Old 02-05-2006, 10:41 AM   #1
sherpa OP
...Robert
sherpa's Avatar
Oddometer: 3,183
640 Counter Sprocket Question
I replaced my 16T with a 15T sprocket today, and being a noob with all things about chains/sprockets...I ran into a few questions. It's an 05 640, I'm the original owner, and I've got 1600 miles on it...
1) Why was there no locktite on the counter sprocket nut and why did it just spin off with hand pressure....good thing the flanged washer was bent over the nut ...
2)The original 16T sprocket had a rubber flange on each side...the 15T sprocket did not. Uhmmmm...looked in my 05 parts book....no rubber flanges...got on the computer and pulled up the 03 parts book...no rubber flanges there either. Okay...the rubber flange must separate and I'll just switch it over to the 15T, because it had the same holes for the rubber as the 16T. That didn't work....the rubber flanges aren't designed to separate....they tear instead. So I just put the 15T sprocket on without the rubber flanges.
What is the function of the rubber pieces, obviously they are not the norm?
3) Does the particular sprocket setup affect chain tension. The diagram in my 05 manual shows the three ratios 15:45 16:42 17:42.
I've got a 15:42 on there now to give it a try...does that change the amount of sag/freeplay I want in the chain.......I wouldn't thing so, but the manual listing those ratio's got me wondering....
Trebor Home Inspections
05 640 Adventure
08 KTM 250 XCFW
I'd trade all my motorcycles for one Flying Dragon.
sherpa screwed with this post 02-05-2006 at 10:48 AM
sherpa is offline   Reply With Quote
Old 02-05-2006, 10:58 AM   #2
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
The rubber flanges are original equipment only. To my knowledge, they are there to aid in passing noise regulations for a new bike and serve no other purpose.
Don't know why the nut wasn't loc-tited... maybe because it has a locking tab.
KTM started using the nut in either '04 or '05 on 640As. '03 and earlier use a bolt like the 660 Rallye, and they come with a dry loc-tite patch applied.
They've used both methods for years on various models... why I don't know.
This is my arrangement... running a 15:40 set.
Question number three. Gearing (within limits) does not effect the method of establishing chain tension or the specification. If you had something way different... then the point of reference for chain tension would no longer be accurate, but the total movement of the chain would remain the same.
C
So... how's tricks?
creeper is offline   Reply With Quote
Old 02-05-2006, 11:03 AM   #3
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Hey Creepy....
What style o-ring does your fancy gold sided Regina use? I'm about due for a drive train update...
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 02-05-2006, 11:05 AM   #4
rjf
SBS's #1 fan in January
rjf's Avatar
Location: Gosford, NSW, Aust. Scrambler, 640Adv, 300EXC
Oddometer: 4,376
Hey Serpa,
My stock '03 had the rubber damper thing. I replaced it with chain gang.com.au sprocket's with no rubber stuff. I read a post a while back where they thought the rubber was for noise reduction. I guess its either that or to try and debris from getting down to the shafts seals, mabye.
Re chain tension you will have to adjust it, if thats what you mean, but it shouldn't be too far out with only 1 tooth difference.
If you cannot get it tight / loose enough using the adjuster bolts, you can rotate the adjuster blocks around 180 deg. to try and get it back in range, as the parts that touches the adjuster bolt head are different lengths on either side of the axle.
I just re read your post "does that change the amount of sag/freeplay I want in the chain". My appoligies if you allready knew the above. I don't think it would.
Central Coast ADVenture bike training courses and 1 on 1 lessons - For details Click HERE
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadslide, thoroughly used up, totally worn out and loudly proclaiming- WOW-WHAT A RIDE!
rjf is offline   Reply With Quote
Old 02-05-2006, 11:10 AM   #5
rjf
rjf's Avatar
Oddometer: 4,376
Creep and CrisC - fook you guys can type quick.
Originally Posted by creeper
. '03 and earlier use a bolt like the 660 Rallye, But of course they'd use the same system on the 2 uber bikes.
there's a lot off built up grime all over that. do you ever clean your bike Creepy ?
Old 02-05-2006, 11:29 AM   #6
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Chris
1943 BSA M20WD
Old 02-05-2006, 12:01 PM   #7
sherpa OP
...Robert
sherpa's Avatar
Oddometer: 3,183
Noise reduction......that would of never crossed my mind....thanks for the replies....
One more question...Looking in The World Famous Index Thread under the gearing thread, there is mention of a downloadable spreadsheet for calculating various sprocket combinations...the download link is not working...is that spreadsheet still available?
Here's the spreadsheet... http://www.advrider.com/forums/showp...6&postcount=50
05 640 Adventure
08 KTM 250 XCFW
Old 02-05-2006, 12:30 PM   #8
markjenn
Oddometer: 10,482
I think we concluded a while back that KTM is not shipping any replacement sprockets with the rubber dampers. They're not necessary.
