09-04-2006, 12:16 PM
#46 | |
Ignostic
Oddometer: 13,843
And the top assembly does not contact the seat pan? It is pretty tight in there. I guess that it probably would.
Kronreif Trunkenpolz Mattighofen LC4 640 Its not so much staying alive; its staying human that counts. |
09-04-2006, 05:40 PM
#47 |
Formerly H20Pumper
Oddometer: 2,013
So MP where did you find the battery? No I didn't look in the Blipping index
I got a Wesco a while back from Road Rider, it fit fine. I also have an Odyssey in my BMW and it too required a bit of manipulation of the cables to fit. But like everyone has said it works great! Good luck. |
09-04-2006, 07:09 PM
#48 | |
LC4 Pilot
Oddometer: 800
BlitzBike |
09-04-2006, 08:04 PM
#49 | |
Ignostic
Oddometer: 13,843
The fella is closer to you - Gilroy actually. He is Yawan Smith of Kodiak Industries (http://www.kodiakinc.com/ - under development). He is a damn nice fella! He does service calls in San Jose, and dropped the battery off at my house on his way home last week... Then he chatted with me for a bit. I hope his customer service ethic pays off, 'cause we need more folks like him running businesses. BTW, his price on the PC310 was competetive with internet pricing , and there was no shipping of course. I will post more about him later, but he specializes in mobile power solutions for all types of HD industries (heavy duty, not Harleys... ). He is the only Odyssey battery outlet in Northern Cali. The Westco is plug N' play - no idea why Odyssey made the PC310 so weird...
09-30-2006, 10:39 PM
#50 |
Ignostic
Oddometer: 13,843
I am trying to figure out if I can mount the Odyssey battery, with a minimum of modifications.
![]() I am thinking to ask Eastern Beaver to make me some terminal relocation wires so I can hook the interconnects up where the Yuasa terminals were. I think it will be nearly impossible to connect to the positive terminal easily due to the fuse box wiring, and the negative terminal of the Odyssey actually contacts the underside of the battery bracket which holds the regulator/rectifier. Should be OK since the negative circuit leads directly there anyhow, but... ![]() That and maybe taking off the clip that hangs off the front of the battery bracket (#21) should help since the Odyssey wasn't designed to utilize this feature like the Yuasa or the WestCo. I can't imagine the battery really needs this clip since it would have to push this assembly up to get out, and the seat is right there. But again ![]()
10-12-2006, 09:55 AM
#51 | |
East Coast Rider
Oddometer: 482
So Is the Westco battery as good as the Odyssey for fit and quality....I need one for my '98 RXC "that has the original battery installed"
10-12-2006, 10:05 AM
#52 | |
Enjoying the ride
Oddometer: 1,020
So, it looks like low flow heads are the winners! And, everybody know 02's are the best anyway. Patrick
Live Long and Ride Curmudgeon screwed with this post 10-13-2006 at 09:05 PM |
10-12-2006, 10:07 AM
#53 | |
Ignostic
Oddometer: 13,843
I will have to post my installation sometime (going on vacation for a week so not soon), but I need to finalize it. I have the battery in, but I want to clean up the install so that it seems more "hearty" for dual-sport use. I did trim the battery bracket, but need to put a riser in the regulator/rectifier mount to make it fit better with the odd bit sticking up on the Odyssey. Then I think I can use the battery bracket as my negative return and drop the cable since the Odyssey's negative terminal will contact the battery bracket. NEEDS TO BE TESTED OF COURSE. Then some work on the positive terminal's relocation wire that I built so it doesn't contact the fuse box (I am concerned about vibration wear/fatigue issues) and really lock in the positive interconnect to it, and... I might be satisfied.
10-12-2006, 10:13 AM
#54 | |
Enjoying the ride
Oddometer: 1,020
2003 KTM 640 Adv battery box: 584.03.002.370 Given the above, 99-02 can use an Odyssey PC310... Ya Ho! Patrick
Live Long and Ride Curmudgeon screwed with this post 10-13-2006 at 09:04 PM |
10-12-2006, 11:24 AM
#55 |
Ditchboy
Oddometer: 12
www.BatteryMart.com
ODY-PC310 Enersys ODYSSEY PC310 117$ after shipping. fits fine in '01, spins up like the spark plug is out. |
10-12-2006, 11:47 AM
#56 | |
Ignostic
Oddometer: 13,843
When you have yours apart and are doing the install, please take some pics.
10-12-2006, 11:57 AM
#57 | |
Enjoying the ride
Oddometer: 1,020
Patrick
Live Long and Ride |
10-12-2006, 12:11 PM
#58 |
LC4 Pilot
Oddometer: 800
I wanna hear reports about how your bikes start with the Oddysea
PC-310? I'm beginning to lose faith in my current mechanic. I have the Oddysea installed and have thus far replaced the starter and next will be the rectifier to try and cure a sluggish intermittent starting/charging issue. He does not have faith in the Oddysea but I know its not the battery because I've run FOUR! different batteries through this bike (2 yuasa and 2 Oddysea) without curing the problem. So you guys tell me....Does this PC310 start the bike fine once the installation hassles are overcome? Could the rectifier coming in contact with the terminal cause problems as well? I suspect something is lacking continuity or grounding somewhere.
BlitzBike |
10-12-2006, 01:04 PM
#59 | |
Ignostic
Oddometer: 13,843
If you installed the PC310 with the +/- in the same configuration as the Yuasa was - negative on the port underneath the battery bracket and positive on the starboard underneath the fuse box - then there would not be an immediate problem with those components contacting the terminals. The negative is simply your return circuit, and it can touch pretty much whatever metal you want it to touch that is part of the return circuit (i.e. grounded to the frame) because the frame IS your return circuit. Note what your negative interconnect is currently connected to... The positive should only be touching the rubber housing of the fuse box, so it should not be an issue, although I am worried that with time and vibrations it might wear thru the housing and/or damage the fuse box internals. If you reversed the battery, and the positive is now on the opposite side, and contacting the underside of the battery bracket (perhaps by wearing thru the positive interconnect's rubber boot) then you would have a problem. But your mechanic should know this stuff, it's basic. Perhaps your mechanic is not adept at electrical work? You should post your complete sorrid tale, including when you did what and when specific issues occurred and what was done to rectify those issues and... perhaps someone will be able to help. I don't know if the Odyssey could cause such issues; for sure an improper installation could.
10-12-2006, 03:02 PM
#60 | |
Formerly H20Pumper
Oddometer: 2,013
Hey MP are you talking about boats or bikes?? PORT/STARBOARD Did you get my MT pics? Have a great week off. |
