Old 02-13-2006, 05:58 AM   #1
Texmoto1 OP
Adventure Berzerker
Texmoto1's Avatar
Oddometer: 274
Hard Starting 950?
I have a 2 week old 950 Adventure that just doesnt like to start. I end up having to crank the thing several times for 7 or so seconds at a time before it fires up. After it starts it runs and acts normally. If I shut it down and emmediately restart it.. no problem. If I leave it for more than even a minute I have to crank like crazy! Sometimes it acts like its flodded, and if I open the thing wide open it slowly cranks to life. The bike has not had its 600 mile service yet, and Curtiss said he will sort it out at that time, but I would rather not deal with the problem that long. Any ideas?
Texmotos Photos
Texmoto1 is offline   Reply With Quote
Old 02-13-2006, 06:39 AM   #2
Pantah
Patriot Nation?
Pantah's Avatar
Oddometer: 10,182
gas in your evap cannister
when you stopped after a refuel, shut off motor and walked away, your hot motor expanded fuel in tanks and the pressure backed fuel into your evap cannister though the tank vent hoses. maybe you have another problem, but what i discribe is common. the evap cannister will dry out in a few days and it'll be normal until the next time you refuel to the tippy top and walk away. the same thing can happen if you drop it. the cannister fills with gas and the motor starts like its flooded. if doesn't clear up in a few days take it in.
for the future you may want remove the evap cannister system after your warranty expires. or you may want to simply unplug the vent hose between the tanks at the connector under your headlight. i got into the habit of not filling to the top, and then if i needed to stop and leave it for a few minutes right after, i popped open the gas caps until i came back. eventually, though, i just removed the evap system. hope that helps. -pantah
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Old 02-13-2006, 06:44 AM   #3
ktmMike
roadscout
ktmMike's Avatar
Oddometer: 1,249
hardstarting
texmoto,
Both of my 950s did that a lot when they were new, until I installed the Sportluftfilterdeckel from the Sommer catalog. It is a triangle shaped replacement for one of the airbox sidecovers (www.sommer.com or something like that). Sometimes, on hot days, my 950s would even cut out whenever I would come to a stop at a stop sign or whatever. When I installed the cover, all that stopped immediately (also you have to raise the carb needles one notch when you install).
KTM MIKE . . . . . . . KTM EQUIPPED SINCE 1999
three 640's (sold), two 950's (sold),
530 EXC Supermoto, 690 SMC, 990 SM-R
ktmMike is offline   Reply With Quote
Old 02-13-2006, 10:11 AM   #4
teabagger
teabagger's Avatar
Oddometer: 279
Thumb Starting woes
Goto the Jetting thread and see my post. I also have removed the SAS.
JM
teabagger is offline   Reply With Quote
Old 02-13-2006, 10:22 AM   #5
jimmex
Guero con moto
jimmex's Avatar
Oddometer: 2,785
Starting Woes
I had the exact same symptoms on my '05 950. The problem is most likely an air leak.
jimmex is offline   Reply With Quote
Old 02-13-2006, 11:00 AM   #6
trident
Town Idiot
trident's Avatar
Oddometer: 137
Have you tried turning on the GAS!! (I actually had this problem after doing my valve adjustment - I remember the tank valves but forgot the main petcock... boy was that a scare).
Just kidding, mine used to do the same thing. Sometimes stalling at stoplights and it would take me a fist full of throtle to get it going again. In short your machine is way to lean and it is causing a problem with the evap canister (same as above).
You should get as many miles to service as possible then undergo the SAS and Canisterectomy asap! Also as everyone has told me adjust your needles to the 3rd position or so and VOLA!
Everyone here has been a great big help to me while I get my machine sorted out, just wanted to pass on some.
OH by the way the Blue ones are way faster...!
And Why You Ask?.... CAUSE I'M A JEDI PIMP!
trident is offline   Reply With Quote
Old 02-13-2006, 11:34 AM   #7
AntWare
Lost In Translation
AntWare's Avatar
Oddometer: 16,483
I'll go with Pantah, until it's been de-cannistered don't fill 'er up.
Only other thing that comes to mind re the stalling is maybe it's idling too low, works great if you set it at 1400rpm, no less.
Good luck
Choose Life. Choose a job. Choose a career. Choose a family.
Choose a fucking big television.
Choose sitting on that couch watching mind-numbing, spirit-crushing game shows,
stuffing fucking junk food into your mouth.
Choose rotting away at the end of it all, pishing your last in a miserable home,
nothing more than an embarrasment to the selfish, fucked up brats you spawned to replace yourself.
Choose your future. Choose life.
I chose not to choose life, I chose something else instead.
AntWare is offline   Reply With Quote
Old 04-26-2006, 12:25 PM   #8
Foto Veloce
The Free Radical
Foto Veloce's Avatar
Oddometer: 376
I just had my bike serviced and immediatly took a 2200 mile trip to CA. First couple of days where fine. However when I got to CA after my first fillup it's been really hard to start up (even when cold but that seemed to be my bad since I'd become accustomed to starts in a climate 20F cooler).
The hard starting is not going away. I still have all the emissions junk installed. Reading this and a couple of other threads it seems that the evap could be causing this. My buddy also noted that during the hard starts it seemed like the bike was puffing fuel so that matches up with the rich diagnosis from evap can fumes/fuel?
My biggest worry is that something happened to lower the compression and this cracking open the throttle increases air volume into the cylinders and that helps it light off pretty quick.
