Old 09-11-2006, 12:45 PM   #31
Beamklamp
Velvet Burrito
Beamklamp's Avatar
Oddometer: 4,272
Looks damn cheesy in that neighborhood.
He laughed, then he took a dump.
Beamklamp is online now   Reply With Quote
Old 09-11-2006, 07:26 PM   #32
murgatroid42
Great Adventurer
Oddometer: 4,185
Originally Posted by hava98
Sorry to resurrect an old thread, but did you have to cut the sheet of plywood in half to allow you to fold the trailer? Appears that way from the pics, just wanted to make sure. I think I'll have one of these in my garage this week.
hava98
Yes, you have to cut it in half. Home Depot will do it for you.
"We hang around people who think these activities are normal."
"Me and gravity, we are really, really good friends." - Streetbike Tommy, Nitro Circus
"I'm a dude in his mid-40s, who acts likes he's in his 20's. But I don't plan on stopping any time soon." - Ken Block
murgatroid42 is offline   Reply With Quote
Old 09-11-2006, 08:32 PM   #33
CollinsB
CollinsB's Avatar
Oddometer: 990
I've got a smaller version of that trailer, looks to be the same manufacturer. I took the leaf springs off, lowered it, added a full length rail that extends a bit over the end. It's a great little trailer! Priced right and stores easily....
I've used it to tow my 1150GS, (a bit large for the unit) but it works perfect for the XR650.
Brian
BMW 1200GS ADV, KTM 625SXC, KTM 950SE
Yamaha R1, Kawasaki BF V750
CollinsB is offline   Reply With Quote
Old 09-12-2006, 01:13 PM   #34
Effervescent
Sexiest ADVrider '14
Effervescent's Avatar
Oddometer: 1,801
I think you just physically remove the plywood.
-Eff
Effervescent is offline   Reply With Quote
Old 09-12-2006, 02:30 PM   #35
Thinc2 OP
Paciugo
Thinc2's Avatar
Oddometer: 4,637
-Eff
No - the plywood stays on. Tthe trailer just folds over onto itself. You can see it in the pic - the plywood is painted white.
Make sure you position your eye hooks (for straps) in the plywood so they don't contact each other when you fold it - that allows it to fold more compactly.
Me: You should think before you speak.
Daughter: That always backfires on me.
F800GS review.
Thinc2 screwed with this post 09-12-2006 at 02:42 PM
Thinc2 is offline   Reply With Quote
Old 09-12-2006, 02:35 PM   #36
Thinc2 OP
Paciugo
Thinc2's Avatar
Oddometer: 4,637
No kidding.
That's why you fold it up and store it in your garage - so you don't have a trailer sitting in your yard
F800GS review.
Old 09-12-2006, 02:41 PM   #37
element
Time to roll
element's Avatar
Oddometer: 357
Same setup
Great trailer, I replaced the bearings at 9,000 miles... the new ones from HF are better then first set.
I also do not uses the trailer sides to save weight and air drag
Aluminium ramps save weight too and that helps the smaller 4 cyl engines pull the trailer at highway speeds
element is offline   Reply With Quote
Old 09-12-2006, 02:42 PM   #38
kevbo
Rubbery-Lip Flappin' PHI
kevbo's Avatar
Oddometer: 1,478
Question
Originally Posted by ozrockrat
Looking at your photos of the hitch area I would suggest you replace the safety chain hooks with real shackles
I have had the ones on my trailer (the same one) shake loose while towing.
They will every time if connected as in the photo. To make that style work, you need long chains. Pass the whole chain through the loop on the hitch, spiraral the end around the standing chain at least twice, then hook the hook in a link of chain, and pull the whole works tight. Works great untill your buddy borrows your trailer, hooks it like in the photo, and returns it with links of the chain ground down, (from dragging on the pavement) and the advice that "you need to shorten up those chains!"
Sincerity is the most important thing. Once you learn to fake that, the rest is easy.
kevbo is offline   Reply With Quote
Old 09-12-2006, 02:45 PM   #39
Thinc2 OP
Paciugo
Thinc2's Avatar
Oddometer: 4,637
Originally Posted by kevbo
They will every time if connected as in the photo. To make that style work, you need long chains. Pass the whole chain through the loop on the hitch, spiraral the end around the standing chain at least twice, then hook the hook in a link of chain, and pull the whole works tight. Works great untill your buddy borrows your trailer, hooks it like in the photo, and returns it with links of the chain ground down, and the advice that "you need to shorten up those chains!"
Thanks for the reminder - I've still been using it just the way it is in the pic - looks like I need to fix that before making any longer trips.
F800GS review.
Old 09-12-2006, 02:55 PM   #40
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,555
Here is an alternative to that trailer:
Old 09-12-2006, 03:39 PM   #41
markgsnw
WTF?
markgsnw's Avatar
Oddometer: 3,592
Originally Posted by Yellow Pig
that's just crying out for a Harley
http://vasaphoto.wordpress.com/
2011 Moto Guzzi Norge 8V GT
markgsnw is offline   Reply With Quote
Old 09-12-2006, 05:35 PM   #42
CollinsB
CollinsB's Avatar
Oddometer: 990
"Diamond Plate" makes anything look cool!
Brian
Old 09-13-2006, 07:44 PM   #43
Thinc2 OP
Paciugo
Thinc2's Avatar
Oddometer: 4,637
Porco Giallo,
That's a nice trailer! I didn't know about it when I bought mine. It's a good alternative - I think the decision really comes down to how much you want to spend and how many miles you are going to put on it.
I'm using mine as much as a utility trailer to haul concrete, BBQ's, wood, household goods etc as for the bikes, so it's working out well. I definately need the rails.
Your version certainly looks more sturdy in certain areas, as you pointed out. Better axles/bearings would be nice. RDubb mentioned he broke his fenders on your version of the trailer - losing one on the highway.
I also had a fender break off - due to metal fatigue at the bracket right where it attached to the trailer.
Looks like there are at least two decent options for folding trailers under $1K.
F800GS review.
Old 01-05-2007, 07:35 AM   #44
caffeine
Oddometer: 962
hate to bring up an old thread, but curious if anyon has taken any of these trailers on a longer trip?
I am looking for something "smaller" (as compared to an exclosed 8x14 monster that i have to tow with a dodge 2500 heavy duty gas eater) to tote my KLR around with my 6 banger blazer......potentially out of state on some few hundred mile rides....
anyone taken the HF folding trailer (great for me since i have limited storage) on a longer ride? i figure the KLR is 400lbsish...should be ok.
-Rob
caffeine is offline   Reply With Quote
Old 01-05-2007, 08:24 AM   #45
gman350
Oddometer: 156
I've got a HF 4X8 folding trailer. I got the one with 8" wheels, rated for 990lbs. I've used it to haul 2 dirtbikes, 12 gallons gas, and all the associated riding gear on several 1400+ mile trips. Ran 80+, 0 issues. Make sure you get the load distributed right so the trailer doesn't wobble. I've also hauled my 600+ lb Concours on it. Mine ate the bearings this past year, after 7 years of hard use and no maintenance. For the price, and the ability to fold up, you just can't beat this trailer. Granted, if I had a good place to store one, I would have bought a heavy duty non-folding trailer from a reputable manufacturer.
gman350 is offline   Reply With Quote
Times are GMT -7.   It's 11:19 AM.
