Old 02-04-2006, 11:24 AM   #1
KTM640Dakar OP
Motorsick
KTM640Dakar's Avatar
Oddometer: 2,123
Odyssey PC310 battery for a KTM 640
Has anyone tried the dry cell Odyssey PC310 battery in their KTM 640 Adventure? It is supposed to be vibration resistant and last ten years. They also recommend a special charger instead of a battery tender. Does anyone have any experience with these batties? Are they worth $118?
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
It is not the destination, it's the journey.
KTM640Dakar is offline   Reply With Quote
Old 02-04-2006, 11:40 AM   #2
2 SPOT
wannabe
2 SPOT's Avatar
Oddometer: 3,361
i dont have a real answer for you but,, worth the money? i dont know its a pespective thing. i can tell you that about 7-8 yrs ago i dropped an optima in my landcruiser that may go a month or so between drives, never a battery tender or charge needed it has been worth every penny of the $130 i spent on it back then.
IMO when its time for a new batt on my bike, my money will go to optima, odyssey ect. not a lead acid.
2 SPOT is offline   Reply With Quote
Old 02-04-2006, 02:31 PM   #3
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,261
I thought the stock battery was over $100 (well, bought thru a KTM shop anyways) so for a bit more that doesn't seem to bad. How much are you paying for the old style battery?
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 02-04-2006, 05:04 PM   #4
GODSPEED
finger lickin' good
GODSPEED's Avatar
Oddometer: 2,076
118 yikes.
Try ebay.
Odyssey World
Motobatteries
They don't have the 310 listed right now, but keep checkin or contact Odyssey World. I bellieve they are a factory direct seller.
Most people that have installed them like them.
Godspeed
I'd rather do it than watch it.
Those of you with spouse and SO's know this already, but man give them a big hug, and don't take anything foregranted. - MACK RIP
When 51% of the grasshoppers vote, the ants are screwed.
http://godspeed.smugmug.com/Motorcycles
GODSPEED is offline   Reply With Quote
Old 02-04-2006, 11:52 PM   #5
KTM640Dakar OP
Motorsick
Oddometer: 2,123
I just started looking for a battery. They have maintence free batteries on ebay for $24 plus shipping that are Chinese. I was also wondering if anyone has tried to upsize their battery and what they did if it's possible.
Old 02-05-2006, 01:40 AM   #6
Max Kool
Xtankteam™
Max Kool's Avatar
Oddometer: 3,240
I have an Odyssee on my Beemer sixfiddy. It gets shaken around just like it would on a properly used KTM. So far it has withstool all I threw at it (and all I threw myself against ). Very sturdy, and you never have to worry about acid leaking from it when you gently lay you bike on its side again.
Imho worth it's money (and in my case it weighs half as much as the stock battery).
Max Kool is offline   Reply With Quote
Old 02-05-2006, 02:47 AM   #7
rallybug
Local Yokel
rallybug's Avatar
Oddometer: 8,096
I may try one next on my NX - would you believe that the Odyssey is actually half a pound heavier than a Yuasa though (5.9lb to 5.4lb) even though the Odyssey is slightly smaller in each dimension
One major benefit for my bike anyway, is that that Yuasa has 120 CCA, against the Odyssey at 310, so hopefully that would mean I'd have to use the kicker less
Ben
My Ride Reports
rallybug is offline   Reply With Quote
Old 02-05-2006, 09:58 PM   #8
meat popsicle
Ignostic
Oddometer: 14,261
Hmmm, isn't everything made in China now? (don't know whether to laugh or cry about that one...)
Anywho, I have experience with putting, nay scratch that, with having a larger battery put into my brand spankin' new bike. Casper Mountain Motorsports in Wyoming thought that since Partz Limited sent them a battery that didn't fit into the battery box, why not tear the friggin' battery box out and stuff the bigger battery in there!
To make an old story short, there are a couple of bolts under the box that were slowly wearing their way thru the battery housing when it was found barely in time.
Why do you need a larger battery?
Old 02-05-2006, 10:06 PM   #9
KTM640Dakar OP
Motorsick
Oddometer: 2,123
They seem to be less expensive than the little one that they put in it.
I just installed a voltage meter to watch the charging voltage of my bike and it would only charge 13.7 volts when running 5000 rpm. I figured a larger battery might help if there is room.
Old 02-05-2006, 10:18 PM   #10
meat popsicle
Ignostic
Oddometer: 14,261
compact does have a premium...
I don't think there is more room, unless you could relocate (and rewire) the stuff sitting on top to somewhere else?
Old 02-14-2006, 08:31 PM   #11
KTM640Dakar OP
Motorsick
Oddometer: 2,123
So does anyone recommend a cheap source for Odyessy PC 310 bateries? Cheap being less than $118.
Old 02-14-2006, 09:19 PM   #12
Curmudgeon
Enjoying the ride
Curmudgeon's Avatar
Oddometer: 1,022
Odyssey is a 6 to 10 year battery. My 1150GS has been running one for 4.5 years and is just starting to fatigue. Great stuff, and easily worth the $118. Couldn't find one for anything less than $120 on the web.
Enjoy the juice.
Patrick
Live Long and Ride
Curmudgeon is online now   Reply With Quote
Old 02-15-2006, 09:42 PM   #13
BlitzBike
LC4 Pilot
BlitzBike's Avatar
Oddometer: 800
Checked around and found someone local who has the odyssea PC310 in stock. Will report back findings, price, fitment for KTM LC4 640
BlitzBike
BlitzBike screwed with this post 02-15-2006 at 10:55 PM
BlitzBike is offline   Reply With Quote
Old 02-15-2006, 11:06 PM   #14
BlitzBike
LC4 Pilot
BlitzBike's Avatar
Oddometer: 800
OK..heres the comparison the stock Yuasa is 150mm X 87mm X 93mm and the Odyssey is................................................ ......... 138mm X 86mm X101mm
So assuming the 8mm extra height will fit, the odyssey fits nicely otherwise.
The MSRP on the odyssey is 173.95 but, I see it everywhere on the net for a bit under 120.00 (circa 128.00 shipped). Not sure what my local retailer is asking. The yuasa usually retails for around 105 bucks but I see them on the net for 85.00 shipped.
The Odyssey boasts 310 CCA for 5 seconds compared to the yuasas 190 CCA and the odyssey is considered a deep cycle battery. The odyssey is also 1.1 Pounds lighter than the Yuasa (5.9 Lbs compared to 7 Lbs) ---yeahaw! Odyssey claims a 6 year service life which is supposed to be three times longer than conventional batteries. Except for the slightly higher price the odyssey looks like the clear winner. Its also lighter than the 7 Lb Westco battery.
BlitzBike
BlitzBike screwed with this post 02-15-2006 at 11:23 PM
Old 02-16-2006, 07:23 AM   #15
StokelyVanCamp
StokelyVanCamp's Avatar
Oddometer: 10
I have a Odyssey in my Dr. Big and love it, but another thing to consider is that apparently you cannot trickle charge the Odysseys. I haven't tried a trickle charger, but did buy a nice charger I found on sale that can throw a little more current at it. But it may factor in to the overall cost, if you have to get a charger as well. But for the record, it is still worth it in my books. I haven't had an issue starting the Dr. Big since I got it, even if it is really cool out and the bike has been sitting, and before I had hassles all the time, even with a brand new Yuasa
StokelyVanCamp is offline   Reply With Quote
Times are GMT -7.   It's 08:48 AM.
