03-01-2006, 05:07 PM
#1 |
ain'tcha gonna...
Oddometer: 87
R1100Rt first it starts, then it goes, then it quits
My R1100 RT-P was running just fine. Came down a hill in third gear, and suddenly I have no throttle. The engine didn't sputter or anything; just stone died. I listened for the fuel pump, and it was working. I checked fuses, and nothing had blown. I checked the manual
for any mysterious BMWesque problems that would elude the electricly challenged. "Check fuse number six." So, I am wondering, does anyone know about any relays/sensors/german beer law infringments which could be affecting my bike? Thanks for any help. coffee_brake5
03-01-2006, 06:07 PM
#2 |
Oddometer: 31,089
Start with the sidestand switch. Kick the sidestand up and down a few times to see if the bike will run. If not, jumper across it with a very fine piece of wire.
03-01-2006, 07:45 PM
#3 |
Oddometer: 925
Could be bad HES (Hall effect sensor). Take a look over on the IBMWR.org list in the oilheads technical section for the trouboeshooting steps to follow.
Of course, if the fuel pump continues to run then it is not the HES. |
03-02-2006, 12:00 PM
#4 | |
de-nOObed!
Oddometer: 5,046
Does the bike still turn over? Does it still spark at the plugs? Chafed wiring around the headstock. We have an 1100RT at work, I know that even in neutral, lowering the sidestand will cut the engine unlike an 1150. Tape the side stand switch in the stand retracted position to ensure that it's not weak side stand springs allowing the stand to come down a llittle & cause the bike to cut out - seen this happen once before, albeit on a Suzuki.
www.possu.smugmug.com |
03-02-2006, 02:41 PM
#5 |
Lost
Oddometer: 3,720
i didn't think the rt-p's had a sidestand cutoff.
sounds like the Hall sensor... |
03-03-2006, 03:47 AM
#6 |
ain'tcha gonna...
Oddometer: 87
It turned out to be the Hall sensor, but not because the sensor had gone bad. The service shop in Greenville, SC. ran the diagnostic and had a bad HES fault. They took the sensor off, looked at it, and put it back on. The bike turned over just fine. Do these sensors get loose? Anyway, thanks for the good tips; it could have been any of those things and I wouldn't have known any better.
03-03-2006, 04:26 AM
#7 |
Oddometer: 925
Never heard of the HES getting loose.
The HES lives down on the front of the engine in a very servere heat and mechanical environment. Many of the HES problems I have heard about are the result of heat causing causing the wiring to fail intermittantly internal to one of the sensors. One accepted method of troubleshooting such a failure is to spray the sensor with something cold and then see if the bike runs. If it does then the sensor is bad. Your shop saved you a LOT of money by not replacing the sensor assembly but if I were you I would begin looking for a used sensor replacement. There are also a couple of articles floating around the web on individual sensor replacement. Of course none of this is anything the average guy could do very easily by the side of the road on a dark and rainy night. |
03-03-2006, 06:05 AM
#8 |
Oddometer: 31,089
I agree with AF. Its usually temp related.....fails when hot, and then works when cold. It will probably die again.
03-03-2006, 12:10 PM
#9 |
Ride > Post
Oddometer: 1,376
There's been some discussion about them working intermittently when it's wet too.
03-03-2006, 12:22 PM
#10 |
rides ugly bikes
Oddometer: 226
Here's a nice write-up on how to diagnose and repair your Hall Effect Sensor:
http://www.ebbo.org/2av54.php Much cheaper than a factory new one, and I'd trust it more than a used one that may be near failure. |
03-07-2006, 04:42 PM
#11 |
ain'tcha gonna...
Oddometer: 87
I didn't know the HES is temperature sensitive. It had been a police bike and did alot of idling.
03-07-2006, 04:50 PM
#12 | |
Tinaversal
IMHO. Fuck Cancer. Ride bikes. - dave + tina |
