when using these fuels.
I was relating this experience to lend creditability to my recommendation of not using two head gaskets based upon actual experience doing so.
I ran two gaskets for quite some time as I was riding my Sport daily to work.
After a rather short time the gaskets would leak and burn through.
Because of the poor reliability of two head gaskets I made a base gasket of pipe flange gasket material. It was a little thicker than two Guzzi head gaskets.
There was a reduction in performance but the bike got me where I was going till I could put lower compression pistons suitable for the newer fuels.
Here's the old Sport outside my "pad" with it's custom cover:
It was a cool bike. I had to be the first Sport Biker in Houston. Note clip on handlebars
and 10 HP worth of stickers:
Regards
Fritzcoinc
fritzcoinc screwed with this post 07-19-2013 at 07:32 AM
Old 07-19-2013, 09:25 AM   #60746
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,404
Originally Posted by Alaskajeff View Post
This style?
Jeff suggested these in the XR600 thread when you axed the same question a week ago.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 07-19-2013, 09:38 AM   #60747
techforlife
CDI REPAIR
Oddometer: 4,329
Who makes them boss
B
Old 07-19-2013, 11:38 AM   #60748
KyoXR
Clouds, Snow, Rain
KyoXR's Avatar
Oddometer: 747
Anyone need special sprockets?
Try here:
http://www.rebelgears.com/2009catalog.html
Thanks for posting the link, my enthusiasm was cut a little bit short when I found out they only make Aluminum rear sprockets but I'm still happy there is a option for custom sprockets.
plus they have that hard coat option and a option to go Xtra Lite.
2007 XR650L,
Looking to acquire a stock XRL choke plunger.
The multi-quote function is your friend.
It's surprising how idiots have good luck, I don't have good luck.
KyoXR is offline   Reply With Quote
Old 07-19-2013, 11:52 AM   #60749
mrfixit54016
Wisconsin Dual Sporter
mrfixit54016's Avatar
Oddometer: 666
Go to Fleabay and type in
99 XR600R Acerbis Frame Guards
And I bet you may find some there.
Or try Power Sport Junkie or many others for the UFO brand.
http://www.powersportjunkie.com/UFO-HO02685041-p/pu-12-488-29.htm
1993 RD07 Africa Twin
1994 XR650L farkled
1985 XL600R (sold!)
1985 XR600R tagged
1983 XL100S, 1980 XL80S, and 1985 ATC250ES
mrfixit54016 screwed with this post 07-19-2013 at 12:06 PM
mrfixit54016 is offline   Reply With Quote
Old 07-19-2013, 12:51 PM   #60750
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,555
Yes
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Times are GMT -7.   It's 05:19 PM.
