Old 01-21-2003, 07:47 AM   #1
jimjib OP
Oddometer: 1,649
Sag numbers for 02 adventure
jimjib is offline   Reply With Quote
Old 01-21-2003, 08:14 AM   #2
Cat0020
El cheapo
Cat0020's Avatar
Oddometer: 5,560
Cool2 Re: Sag numbers for 02 adventure
I assume that you are looking for the suspension sag?
That really depends on what type of riding you are doing, how much does the rider/luggage weight, and also how fast/far do you plan on riding..
For normal on-pavement commute, with myself and 40lb. of luggage weight (total of 180-190lb.) I set the sag at 1.75-2.5 inches from free bike. I load up the preload for compression (to minimize brake induced diving) and set damping at mid-point... not much chance to take multiple impact from rough tarrain on-pavement.
For off-pavement.. that's whole different issue.. and make great difference what kind of terrain you are riding in... I usually experiment with my mountain bike first.. to see what kind of suspension setup would be suited.
Mankind is doomed & Physics do not lie
Chances favor the prepared mind.
Cat0020 is offline   Reply With Quote
Old 01-21-2003, 09:29 AM   #3
jimjib OP
Oddometer: 1,649
I guess thats the front numbers...with you sitting on the bike, correct? What are the rear numbers?
I like a soft ride up the fire roads...I dont push it hard or launch the thing. I weigh 210 and have added hard bags...just went to a bit stiffer spring also.
Old 01-21-2003, 09:30 AM   #4
jimjib OP
Oddometer: 1,649
Actually your numbers sound more like no rider.
Old 01-21-2003, 04:51 PM   #5
Randy
Randy's Avatar
Oddometer: 2,362
Said jimjib:
i agree. ordinarily your sag should be set so that, with you on board in your normal riding position and wearing your normal riding gear, your suspension is compressed somewhere around 1/4 - 1/3 of its total travel. so, put the bike on the center stand to unload the suspension and measure from the center of the rear axle to a convenient point on the sub frame or rear body work. then suit up, get on the bike in your normal riding position with someone else helping balance the bike. bounce up and down a couple of times to settle the suspension and compensate for stiction. now have someone measure from the axle to the same point on the frame or bodywork. subtract the two and it should be about 1/4 -1/3 of the total suspension travel. if not, adjust accordingly. this is not exact but just a general rule of thumb. rider sag is diferent from static sag in that static sag is a measure of how much the bike compresses the suspension on it's own. if you have to crank preload up so much to achieve proper rider sag, that you don't have enough static sag then you need a stiffer spring with less preload. conversely if you have to back off so much on preload to achieve proper rider sag that you have too much static sag you need a softer spring with more preload.
the same procedure is used to set sag at both ends.
many people ride around on bikes with improper sag settings or spring rates and never really know the difference and are quite happy with it. but to get the most from your suspension it needs to be set up properly. of course it depends on your skill level and riding style to determine just how important it is.
maybe of more importance is that the sag is properly balanced, front to rear, as this can have negative consequences on geometry. this will have a more pronounced affect, for more riders, than just having wrong sag settings.
have to little sag allows the suspension to top out too often on rough terrain, loosing traction, while having to much lessens the amount of available travel. both situations adversely affect traction, handling and ride quality. it is best to have the suspension working in the proper portion of it's stroke.
"some might call it a 'midlife crisis', I prefer to call it a renaissance of thought and action"... "Life is too short to do anything other than that about which you are absolutely passionate."..."Adventure is a frame of mind, set upon by action, not defined by equipment."..."It all boils down to your ability to say "SCREW IT" and really mean it"....Randy
Randy is offline   Reply With Quote
Old 01-22-2003, 06:11 AM   #6
Cat0020
El cheapo
Cat0020's Avatar
Oddometer: 5,560
Cool2
Maybe I was not clear the first time..
The sag measurment that I posted first was for on-pavement commuting, not for off-pavement.
I don't know what the pavement is like in other parts of the country, but in my area, it is pretty smooth with maximum bump size of 2-4 inches, some manhole covers, some potholes.. that's it.. not 2 foot dropoffs.
