Old 10-14-2013, 10:36 PM   #63526
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,357
Originally Posted by ZEmann View Post
and then one day when the kickstand spring breaks and it lowers to the asphalt just as your entering a turn or taking a jump
oh wait don't think like that
Happened in the Baja Rally. Had to take the kickstand off. it has to make it all the way around to make a jump. Most won't make it around. if it does, your suspension is too tight.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 10-15-2013, 12:00 AM   #63527
Spud Rider
Spud Rider's Avatar
Oddometer: 3,774
Here are some photographs I recently captured of the fall foliage in Idaho.
Spud
Old 10-15-2013, 05:50 AM   #63528
JWhitmore44
pistolero
JWhitmore44's Avatar
Oddometer: 1,619
Nice shots Spud, thanks for sharing!
84 Honda Goldwing (GL1200)
03 XR650L
JWhitmore44 is offline   Reply With Quote
Old 10-15-2013, 07:35 AM   #63529
mendoteach
mendoteach's Avatar
Oddometer: 1,591
Originally Posted by RZRob View Post
Spud, you're my hero and your timing is great. I've got a massive box of miscellaneous NIB Honda parts and it's almost too much to list. Now I can see what they fit and post accordingly. Thanks for the links.
RZ Rob
Thanks Spud. This will be a great resource when buying or selling.
mendoteach is offline   Reply With Quote
Old 10-15-2013, 08:15 AM   #63530
Ulyses
Ulyses's Avatar
Oddometer: 1,036
Originally Posted by ThumpnRed View Post
Quite the waste of time actually. I found out the hard way that locking the steering only makes more of a mess to fix when/if you recover the bike when it gets stolen. It's actually VERY easy to bust the steering lock on bikes. It also busts up the ignition which makes it easier to bypass the key.
The first time my old XL500 got stolen (recovered once, lost it the SECOND time) the thief simply torqued the steering, which also busted the bottom of the ignition loose. It was then a simple matter of turning the bottom of the switch to turn everything on.
Chain it to something or kiss it g'bye.
I don't know....I think every little thing you can do that makes your bike just that much harder to steal can be worth it, especially if you're far from home or, even better, in a different country. If it takes a would be thief one more minute to lift the bike or break the steering lock, that's one more minute that he might be spotted by someone or walked up on by me. Of course, if they do get it, like you said, it's going to be hell to fix..
Ulyses is offline   Reply With Quote
Old 10-15-2013, 08:23 AM   #63531
ZEmann
want to be riding
ZEmann's Avatar
Oddometer: 657
I agree
there seems to be 2 schools of thought with theft
the "I don't lock my doors so they don't break a window "
or the type like Me "I lock the doors , alarm, brake etc "
if I was in a sketchy area on my bike i would definitely lock the steering and padlock the disc
bikes are heavy and not being able to roll it up a ramp with the wheels straight and spinning may save you a walk home
I had a CBR for years in Cali and AZ two days after I sold it it was stolen
new owner did nothing to prevent theft I always did
ZEmann is offline   Reply With Quote
Old 10-15-2013, 08:44 AM   #63532
XR650L_Dave
Oddometer: 3,741
There are 3 wires, and if you do it right (leave the switch in place) the sidestand warning light will still work.
---->>Thanks for the rotor, guys!<<----
XR650L_Dave is offline   Reply With Quote
Old 10-15-2013, 10:17 AM   #63533
JWhitmore44
pistolero
Oddometer: 1,619
You can follow the wiring harness from the kick stand switch up under the seat. You will see the connector with the Green, Green with White stripe, and the Yellow with Black stripe connector. Connect the Green and the Green with White stripe together with your choice of connection. You can use a small jumper wire in the back of the connector, one of those scotch lock crimp on things, or cut and solder the two wires together. The side stand warning light will still work but the bike will still run with the side stand down, in gear, and the clutch released.
03 XR650L
Old 10-15-2013, 10:23 AM   #63534
mcma111
mcma111's Avatar
Oddometer: 12,249
WTB XR650l Front Hub
Anyone have a XR650l front hub that they will sell me?
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 10-15-2013, 12:04 PM   #63535
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,555
My XL500 that got stolen was quite the ordeal. I lived in a townhouse with a parking lot... nothing to chain the bike to. The first time around they popped the steering lock and had the ignition hot, but apparently didn't know the starting drill. I found the bike about a block from my house. I got a new ignition switch installed in it and wrapped a chain through both wheels so you couldnt roll it off. A few mornings later, I got up to go to work and it was gone. No broken bits and pieces in the parking spot like the previous attempt. I think they just lifted it up, tossed it in a truck and hauled it off. I always take solace in the fact that it was a really crappy dirt bike and hopefully maimed someone.
I agree
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Old 10-15-2013, 01:06 PM   #63536
mcma111
mcma111's Avatar
Oddometer: 12,249
New Hardware
I went for the thirty day check up on the knee job. I took a picture of the new hardware.
Kobalt and Chromium bitches.
All those little circles are the staples.
Yes, it still hurts.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 10-15-2013, 01:38 PM   #63537
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,328
Holy shit.....
Good to hear it`s helping you though Steve....but you are turning into Steve Austin slowly but surely....
B
techforlife is offline   Reply With Quote
Old 10-15-2013, 02:02 PM   #63538
mcma111
mcma111's Avatar
Oddometer: 12,249
Wanna see my shoulder X-Ray?
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 10-15-2013, 03:24 PM   #63539
techforlife
CDI REPAIR
Oddometer: 4,328
Seen that i think......you are gonna be a cyborg soon Steve
B
Old 10-15-2013, 03:40 PM   #63540
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,357
I'll show you mine.......
Times are GMT -7.   It's 04:59 AM.
