Old 09-01-2013, 01:59 PM   #62071
jarhead251
Semper Fi
jarhead251's Avatar
Oddometer: 38
Originally Posted by joexr View Post
I've gotten it on good authority HERE that there is no revlimiter.
I've got it on "my" authority that it does. Didn't hear it from somebody else.......heard it myself while the throttle was WFO for 4 seconds.
You and I have a rendezvous with destiny. We will preserve for our children this, the last best hope of man on earth, or we will sentence them to take the first step into a thousand years of darkness." Ronald Regan
jarhead251 is offline   Reply With Quote
Old 09-01-2013, 02:07 PM   #62072
joexr
Oddometer: 3,773
Cool2
I've gotten it on better authority HERE that there is no revlimiter.
Old 09-01-2013, 02:49 PM   #62073
mcma111
mcma111's Avatar
Oddometer: 12,385
Originally Posted by gammel View Post
My current set up both d606's
Front approx 4500 mi
Rear approx 1800 mi
[IMG]http://img.tapatalk.com/d/13/09/02/nuru4yre.jpg[/IMG
My buddy Andy would have his 606 looking like this. I thought it was because he was hard on the front brake. My preferred flavor of tires is a MT21 front (it doesn't wear any where near this bad) and a 606 rear.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 09-01-2013, 03:06 PM   #62074
Barron
M0DAH0LIC
Barron's Avatar
Oddometer: 2,452
Originally Posted by Brown Falcon View Post
Good to hear. I enjoy carving the corners when I'm out on the street, and even though most of my riding is pavement, I want have tires that are good in the dirt as well.
I'll be going with a Mefo Explorer rear, which is more of a 50/50 tire and looks like it will perform well offroad, but the matching front doesn't seem aggressive enough to do well off pavement so I am looking for a better alternative.
I had some MEFO explorers on the front and rear for over 5000 miles and I really liked them on pavement and offroad with the glaring exception of mud. For the miles you get out of them I could deal with not hitting mud because when I had them it really wasn't an option unless I wanted to practice picking the bike up. Just make sure you heat up that tire before you put it on, doing so will save you a lot of four letter word usage.
When my rear was done the front was cupped really badly, I tried turning it around but it had a bad wobble to it. I was going to give it to somebody but it just wasn't safe for use.
If you ride dry pack and pavement I'd recommend them, just be careful in the mud.
FWIW, one time I had a blow out in the rear after catching a nail or something and had to limp 5 miles on a flat. It came off the bead, but stayed on the rim. I don't recommend doing this but it's good to know it can handle it in a bad situation.
-Barron
1996 XR650L with a couple mods
If everyone brewed beer there would be no war.
Barron is offline   Reply With Quote
Old 09-01-2013, 03:17 PM   #62075
DaveHunter
DaveHunter's Avatar
Oddometer: 87
Stupid questions. There will be more
The air valves on the top of the forks to let air pressure out? We don't want pressure in there? Or do we?
Dunlop D606. He had pretty low air pressure in them. Like less than 20-ish. That normal? Those tires mostly dirt tires?
The fuel valve is manual shut off? I don't see a vacuum line from the carb to it. Might be a different one than stock? Tank is a plastic Clarke tank.
Did this old of bike (1994) have the smog air pump OEM? Is there anything to check from the removal that should be sealed off.
Rear shock has XR Only sticker on it. Is this something changed out or rebuilt?
Super Trapp muffler any good? Sound pretty good.
I think I probably should get a Honda manual. He gave me a Clymers for like three different bikes.
DaveHunter is offline   Reply With Quote
Old 09-01-2013, 03:21 PM   #62076
joexr
Oddometer: 3,773
You can put up to 6 PSI in the forks. Petcock is manual.
Old 09-01-2013, 03:25 PM   #62077
DaveHunter
DaveHunter's Avatar
Oddometer: 87
I was pretty sure about the petcock but had to ask if a vacuum line was missing. I couldn't find any place it would plug in either end.
What is the advantage/ disadvantage of pressure 0-6 PSI in the forks?
Old 09-01-2013, 03:27 PM   #62078
joexr
Oddometer: 3,773
You are stiffening the fork springs with air. What vacuum line? Pix?
Old 09-01-2013, 03:43 PM   #62079
Olderslowerguy
Olderslowerguy's Avatar
Oddometer: 424
If "your" authority thinks there is a rev limiter, please tell me at what rpm it cuts in? I can say without a doubt that it does not function between 0 and 9400 rpm.s! There is NO limiter in the stock CDI.
OSG
Clearwater, Fl.
Olderslowerguy is online now   Reply With Quote
Old 09-01-2013, 03:51 PM   #62080
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,662
I usually run about 18psi.. will go lower if no street only trail
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Go forth and be a force of the awesome!
kenny61 is offline   Reply With Quote
Old 09-01-2013, 04:03 PM   #62081
joexr
Oddometer: 3,773
In your forks?
Old 09-01-2013, 04:25 PM   #62082
AZ TOM
Oddometer: 4,029
After many combos, 130/90/18 606, Maxxis Desert IT 80/100/21, 15 lbs street, dirt work best for me. About 3 sets a year.
AZ TOM is offline   Reply With Quote
Old 09-01-2013, 04:25 PM   #62083
gammel
gammel's Avatar
Oddometer: 529
I'm thinking I'll try the D606 rear MT21 front next. My front just started to wear like this on my trip to Utah.
Bergie
gammel is offline   Reply With Quote
Old 09-01-2013, 04:27 PM   #62084
gammel
gammel's Avatar
Oddometer: 529
In your forks?
Damn beat me to it!!
Bergie
Old 09-01-2013, 04:31 PM   #62085
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,662
In your forks?
yeah why?
Times are GMT -7.   It's 04:31 AM.