Old 01-22-2003, 11:24 AM   #7
motu
Loose Pre Unit
motu's Avatar
Oddometer: 4,566
You also have balance front to rear - do your rear sag as Randy says,then put your foot on the rear brake lever and push down on the peg with your foot - the bike should go down level,work on the front to get a balance.Long time since I've done it,please correct if I'm wrong.I am light and always set my bikes up soft,I don't mind the bike moving around,but at higher speeds I get some air time which can give wobbles if I come down crooked.
motu is offline   Reply With Quote
Old 01-22-2003, 11:34 AM   #8
motu
Loose Pre Unit
motu's Avatar
Oddometer: 4,566
Lucky I'm getting a new computer next week,it didn't load all of Randy's post,I thought it was an image and didn't wait.
Old 01-22-2003, 06:26 PM   #9
Randy
Randy's Avatar
Oddometer: 2,362
even if you do exclusively street riding your suspension will give you the best handling if set up properly. suspension setup is a huge part of roadracing and your best bet is to setup your suspension so that it will work within it's design parameters. too soft will allow for more hobby-horsing from abrupt throttle changes and braking. too hard will cause poor ride quality and more subtle negative effects on handling. more importantly, maybe, for street use is your damping settings. i would set the sag up as i advised earlier but you can get away with much more rebound and compression settings both front and rear. you will have better control and stability and an all around better handling bike if you set the suspension up properly. it's not a huge issue. as i stated in my earlier post, a lot of people ride around their whole lives without proper setup and never know the difference and are completely happy. but, for me, the KTM has really good suspension compared to a lot of bikes and i like knowing that i have it set up to extract the maximum performance. it all depends on your perspective.
Old 01-22-2003, 06:58 PM   #10
Cat0020
El cheapo
Cat0020's Avatar
Oddometer: 5,560
Cool2
Said Randy:
That it true... so why would your perspective of sag setting make a difference to anyone elses' riding???
Old 01-23-2003, 04:03 PM   #11
jimjib OP
Oddometer: 1,649
I think the point is that the sag settings should be set pretty much the same no matter how and where you ride. If your bike has more sag than than the base setting or a ton of preload jacked in to get those settings...you need stiffer spring.
Old 01-23-2003, 06:31 PM   #12
Cat0020
El cheapo
Cat0020's Avatar
Oddometer: 5,560
Thumbs down
Said jimjib:
You might be contradicting yourself with that..
I would think that suspension sag setting should vary drastically with riding style and terrain.. also especially with a rider's weight.
Given the fact that my weight 135 lb. is about 25% less than someone 175 lb. which could translate to 10% difference in total weight of rider and bike.
Given the fact that you weight 210 lb. yes, you are right, you definately have more sag than me.
Old 01-23-2003, 08:35 PM   #13
motu
Loose Pre Unit
motu's Avatar
Oddometer: 4,566
No,the whole point of a sag setting is that it's a constant,the only things that will alter it are your weight or the weight you put on the bike.You alter how the bike responds with the dampening settings,if you have to go back to the springs then something is wrong.
Old 01-24-2003, 04:42 AM   #14
Cat0020
El cheapo
Cat0020's Avatar
Oddometer: 5,560
Cool2
Said motupaika:
Are you saying that sag should be constant regardless of riding terrain?
Think again, dude..
Old 01-24-2003, 11:59 AM   #15
motu
Loose Pre Unit
motu's Avatar
Oddometer: 4,566
Yes,you are matching spring preload to your riding weight,you should only need to change it for very extreme conditions or some fine tuning.You might want a softer ride if you only ride on the road,or if you are getting supercross airtime you might go stiffer.When I was riding off road,with my bike correctly set up,I could ride on open very rough terain in 5th gear using up all my 12in travel,getting air time,and yet still have it soft enough to go in under trees etc..My current bike has no rear spring,just an air shock,but the same rules apply.
Bottom line - trust the guys who designed your bike and suspension,if it was made for serious use in the last 20yrs,suspension will be well sorted.
Times are GMT -7.   It's 01:54 PM.
