Old 04-25-2010, 02:18 PM   #106
Ricardo Kuhn
a.k.a. Mr Rico Suave
Ricardo Kuhn's Avatar
Oddometer: 12,407
Originally Posted by BDXMPL
It should have come fully charged from the distributor, so I wouldn't be very happy about a new "dead" battery. Since you got yours on e-bay, getting a "fresh" one might not be do-able.
In terms of charging, you're going backwards. You want to start with higher amps and work your way down. I would start at 40 amps for an hour, and check to see if you reached 14.75
After that, 4-6 hours at 10 amps, then a maintenance charge (Battery Tender) after that.
Hunter
Thanks for the advice Hunter, I will keep it at 40amps for a few hours and see what happen.
PS: I purchase two 680 battery's for my GS's and they came fully charge, But I also know this vendor sells a tons of this things to the Harley guys so i'm surprise this one did not have a charge.
Wanted: worn, ugly, cheap motorcycle cover for a big GS 1200
Ricardo Kuhn is offline   Reply With Quote
Old 04-25-2010, 04:08 PM   #107
BDXMPL
The Sheriff
BDXMPL's Avatar
Oddometer: 1,016
No problem, but be careful, too much time at 40 amps could cause some damage.
I would check it every hour or so, until it hit 14.75
Hunter
Then the world exploded, and my head fell off.
BDXMPL is offline   Reply With Quote
Old 04-25-2010, 06:15 PM   #108
Ruffus
Dirty Old Mudder
Ruffus's Avatar
Oddometer: 4,091
Hunter
At 40 amps, even the big Optima in my jeep has never needed more than 15 to 20 minutes on an ice cold winter night.
I think if I needed to give a small bike battery that kind of boost, I'd just grab a beer & watch it for a few minutes. It should charge up rather quickly at that amperage.
We spend our lives chipping away at our ignorance :wisdom by Dakez
Friendship is like peeing your pants, everyone can see it, but only you
can feel the true warmth.: wisdom by ??
Reverse Darwinism...he's only alive because he's to stupid to die. : wisdom by AZRamjet
06 Husky TE510
Ruffus is offline   Reply With Quote
Old 04-25-2010, 07:03 PM   #109
See-Double-You
See-Double-You's Avatar
Oddometer: 1,674
Whoa... You might want to read up the technical documentation @ the odyssey website.
http://www.odysseybatteries.com/files/techbook.pdf
CW
" Suggest you stick with failure analysis of Pork Chops " - -Benesesso
See-Double-You is online now   Reply With Quote
Old 04-25-2010, 09:18 PM   #110
Ricardo Kuhn
Oddometer: 12,407
Hunter
Thanks that was my Fear when using the 40amp mode.
Old 04-25-2010, 09:20 PM   #111
Ricardo Kuhn
Oddometer: 12,407
Thanks a bunch..
I guess I have a defective battery since mine spend a few hours in the 2amp mode with out a sign of anything
Old 04-25-2010, 11:42 PM   #112
See-Double-You
Oddometer: 1,674
The Odyssey has specific charging requirements.
You need to read the provided link.
6amp is the mimimum charging current with a discharged battery. You can use a 2amp charger to keep a battery topped off, but only with a battery that's already close to 100% capacity.
Despite all the hoopla and long life claims it's important to use a battery tender or disconnect your battery during storage. My new (last summer) $100 PC310 didn't last through the winter. I was complacent and perhaps a bit ignorant and just left the battery in the bike as I'd done in previous years. As a result my battery voltage was down to 8.2 at the begining of spring.
A Ctek charger was able to get the battery charged up to 12.8, but the battery won't hold it. After sitting for a few hours, the battery reads 12.4 volts and the bike is slow to start. According to Odyssey 'state of charge' chart, my battery capacity is down to about 60% of what it was when new. An expensive mistake on my part.
Although the Odyssey has a number of benefits, the overall capacity is less than OEM in my particular use. OEM was a 12 amp hour, and the Odyssey is a 7 or 8 AH. I've since replaced the PC310 w/ a 14 AH capacity AGM battery.
Moral: take care of your battery.
CW
Old 04-26-2010, 11:27 PM   #113
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,248
Thanks a bunch..
Hey Ricky
Should have come charged; what was the date on the battery's cardboard box?
I was sold an ISA Charger (Canadian) by my vendor (who is a knowledgeable bloke), and it is only a 3A. But it says (and he said) it will charge a dead battery. It is also designed for gel, and AGM (absorbed glass mat - Odyssey) batteries. I think the Ody is 14.89v max, or you will damage it. Amps don't matter.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 06-20-2010, 12:59 PM   #114
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,276
deka ext9 is also a sealed agm. it's a quality made in the us battery.
i've gotten atleast 4+ yrs on the ones i've used. maybe the ody will last a little longer but you could buy 2 deka for the 1 ody.
http://etx9.com/
http://www.batteryprice.com/deka-etx...gmbattery.aspx
Alaska
Butler Maps website:
http://www.butlermaps.com
Times are GMT -7.   It's 10:51 PM.