Whether your bike uses a nut or bolt to secure the CS sprocket (they changed it at one point), I'd use loctite. The loosening of this fastener is a problem area. If you have the earlier bolt-style, you need to be cautious of torque - we've had a few bolts break off and there are two different strength bolts (12 and 8) spec'd with a different torque for each. Personally, I think using the stronger bolt and the lesser torque (loctited ) is probably the safest bet. Drilling the cover and using locating marks to keep an eye out for loosening is a great idea that I haven't done (yet).
15, 16 or 17 in front can generally be compensated for by the chain adjusters in the rear without changing chain length. But, of course, you do need to adjust the chain when you change sprockets to return to the appropriate free-play. Which BTW, is also a tricky issue - it is very easy to adjust the chain too tight. The spec is to put the bike on centerstand and have the chain just be barely able to touch the swingarm on the bottom run aft of the plastic swingarm pivot guard. It's not a bad idea to strap the bike down and make sure this adjustment isn't too tight. I was surprised that this spec, which seemed loose on the centerstand, was slightly too tight with the suspension compressed worst case (where the axle, swingarm, and countershaft axis are all in a straight line).
Cheers,
- Mark
Old 02-05-2006, 12:39 PM   #9
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
Originally Posted by ChrisC
Hey Creepy....
Regina ZR brother CC.
So... how's tricks?
Old 02-06-2006, 01:40 AM   #10
The Misinformant
What road?
The Misinformant's Avatar
Oddometer: 350
I have a 15 16 and 17T front depending on what I am doing (still running a 42 rear). About to fit a 44 rear as I find the 17/42 just a bit to tall with a load on, big winds, cruising at 110kph.
Hopefully the 17/44 will put me a little taller (somewhere between stock 16T and the 17T). It will make the 16/44 just a bit shorter than stock and the 15/44 will be good for silliness and some of the really snotty rocky hill climbs here.
I like the design of the chain adjuster blocks as when I run the 17T front and set the chain tension (the blocks on the short side) and if I change to the 15T front only need to flip to the long side and not need to play with the adjusters. It is a big difference in gearing though. Works good to go somewhere - quickly change then a quick change to come home.
By the way "go some where" often means 500-900km each way.
The Misinformant is offline   Reply With Quote
Old 02-06-2006, 02:53 AM   #11
braaap!
waiting for the big one
braaap!'s Avatar
Oddometer: 2,474
Originally Posted by The Misinformant
......By the way "go some where" often means 500-900km each way.
So Mate, you musta' been on the test team for the 03 (uber?) seat design
No wonder rjf needs medication!
braaap! is offline   Reply With Quote
Old 02-06-2006, 05:10 AM   #12
sherpa OP
...Robert
sherpa's Avatar
Oddometer: 3,183
I didn't have to switch the blocks around, on my 05, going from the 16 to the 15...and I'm guessing, but it doesn't look like I'll have to switch them to bump up to try the 17, plenty of threads on the adjuster bolts...the blocks are short side forward...maybe there have been some changes to the business end of the swingarm...
05 640 Adventure
08 KTM 250 XCFW
Old 02-06-2006, 07:22 AM   #13
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,247
Hey you use the same grease as me
The spreadsheet is available in my Yahoo Briefcase under "External Links to Other Downloads" (sic). Lots of stuff in there; help yourself and enjoy.
ps - "changes to the business end of the swingarm" would be unlikely under my guesstimation if it means redesigning a swingarm or retooling a production run. Unless it means big improvements. What will be interesting to see, not that you will remember this by the time you get there, is if you can adjust your chain thru it's entire lifespan (stretch) on both sprockets. In case you can't the reverseable spacers might come in handy at some point.
pps - Speaking of doing the creepy mod and drilling the CS cover, I wish we had an inside guy who could make the rallye CS cover available. I'm not dredging up a pic (they are everywhere) but their CS cover just covers the top and a bit of the front so you can see pretty much the whole she-bang (WTF is that word anyways ). I looks like a plastic part like ours. Perhaps I will cut mine off to match.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 04-14-2011, 06:30 PM   #14
bikepikespeak.com
bikepikespeak.com's Avatar
Oddometer: 598
I'm trying to set my bike up to switch between 16 and 17 CS sprockets. I'm starting out with the 16 up front and it won't take much adjusting to change to 17. My question though is: Is there anyway to change these w/o breaking the chain? From what I can figure there is not. Correct? If that is true and you need to break the chain how many times is it safe to break it at the master link and re-mushroom it again?
bikepikespeak.com is offline   Reply With Quote
Old 04-14-2011, 07:52 PM   #15
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,544
If you let off the adjusters, maybe run the chain off the back sprocket, wiggle stuff around a bit, you should be able to swap front sprockets without removing the chain. It might be a bit tighter with a 17T, but I swap from 16 - 14 now & then no probs.
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Times are GMT -7.   It's 03:02 PM.