Idle was set at 1400 by the shop and if the tach is close to accurate it looks like the idle is dead on (I also wondered if idle was too low after easier start with cracked open throttle).
Anyone have this rather specific symptom and get it 100% resolved with the evap removal or some other update/repair? With 3200 miles on it's well under warranty but I don't want to waste time and money at the shop to look for a major issue when one might not exist.
Damn this website kicks bootie!!
'05 KTM Adventure
Foto Veloce is offline   Reply With Quote
Old 04-26-2006, 12:54 PM   #9
jimmex
Guero con moto
jimmex's Avatar
Oddometer: 2,785
Hard Starting
My bike did the exact same thing and the problem was a leak in the vacuum resulting from torn hose going from the airbox to somewhere. Sounds like the same is occuring with yours.
Old 04-26-2006, 01:08 PM   #10
inte
neophyte serendipity
inte's Avatar
Oddometer: 2,738
ectomies
I'll cast another vote for the ectomies...
Do a search on "canisterectomy" ... you'll see all sorts of people (including me) who've experienced the same thing on various model years of the 950s.
Just finished a ride with Scot Harden in Virginia ... Johnathan Edwards (KTM factory team physician at Dakar) was on a BRAND NEW 950S ... if you check out the thread (linked to Scot's name above) you'll see a blue/orange 950S (only one on the tour) ... he had a pretty serious getoff & the canister & TPC valves filled up ... had to truck the bike back.
That emissions stuff is nuts. Unless you only ride pavement, and are VERY careful about how you fill the bike, it will completely disable the thing.
Mine did the same thing ... once I took it off the fix was immediate & permanent. Haven't had a single issue since & have been through some decently nasty terrain.
Sum, ergo Cogito, ergo Dubito pullus.
http://blog.motorrad-adventure.com
Twitter: @adventurephotog
Instagram: @adventurephotog
inte is offline   Reply With Quote
Old 04-26-2006, 01:24 PM   #11
Texmoto1 OP
Adventure Berzerker
Texmoto1's Avatar
Oddometer: 274
It seems that some miles and a full cannisterectomy has cured my problem? When the first service was done, It was also mentioned that my intake valves were tight?
Texmotos Photos
Old 04-26-2006, 03:27 PM   #12
Foto Veloce
The Free Radical
Oddometer: 376
3200 miles on bike.
Oil & filter at 640 miles
Full service at 2040 (exhaust valves were tight)
No problems with hot-start until 2nd day of trip started right after service. Pops A LOT on decel so I don't think it's rich in the carbs. All this canister stuff or maybe a vaccum hose was left off or loose by the mechanics?
I don't really have a garage at the moment (sold house and renting space until I buy another house) but maybe I can ectimize part of the system this week and see if that straightens it out. A loose vaccum hose would be a nice 'fix' if that is all it is but then why would it have come off.. that concerns me if it turns out to be the case.
Also on my list is moving the needle clips to #3 (now is that counting from the blunt end or needle end or are there 5 possitions and thus does not matter?) LOL
'05 KTM Adventure
Old 04-27-2006, 06:18 AM   #13
Texmoto1 OP
Adventure Berzerker
Texmoto1's Avatar
Oddometer: 274
Thats the main reason I wanted to get all the tubes and SAS and crap removed from my bike. They are a potential point of failure. If a mechanic accidently pulls on the wrong tube, or pinches one, you end up with hard to diagnose issues that can drive you nuts!
Texmotos Photos
Old 04-27-2006, 06:46 AM   #14
jnberr0
6Ninety Pilot
jnberr0's Avatar
Oddometer: 409
One of the reasons I love this site!!
Just last night I happened to go out for a quick ride as it's springtime here in Kentucky and the weather is beyond perfect. Anywho, I go to start my 2005.5 950 and it takes FOREVER to start. Not a weak battery as all electrics are up and the bike is cranking fine. It just took about 10 pushes of the starter to get the thing going. Once started, it idled fine and rode fine.
When I got home, I shut down the bike to open my gate and when I went to restart it, it was hard to start again. Frustrated, I finally got the bike locked up, cracked open a Red Stripe, and hopped on ADVRider. To my relief, the very first post in Orange Crush was title "Hard Starting". I read the post and it seems like I'm not alone in my starting problems. ADVRider is the proverbial duck's nuts. Thanks everyone for keeping this site so full of info.!
Here's my issues though: Yes, I did fill my bike all the way up and then only rode it 15-20 miles before putting it up, but that was almost a week ago. Will a filled evap canister stay filled for that long if the bike isn't started or ridden? Also, I'm still getting a horrid crack sound when the bike stalls or refuses to start. I suppose this may be that starter torque limiter that some folks have said may need replacing (KTM sent out a bad batch on some bikes, apparently?), but maybe I'm forgetting about something. Anybody have any advice on these issues?
I'm taking my bike in for an oil change and valve adjustment this weekend. I just want to make sure I'm armed with good info before going in. And yes, I hope to do the canisterectomy and maybe a set of FMF's in the fall once the warranty's up. Thanks!!
2014 KTM 690 Enduro
2006 KTM 400 EXC dual sport
jnberr0 is offline   Reply With Quote
Old 04-27-2006, 07:38 AM   #15
jsrider
Oddometer: 3,495
Yes, you are moving the clip to the middle position so it doesn't matter, but in general you are trying to raise the needle, so you should be moving the clip down from the top.
jsrider is offline   Reply With Quote
Times are GMT -7.   It's 06:48 AM.
