Old 02-19-2006, 02:44 PM   #1
wxwax OP
Excited Member
wxwax's Avatar
Oddometer: 77,624
Best glue for metal to plastic?
I have a stressed joint that mates plastic to metal. I managed to break it.
What's the best glue to use for repair? By best, I mean most likely to withstand regular stressing.
Sid.
It has been said that man is a rational animal. All my life I have been searching for evidence which could support this.
-- Bertrand Russell
To make an apple pie from scratch,
you must first invent the universe.
-- Carl Sagan
wxwax is online now   Reply With Quote
Old 02-19-2006, 02:51 PM   #2
hogmolly
Dude
hogmolly's Avatar
Oddometer: 3,142
I like the 3M automotive trim adhesive. It's the crap they use to keep molding on the sides of your car. If the metal is bare, consider painting it first. Bare metal and adhesives are problematic because water migrates along the metal adhesive interface ultimately causing the bond to fail.
10 FLHCUSE-BLK, 09 FXDL, 08 FXDWG, 98 FLHR, 07 R1200GS Adv, 95 R100GSPD Classic, 93 R100GSPD, 92 CB750
hogmolly is offline   Reply With Quote
Old 02-19-2006, 03:03 PM   #3
wxwax OP
Excited Member
wxwax's Avatar
Oddometer: 77,624
Thanks. This thing won't get really wet. But it will be subjected to a lot of twisting stress.
Sid.
-- Bertrand Russell
-- Carl Sagan
Old 02-19-2006, 03:09 PM   #4
ephemeris
UYPL
ephemeris's Avatar
Oddometer: 663
Polyurethane?
or something from 3M...........
http://products3.3m.com/catalog/us/e...er/output_html
ephemeris is offline   Reply With Quote
Old 02-19-2006, 03:46 PM   #5
nomiles
Sledge-o-matic
nomiles's Avatar
Oddometer: 4,003
Barge cement!
Been using it for years, a leathersmith friend turned me on to it. Shoemakers all use it, they buy it in gallons.
'The Original Barge Cement; Cobbler's 1st choice for gluing rubber and leather. Used in the motion picture industry by grips and set decoraters.
All Purpose Cement for rubber, wood, leather, glass, cork, metal, plastic, plaster, paper, concrete, etc.'
You can get it at hardware stores now, in the olden daze it was pro leather shops only, it's a contact type rubber cement.
Sand both pieces you want to glue or rough them up for some 'tooth' for the glue. Apply Barge cement to both pieces and let it sit awhile then stick them together (NO second chances!) and clamp them or hit them with a mallet like the shoemakers do if you really want a nice joint.
Everybody is someone else's weirdo.
nomiles screwed with this post 02-19-2006 at 03:53 PM
nomiles is offline   Reply With Quote
Old 02-19-2006, 03:54 PM   #6
Ryko123
The n00b You Love to Hate
Ryko123's Avatar
Oddometer: 154
JB Weld rox!
Ryko123 is offline   Reply With Quote
Old 02-19-2006, 04:02 PM   #7
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 33,642
Gorilla Glue or its equivalent. Supposed to be some badass stuff.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 02-19-2006, 04:48 PM   #8
kv
[none]
kv's Avatar
Oddometer: 5,048
I've heard more of the same... No exp. with it though.
Save $5.00 on a subscription to Smugmug by entering SmYAucfONBnH2 in the 'Referred by' field on the signup form.
kv is offline   Reply With Quote
Old 02-19-2006, 05:00 PM   #9
rick danger
Off the wagon
rick danger's Avatar
Oddometer: 4,992
Marine grade epoxy
rick danger is offline   Reply With Quote
Old 02-19-2006, 05:04 PM   #10
Lone Rider
Registered User
Oddometer: 25,130
Some people call it 'Sir'.
Yep, it is.
Lone Rider is offline   Reply With Quote
Old 02-19-2006, 05:07 PM   #11
Lone Rider
Registered User
Oddometer: 25,130
Originally Posted by rick danger
Marine grade epoxy
What's the difference between 'Marine Grade' and the magnum, elite, ultra, superest stuff in small tubes at auto parts stores...besides the marine price?
Old 02-19-2006, 05:11 PM   #12
skwidd
where does this lead?
Oddometer: 17,236
gorilla glue expands as it sets up,it will move stuff unless clamped heavily.
chemrex CX47
used to put truck bodies together and hold windows into highrises.
moisture cured,so you can mist it with water to speed up setting time.
some incredibly strong shit,don't put it where you don't want it once it dries.
skwidd is offline   Reply With Quote
Old 02-19-2006, 05:15 PM   #13
edwyun
edwyun's Avatar
Oddometer: 149
Plastic Weld or Plastic Steel Epoxy (depending on type of plastic and steel).
Ride Safe,
Edward
'72 Ducati 750GT
'98 Ducati 900 SS/FE
IBA#18798
www.geocities.com/edwyun/index.html
edwyun is offline   Reply With Quote
Old 02-19-2006, 07:35 PM   #14
torags
torags's Avatar
Oddometer: 2,461
Does the joint vibrate? If it does, I have had success with Sikkaflex urethane chaulk. It allows give under variable loading. If the patch is too small you may have to rivet.
Find it in hardware stores in building materials.
Rags
'02 BMW R1150R now
'04 BMW R1150RS/// Gone, but not forgotten
'07 HD XR 883R Sportster "Widow Maker"///Gone!
IBA #17225
torags is offline   Reply With Quote
Old 02-19-2006, 08:21 PM   #15
alimey4u2
alimey4u2's Avatar
Oddometer: 288
ALL depends on the "type" of plastic to be bonded, you will have limited success without mechanical retainers.
alimey4u2 is offline   Reply With Quote
Times are GMT -7.   It's 08:25 PM.
