Old 10-12-2006, 05:39 PM   #61
Pezz_gs
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,808
Originally Posted by BlitzBike
I wanna hear reports about how your bikes start with the Oddysea
PC-310? I'm beginning to lose faith in my current mechanic. I have the Oddysea installed and have thus far replaced the starter and next will be the rectifier to try and cure a sluggish intermittent starting/charging issue.
He does not have faith in the Oddysea but I know its not the battery because I've run FOUR! different batteries through this bike (2 yuasa and 2 Oddysea) without curing the problem. So you guys tell me....Does this PC310 start the bike fine once the installation hassles are overcome?
Could the rectifier coming in contact with the terminal cause problems as well? I suspect something is lacking continuity or grounding somewhere.
How many miles has your bike done?
Check the switch block for power leakage / short?
Check the Capacitor?
Price of a new Harness from KTM - $110.00 cheaper than a battery?
Sounds like a bad earth / broken wire somewhere in the harness.
Pezz :)
Airhead Tragic
I'm not a complete idiot -- Some parts are missing
XR460/4 - http://www.advrider.com/forums/showthread.php?t=497905
Pezz_gs is offline   Reply With Quote
Old 10-12-2006, 07:40 PM   #62
BlitzBike
LC4 Pilot
BlitzBike's Avatar
Oddometer: 800
Pezz :)
13,000 Highway miles on the Odo....thanks for the tips!
BlitzBike
BlitzBike is offline   Reply With Quote
Old 10-30-2006, 01:59 PM   #63
Pezz_gs
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,808
Blitz
A few months ago I sold a 640 Rallye which i'd converted to electric start.
The guy who bought it from me has had a 'charging problem' bike hard to start. It kick starts easily. It appears it may have been the starter motor causing the problem . . . He put 12 volts directly on the starter and got sparks out of it. It must be drawing a lot of current.
Might be worth checking also . . . . .
Pezz :)
Airhead Tragic
Old 10-31-2006, 07:35 AM   #64
BlitzBike
LC4 Pilot
BlitzBike's Avatar
Oddometer: 800
Blitz
Pezz :)
Thanks for the suggestions....I've relayed them to the mechanic...so far I have a new starter motor and now he is putting in a new rectifier. If that ain't it, I got the rest of your list to pursue! I should note this sluggish starting/charging issue has been an issue since the bike was new. Wish I would have pursued it when the bike was under warranty but, it usually started (grudgingly).
BlitzBike
Old 11-04-2006, 02:43 AM   #65
Curmudgeon
Enjoying the ride
Curmudgeon's Avatar
Oddometer: 1,022
Originally Posted by meat popsicle
Patrick,
When you have yours apart and are doing the install, please take some pics.
Originally Posted by Curmudgeon
Will do.
Patrick
Well, here's the Odyssey PC310 from Battery Mart. Delivered to my door for $109... Took a week to get it.
Looks like a battery!
Not a perfect fit, but it could work.
A few strips of electrical tape to protect the Odyssey and we'll have to see if the battery hold down brachet rubs the battery.
Actually, the PC310 is smaller than the rubber battery container in the battery box, so I was able to push the battery towards the front of the bike and pad the contact point right at edge of the lump on top of the battery. I can't move the battery at all, so we'll have to see how it holds up.
Patrick
Live Long and Ride
Curmudgeon is offline   Reply With Quote
Old 11-04-2006, 06:26 AM   #66
BlitzBike
LC4 Pilot
BlitzBike's Avatar
Oddometer: 800
$109...Thats the best price I've seen!
BlitzBike
Old 01-03-2007, 12:39 PM   #67
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,980
Any further word on the install on an '03 640A?
Am looking for a thumbs up, down, or head for the hills from the other inmates because fitting the Odyssey PC-310 is a screaming biotch for what otherwise should be a straight forward install.
If you think McGyver could make it fit, I'm willing to give it a shot.
I'm tired of using the kicker if the bike sits for more than a day and need a new battery.
Dirty
No, really, the mustache means I love you.
dirty_sanchez is offline   Reply With Quote
Old 01-03-2007, 12:43 PM   #68
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,243
check your PMs dirty -
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 05-09-2007, 06:27 AM   #69
rw4x4van
East Coast Rider
rw4x4van's Avatar
Oddometer: 548
Question Yuasa/Odyssey..........that is the question????
Last year I replaced the stock lead acid battery in my V-Max, with an Odyssey and it's a much better battery and one that starts the bike with more authority.....
...but After 9 years the stock Yuasa YTX9-BS Battery needs to be replaced in my '98 RXC
Now if I understand correctly the Yuasa YTX9-BS Battery and the Odyssey PC-310 are both AGM batteries
What makes the Odyssey AGM a better battery than the Yuasa AGM.........
Ray
'98 KTM 620 RXC
'07 KTM 300 XCW
rw4x4van screwed with this post 04-06-2008 at 02:54 PM
rw4x4van is offline   Reply With Quote
Old 04-06-2008, 10:09 AM   #70
Rogue_Ryder
速 Flat Biller 速
Rogue_Ryder's Avatar
Oddometer: 7,695
What makes the Odyssey AGM a better battery that the Yuasa AGM.........
Anyone?????
I'm looking at a new battery for my LC4E, and if AGM is AGM why pay more than DOUBLE for the Oddesey????
Braaaap!!!!
Rogue_Ryder is offline   Reply With Quote
Old 04-06-2008, 11:59 AM   #71
meat popsicle
Ignostic
Oddometer: 14,243
Originally Posted by Dukeryder
Anyone?????
Compare and decide:
Yuasa specs:
http://www.yuasabatteries.com/batter...bID=B9&vID=891
Odyssey specs:
http://www.odysseyfactory.com/powerspecs.html
http://www.odysseybatteries.com/battery/pc310.htm
Old 04-07-2008, 02:40 PM   #72
nfranco
over macho grande?
nfranco's Avatar
Oddometer: 781
Well? How's it holding up?
Patrick
nfranco is online now   Reply With Quote
Old 04-13-2008, 01:08 PM   #73
motowest
Two-wheeled Adventurer
motowest's Avatar
Oddometer: 1,300
So, I guess the jury is still out?
It looks like the Odyssey is not an exact fit and that makes it slightly less desirable than the Yuasa. How are the McGyver-types doing with the battery?
motowest is offline   Reply With Quote
Old 04-13-2008, 01:31 PM   #74
rw4x4van
East Coast Rider
rw4x4van's Avatar
Oddometer: 548
I ended up with the Yuasa battery for less than $50.00. My garages aren't heated and my one bike has an Odyssey and the KTM has the Yuasa and neither one had any problems starting,.... and with no battery tenders or chargers over the winter.
My stock Yuasa lasted 9 years,...... can't ask for more than that
Ray
'98 KTM 620 RXC
'07 KTM 300 XCW
Old 11-28-2008, 03:18 PM   #75
clarky
05' 640 Adv
clarky's Avatar
Oddometer: 460
Meat did you end up getting your PC310 to fit properly? And have there been any nasty vibration or rub issues on the terminals and wiring?
Also has anyone tried to fit one to an 05 Adventure? I know that KTM loves changing little things between years, did the battery boxes change from the 02/03's to the later models?
You fella's get some top prices, the best price in Aus atm is $225
cheers
Clarky
Northern NSW
AUSTRALIA
clarky is offline   Reply With Quote
Times are GMT -7.   It's 04:08 PM.
