Old 02-06-2006, 08:05 PM   #1
kv OP
[none]
kv's Avatar
Oddometer: 5,049
Gerbing's Liner and Aerostich On/Off Switch Question
Can I use an Aerostich on/off switch with a Gerbing heated jacket liner? Gerbing's literature makes mention that only Gerbing's devices (temp controller, on/off switch, etc.) should be used with their products. My Aerostich on/off switch plugs directly into the liner so I'm hoping it works as I will not have to purchase a temp controller.
Save $5.00 on a subscription to Smugmug by entering SmYAucfONBnH2 in the 'Referred by' field on the signup form.
kv is offline   Reply With Quote
Old 02-07-2006, 02:55 AM   #2
moymurfs
moymurfs's Avatar
Oddometer: 2,192
If the coax connector is the same you shouldn't have a problem. At the worst you would blow the fuse. You may want to consider a temp. controller switch. Before I got mine I had 2 settings ON=BROIL OFF=FREEZE.
moymurfs is offline   Reply With Quote
Old 02-07-2006, 08:43 PM   #3
kv OP
[none]
kv's Avatar
Oddometer: 5,049
I had one but sold it after I found that I wasn't using it as much as I thought I would. I don't know but my liner just never seems to get as hot as everyone elses. I sent it to Gerbing's and they installed somer warmer panels in the arms and took it in a little in the mid-section. It's better but not the 120 degree oven I hear others rave about. It's wired directly to the battery so I know it's getting full power.
Times are GMT -7.   It's 05:30 AM.
